    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.1m Views 79 Watching
    • BoxB Offline
      @hornoxx said:
      how did you get the individual limbs so well strung up next to each other?
      That's what I meant with my last line about using your choice of Stringer. There are a few to choose from, from memory
      Component Stringer by Chris Fulmer
      Comp String by Sam D Mitch
      Path Copy by Smustard
      or in this case Copy Along Curve by Anton S.
      I rendered another after laying the links down flat to the body.
      • BoxB Offline
        Here you go, Unfortunately I can't fully unSUbD it but you get the idea. Each link starts as just a square doughnut that has been twisted with vertex tools.
        Why describe when you can do.
        Like this,
        then distribute with your choice of stringer.
        • BoxB Offline
          SUbD is very helpful when basket weaving. A bit of clothworks thrown in for good measure.
            I could use one of those chairs right now... ๐Ÿ˜„
            • HornOxxH Offline
              HornOxx
              ๐Ÿ˜„ end of may and already 32ยฐC - Iยดll take such a chair also ๐Ÿ˜„ Really excellent Box!
              never trust a skinny cook
              • BoxB Offline
                Something a little different. I'd call it Modern Retro with a nod to Spiderman.
                It's got that late sixties early seventies molded plastic feel but perhaps made with updated materials and processes.
                • cottyC Offline
                  cotty
                  Very nice!
                  my SketchUp gallery
                  • BoxB Offline
                    Here's a little silliness for those that wonder about making parts fit together or that everything has to be a soft curve.
                    The lid fits accurately although it is a separate component and the rubber/plastic seal around the electric cord has defined edges while still being part of the main component.
                    It is made up of only two parts, the main body including the power cord and the lid.
                    Although I must admit I haven't created the hinge section, nor have I done the plug as there are so many variations of them around the world. Not many here would be looking for an Australian plug.
                    I'll add the proxy if anyone wants to do the hinge and their own plug.
                    KettleProxy.skp
                    • boofredlayB Offline
                      boofredlay
                      Great!
                      • BoxB Offline
                        Thanks Cotty, Boo ๐Ÿ‘
                        Something to keep in mind, SUbD isn't just about organic modelling.
                        It's about low poly to high poly. But it can be easily used on medium poly to smooth everything nicely before rendering.
                        Here you see how something that is fairly blocky, but not low poly can be smoothed out with a quick bit of SUbD. Sometimes you want to render a whole model that is well constructed but not so overdone with segments that you get bogged down, but you'd like to do some close up of parts that may not be as smooth as you would want. Rather than having to redraw them with more segments just for the closeup, if well constructed to begin with, a quick subd to smooth is all you need.
                        Model
                        Before SUbD
                        After SUbD
                          Enlighting! ๐Ÿ˜Ž
                          • FrederikF Offline
                            Frederik
                            ๐Ÿ‘ Good point...
                            I know that a lot of other 3D modelling applications are utilizing this in a much wider extend...
                            3dMax have the Turbo Smooth option...
                            If users import such model into i.e. SU, they look really edgy...
                            Cheers
                            Kim Frederik
                            • BoxB Offline
                              Yeah, might be able to fix some models, but I can imagine there might be problems with triangulation and SUbD.
                              But throw in a few blades and some hex screws...
                              • utilerU Offline
                                utiler
                                That's extraordinary, Box!! ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
                                Just Curious...
                                • BoxB Offline
                                  Thanks Andrew but it's not that extraordinary really, just the magic of render software with a very simple model.
                                  • utilerU Offline
                                    utiler
                                    smarty pants.... ๐Ÿ‘
                                    that fan looks a little more work though..?
                                    Just Curious...
                                    • BoxB Offline
                                      Umm, not really.
                                      https://i.imgur.com/wO8RwzW.gif
                                      • BoxB Offline
                                        It would be nice to see what others are making with SUbD.
                                        Another doodle, inspired by someone asking how to make a pineapple post cap. They only wanted a simple solid shape, but I went over the top as usual.
                                        It's a very simple proxy component, radial array, copy and flip.
                                        • HornOxxH Offline
                                          HornOxx
                                          "...but I went over the top as usual..." ๐Ÿ˜„ ๐Ÿ‘ ๐Ÿ˜„ and as usual you manage to turn the "simplest" thing into a so wonderful complex shape - I love it!
                                          • alsomarA Offline
                                            alsomar Extension Creator
                                            Work in progress. A knife, maybe a short sword. QFT + VT + SUbD.
                                            Alejandro Soriano Visuals ยท All my links
                                            • 11
                                            • 12
                                            • 13
                                            • 82
                                            • 83
                                            • 11 / 83
