    Enscape for Sketchup
    extensions
    79 Posts 23 Posters 57.9k Views 23 Watching
    • soloS Offline
      @jql said:
      Is enscape getting better or are you dealing better with it Pete? It's a tremendous quality improvement on your compilation, from the first video you posted.
      Well there has been only one update since I started using Enscape and that was not significant, seems like the Devs are all from a Revit background and all the love goes there first even though SU users will outnumber RT users by a factor of a thousand eventually. I also feel that the development is more concentrated on the VR market than the animation market.
      I just found ways to compensate for the lacking features and more tricks than features at this point.
      • JQLJ Offline
        JQL
        @solo said:
        As I suspected. Post pro tricks or tricks with enscape?
        www.casca.pt
        Visit us on facebook!
        • soloS Offline
          No post pro, more HDRi trickery, camera movement and the fact that I have a new machine with a better GPU and can render at 1080p faster than my last machine could do 720p.
          • ArcA Offline
            Arc
            Who knows how to setup emissive intensity?
            • Thomas SchanderT Offline
              Thomas Schander
              The emissive intensity is based on the material color, white therefore means the maximum intensity. However, emissive materials are currently not yet suited to illuminate large areas. They are just designed to show some "glow". This will be improved in one of the next releases.
              @RichOBrian: The water will be improved, and together with the mentioned emissive and reflections improvement, there will be an AO slider. Hope that helps 😄
              Please notice that the current Enscape for SketchUp version was still an alpha, we will release it in the next days. It will already be a lot more stable and versatile in terms of section planes and billboards.
                Thomas Schander
                We released a new alpha version with support for Skatter!
                https://forum.enscape3d.com/index.php?thread/175-preview-for-sketchup-1-9-4-369/
                Also, the many other features like the grass rendering have been improved. Check it out 😄
                  Phil Rader AIA
                  Here is a recent example of an urban infill house. Really digging Enscape3d, in particular, it's ease of use and Rift and Touch. Kudos to the entire Enscape Team.
                  windows .exe file:
                  Dropbox - Error - Simplify your life
                  (www.dropbox.com)
                  http://www.philrader.com
                  • ntxdaveN Offline
                    ntxdave
                    Well done sir. I was able to navigate both internally as well as externally. Also was able to go up and view the loft and go down to view the basement. 👍
                    Press F1...thank me later
                    • brettsichellodesignB Offline
                      brettsichellodesign
                      This plugin is brilliant. The main thing I look for when trying a new program is it's collaboration with SketchUp and trying to keep everything in the same program so I don't need to do duplicate revisions. The panoramic, VR and walkthrough capabilities of this plugin are brilliant and it is being constantly developed. I see big things for Enscape.
                      Please check out my test run...
                      • marvins_dadM Offline
                        marvins_dad
                        A little late to the show, but noticed this last month when researching VR and saw that it works with Revit and SketchUp...so that's a plus for my firm.
                        Then I ran across a thread in their forum discussing the Oculus Go and noticed Pete on their...maybe it was his question. Anyway, actually learned a lot about VR headsets from that thread and how people are using them with clients.
                        My quick question is about portability and VR...has anyone played with that yet?
                        Revit Live requires the model to be uploaded to the cloud then downloaded to run...which I think is ridiculous when you have the computing power to do it...but what about portability. You can't always rely on robust internet access if you take the setup to a client.
                        Can you run Enscape from a muscle powered laptop for a walkthrough in VR? Without internet access?
                        My Gallery
                          alpro
                          Yes you can run Enscape from a beefy laptop, I'm running a MSI with a Nvidia 1070, 32 GB ram, 2 TB ssd, runs without any issues. Also using the HTC Vive, not super portable but definitely manageable, you'll need some tripods or suction cups for the base stations, takes about 10 mins to setup on site. I have used it at 2 clients residences when they couldn't come to the office. It definitely wowed them. Not sure about the Oculus Rift but with the Vive you will need a internet connection to connect to Steam and run the room setup. The sketchup model is local on your laptop. I've been pretty impressed with Enscape so far.
                            marvins_dad
                            Great, Thanks!
                            My Gallery
                            • Paul RussamP Offline
                              Paul Russam
                              I've just got into Enscape and like you I've been looking at the VR stuff, There's now Windows Mixed reality (MR) headsets that combines the headset with the sensors for the controllers. There are a few out like these from HP and DELL and they seem good value:
                              http://h20386.www2.hp.com/AustraliaStore/Merch/offer.aspx?p=hp-mixed-reality-headset
                              https://www.dell.com/en-uk/shop/dell-visor-with-controllers/apd/545-bbbi/gaming?ref=p13n_ena_pdp_vv&c=uk&cs=ukdhs1&l=en&s=dhs
                              Here's a YT video of the DELL being used with Enscape: https://youtu.be/NshiXpZHYRE?t=590
                              Paul Russam
                              English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                                marvins_dad
                                I've been looking at those, leaning more towards the Lenovo version at the moment. Thanks!
                                My Gallery
                                • E Offline
                                  Enscape
                                  Hi there,
                                  We have now released Version 2.3 with lots of improved features like adjustable water, high quality screenshots in VR and much more. We hope that this will help you creating even better projects!
                                  You can see what's new in our latest blog post: https://bit.ly/2yMEeKS.
                                  Best,
                                  Léa from Enscape
                                  https://enscape3d.com/wp-content/uploads/2018/06/infografik_1_v6.jpg
                                    ark
                                    Hallo guys,
                                    Just playing around with Enscape and is quite amazed of it's simplicity and quality if tweaked correctly.
                                    Does anyone have any problems regarding amount of proxies from Skatter?
                                    I have a scene where only some is loaded into Enscape even though it works in other render plugins like Thea render...
                                    • 4 / 4
