    [Plugin][$] TopoShaper - v2.7a - 01 Apr 24
    451 Posts 143 Posters 669.3k Views 142 Watching
    • fredo6F Offline
      @simonhaufe said:
      I just try TopoShaper with a point cloud with more than 130.000 points out of a ASCII-File. How I can import it in SU and make any kind of terrain model?
      Any ideas and suggestions are most welcome!! 😎 β˜€
      Best Regards Simon
      I don't think TopoShaper can handle 130,000 points; and I don't think either that Sketchup will not scream with a mesh of 130,000 vertices.
      So you'll probably have to find a way, with other tools to simplify the input points or raw mesh, either simplifying, or cutting in pieces if the cloud covers a very large area. I don't know if there are Ruby scripts in Sketchup to do that, but I know there are specialized terrain software that can do it. There are several discussion threads in Sketchucation and Sketchup forums about terrains.
        rspierenburg
        I'm trying to use Toposhaper to create a topo from points. I have points selected and when I run the plugin all I get is a blank error.
        Toposhaper Error
        • fredo6F Offline
          It would be helpful that you attach your model so that I can investigate. Thanks.
            rspierenburg
            Thanks, Here is the model.
            Topography.skp
            • fredo6F Offline
              @Rspierenburg
              You just need to put all contruction points and the contour within a Group, then select the group and run TopoShaper Cloud.
              Note that your model seems to have some points which create peaks.
              Rspierenburg - Topography - SU2015.skp
                Anastasia_0111
                What can be the reason of such error of TopoShaper?
                It appears on SketchUp17 and 18, if I try very simple terrain, just of 2 or 3 curves.
                  Put your SKP, that can be helping! πŸ˜‰
                  Save as V6 for a more large audience! πŸ˜‰
                    Anastasia_0111
                    As I said it happens in any file, just if I try to create a terrain from 2 simple curves drawn by "freehand".
                    This is a full text of the error:
                    body_lib6g6.rbe
                    2254
                    block in proximity_point_curve_by_circle
                    body_lib6g6.rbe
                    2249
                    each
                    body_lib6g6.rbe
                    2249
                    toposhaperalgo.rbe
                    2419
                    block in altitude_at_point
                    toposhaperalgo.rbe
                    2417
                    each
                    toposhaperalgo.rbe
                    2417
                    altitude_at_point
                    toposhaperalgo.rbe
                    2390
                    altitude_multi
                    toposhaperalgo.rbe
                    427
                    block in top_processing
                    toposhaperalgo.rbe
                    425
                    each
                    toposhaperalgo.rbe
                    425
                    each_with_index
                    toposhaperalgo.rbe
                    425
                    top_processing
                    toposhapertool.rbe
                    574
                    algo_processing
                    toposhapertool.rbe
                    666
                    execute_validate
                    toposhaperpalette.rbe
                    130
                    execute_from_palette
                    76
                    notify_from_palette
                    518
                    call
                    518
                    block (2 levels) in palette_validate
                    body_lib6palette.rbe
                    3596
                    call
                    3596
                    execute_button
                    3401
                    onLButtonUp
                    lib6palette.rbe
                    91
                    onLButtonUp
                    toposhapertool.rbe
                    984
                    onLButtonUp
                    • fredo6F Offline
                      @Anastasia_0111
                      Could you indicate the text of the error (just just give the files and line numbers), as well as post one of this simple model with free-hand drawn curve.
                      Many thanks
                        peggy1124
                        Thank you Fredo
                        amazing plugin
                          Keniff
                          Hi, Can't get this to work on my Mac. Using the supplied 'test' SKP file I either get a full on program bug splat! a non contoured output, just the shape of the face or the attached useless error message:
                          Any help appreciated
                            Keniff
                            Hi, Finally got this working on my mac after I realised that it worked on a group rather than selecting points (contrary to some vids I've watched) However, now I've got it working the results I've got are not using all the cloud points in the group. Therefore the result is very "pointy" Any help appreciated
                            • fredo6F Offline
                              Very difficult to help if you do not post the model
                                akaraphon
                                hi fredo btw this plugin is very useful but i have some question . i want to create full area terrain but this is what i got . could you help me what i have to do
                                ps. thank you
                                  akaraphon
                                  hi fredo ,i got some problem . i want to create terrain in full area but this is what i got . how can i do for expand the extent of terrain
                                  thank you
                                  • fredo6F Offline
                                    If you include a face (or several) in the group where you have the Guide points, TopoShaper will use them for the contour of the terrain.
                                    Anyway, the best is that you post your model so that I can have a look.
                                      alpro
                                      Fredo, first off let me thank you for all of your amazing plugins. I have a request for toposhaper. I don't know anything about coding and/or how difficult this would be. But in surface modeling programs you have the ability to add breaklines which make a more accurate surface. Do you think this can be added?
                                      A Breakline is a line used to connect data representing a distinct surface feature, like a ridge line, edge of pavement, toe of a slope, centreline of a road, or flowline of a ditch or stream. When a breakline is defined, the surface triangulation must first follow the breakline, by placing triangle edges coincident with the breakline segments. This ensures the feature in the model is accurately depicted. Then, the rest of the interpolation is performed based on proximity. Breaklines are typically critical to creating an accurate surface model. It is the interpolation of the data, not just the data itself that determines the shape of the model.
                                        alpro
                                        That's great Fredo, look forward to it.
                                        • fredo6F Offline
                                          It is complex (it involves constrained Delaunay triangulation), but I finally built an algorithm (I use it already in FredoCorner). I will integrate it in TopoShaper when I can, along with a GUI refresh. This would look like a "from Contour", where you can also influence the terrain with additional guide points.
                                          • pbacotP Offline
                                            What I wonder how this could be input to the plugin. I'd like to see an example and how it might be implemented on UI level. I suppose edges that are horizontal can be introduced which are defined as firm intersections with the surface and not interpolated with the rest of the terrain. Working-in grades along retaining walls or building walls (rarely level) might be done be definition of point elevations.
                                            My approach is usually working with existing terrain so after TopoShaper I massage it to new work as needed, sometimes cutting the surface where needed, sometimes moving points of the cut portions to fit to new walls or edges of pavement (e.g.). I see that where a vertical face is actually included in the original contours, weird results happen, but I generally rebuild that part or cover it in other geometry (like a model of the retaining wall it represents).
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
