    Enscape for Sketchup
    extensions
    79 Posts 23 Posters 65.3k Views 23 Watching
    • soloS
      Having fun with this software, cannot wait for glass fixes, proxy integration with Skatter and ability to control materials and add lights, but so far I am loving it.
      • ntxdaveN
        ntxdave
        Solo, I am impressed. πŸ‘
        I wish I could learn how to do the landscaping like you have in this model. Between the landscaping and the background it looks very realistic.
        Press F1...thank me later
        • jujuJ
          juju
          This looks promising, it has a miniature model feel to it, appealing in some sense.
          • soloS
            A compilation of videos I have created with Enscape to showcase how diverse the application can be. Cannot wait for some basic features to be implemented like lights, material editor, keyframe controls, and a proxy system. Royalty free music 'ignite to life'
            Select HD if you can as it was done in 1080p
            • pbacotP
              Thanks Pete,
              The environmental lighting looks incredible! Killer models too.
              Some of the architectural models look a little like scale models. Do you think that is just due to D.O.F.?
              Really exciting output.
              Peter
              • soloS
                The DOF in many cases results in a tilt-shift effect, I kinda like it.
                • ntxdaveN
                  ntxdave
                  Really nice example Pete πŸ‘
                  This product really has some potential IMO. I downloaded version 1.9.3.152 but when I tried to use it I got the Trial Expired and I can no longer produce any output however I think I could see still more improvement in what I could do.
                  As you stated, "Cannot wait for some basic features to be implemented like lights, material editor, keyframe controls, and a proxy system." There are a couple of other things I would like to see but what you stated would certainly make it one heck of a product. Can you imagine how it would be if you could use Fredo's Animator plugin with it.
                    Are there plan for proper moving water shaders?
                    What's up with the AO? Seems to draw in and out?
                    • JQLJ
                      JQL
                      Is enscape getting better or are you dealing better with it Pete? It's a tremendous quality improvement on your compilation, from the first video you posted.
                      www.casca.pt
                      Visit us on facebook!
                      • soloS
                        Well there has been only one update since I started using Enscape and that was not significant, seems like the Devs are all from a Revit background and all the love goes there first even though SU users will outnumber RT users by a factor of a thousand eventually. I also feel that the development is more concentrated on the VR market than the animation market.
                        I just found ways to compensate for the lacking features and more tricks than features at this point.
                        • JQLJ
                          JQL
                          @solo said:
                          As I suspected. Post pro tricks or tricks with enscape?
                          www.casca.pt
                          • soloS
                            No post pro, more HDRi trickery, camera movement and the fact that I have a new machine with a better GPU and can render at 1080p faster than my last machine could do 720p.
                            • ArcA
                              Arc
                              Who knows how to setup emissive intensity?
                              • Thomas SchanderT
                                Thomas Schander
                                The emissive intensity is based on the material color, white therefore means the maximum intensity. However, emissive materials are currently not yet suited to illuminate large areas. They are just designed to show some "glow". This will be improved in one of the next releases.
                                @RichOBrian: The water will be improved, and together with the mentioned emissive and reflections improvement, there will be an AO slider. Hope that helps πŸ˜„
                                Please notice that the current Enscape for SketchUp version was still an alpha, we will release it in the next days. It will already be a lot more stable and versatile in terms of section planes and billboards.
                                • Thomas SchanderT
                                  Thomas Schander
                                  We released a new alpha version with support for Skatter!
                                  https://forum.enscape3d.com/index.php?thread/175-preview-for-sketchup-1-9-4-369/
                                  Also, the many other features like the grass rendering have been improved. Check it out πŸ˜„
                                  • P
                                    Phil Rader AIA
                                    Here is a recent example of an urban infill house. Really digging Enscape3d, in particular, it's ease of use and Rift and Touch. Kudos to the entire Enscape Team.
                                    windows .exe file:
                                    Dropbox - Error - Simplify your life
                                    (www.dropbox.com)
                                    http://www.philrader.com
                                    • ntxdaveN
                                      ntxdave
                                      Well done sir. I was able to navigate both internally as well as externally. Also was able to go up and view the loft and go down to view the basement. πŸ‘
                                      • brettsichellodesignB
                                        brettsichellodesign
                                        This plugin is brilliant. The main thing I look for when trying a new program is it's collaboration with SketchUp and trying to keep everything in the same program so I don't need to do duplicate revisions. The panoramic, VR and walkthrough capabilities of this plugin are brilliant and it is being constantly developed. I see big things for Enscape.
                                        Please check out my test run...
                                        • marvins_dadM
                                          marvins_dad
                                          A little late to the show, but noticed this last month when researching VR and saw that it works with Revit and SketchUp...so that's a plus for my firm.
                                          Then I ran across a thread in their forum discussing the Oculus Go and noticed Pete on their...maybe it was his question. Anyway, actually learned a lot about VR headsets from that thread and how people are using them with clients.
                                          My quick question is about portability and VR...has anyone played with that yet?
                                          Revit Live requires the model to be uploaded to the cloud then downloaded to run...which I think is ridiculous when you have the computing power to do it...but what about portability. You can't always rely on robust internet access if you take the setup to a client.
                                          Can you run Enscape from a muscle powered laptop for a walkthrough in VR? Without internet access?
                                          My Gallery
                                            alpro
                                            Yes you can run Enscape from a beefy laptop, I'm running a MSI with a Nvidia 1070, 32 GB ram, 2 TB ssd, runs without any issues. Also using the HTC Vive, not super portable but definitely manageable, you'll need some tripods or suction cups for the base stations, takes about 10 mins to setup on site. I have used it at 2 clients residences when they couldn't come to the office. It definitely wowed them. Not sure about the Oculus Rift but with the Vive you will need a internet connection to connect to Steam and run the room setup. The sketchup model is local on your laptop. I've been pretty impressed with Enscape so far.
                                            • 4 / 4
