    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • BoxB
      Here you go, Unfortunately I can't fully unSUbD it but you get the idea. Each link starts as just a square doughnut that has been twisted with vertex tools.
      Why describe when you can do.
      Like this,
      then distribute with your choice of stringer.
      • BoxB
        SUbD is very helpful when basket weaving. A bit of clothworks thrown in for good measure.
          I could use one of those chairs right now... ๐Ÿ˜„
          • HornOxxH
            HornOxx
            ๐Ÿ˜„ end of may and already 32ยฐC - Iยดll take such a chair also ๐Ÿ˜„ Really excellent Box!
            never trust a skinny cook
            • BoxB
              Something a little different. I'd call it Modern Retro with a nod to Spiderman.
              It's got that late sixties early seventies molded plastic feel but perhaps made with updated materials and processes.
              • cottyC
                cotty
                Very nice!
                my SketchUp gallery
                • BoxB
                  Here's a little silliness for those that wonder about making parts fit together or that everything has to be a soft curve.
                  The lid fits accurately although it is a separate component and the rubber/plastic seal around the electric cord has defined edges while still being part of the main component.
                  It is made up of only two parts, the main body including the power cord and the lid.
                  Although I must admit I haven't created the hinge section, nor have I done the plug as there are so many variations of them around the world. Not many here would be looking for an Australian plug.
                  I'll add the proxy if anyone wants to do the hinge and their own plug.
                  KettleProxy.skp
                  • boofredlayB
                    boofredlay
                    Great!
                    • BoxB
                      Thanks Cotty, Boo ๐Ÿ‘
                      Something to keep in mind, SUbD isn't just about organic modelling.
                      It's about low poly to high poly. But it can be easily used on medium poly to smooth everything nicely before rendering.
                      Here you see how something that is fairly blocky, but not low poly can be smoothed out with a quick bit of SUbD. Sometimes you want to render a whole model that is well constructed but not so overdone with segments that you get bogged down, but you'd like to do some close up of parts that may not be as smooth as you would want. Rather than having to redraw them with more segments just for the closeup, if well constructed to begin with, a quick subd to smooth is all you need.
                      Model
                      Before SUbD
                      After SUbD
                        Enlighting! ๐Ÿ˜Ž
                        • FrederikF
                          Frederik
                          ๐Ÿ‘ Good point...
                          I know that a lot of other 3D modelling applications are utilizing this in a much wider extend...
                          3dMax have the Turbo Smooth option...
                          If users import such model into i.e. SU, they look really edgy...
                          Cheers
                          Kim Frederik
                          • BoxB
                            Yeah, might be able to fix some models, but I can imagine there might be problems with triangulation and SUbD.
                            But throw in a few blades and some hex screws...
                            • utilerU
                              utiler
                              That's extraordinary, Box!! ๐Ÿ˜ฎ ๐Ÿ˜ฎ ๐Ÿ˜ฎ
                              Just Curious...
                              • BoxB
                                Thanks Andrew but it's not that extraordinary really, just the magic of render software with a very simple model.
                                • utilerU
                                  utiler
                                  smarty pants.... ๐Ÿ‘
                                  that fan looks a little more work though..?
                                  Just Curious...
                                  • BoxB
                                    Umm, not really.
                                    https://i.imgur.com/wO8RwzW.gif
                                    • BoxB
                                      It would be nice to see what others are making with SUbD.
                                      Another doodle, inspired by someone asking how to make a pineapple post cap. They only wanted a simple solid shape, but I went over the top as usual.
                                      It's a very simple proxy component, radial array, copy and flip.
                                      • HornOxxH
                                        HornOxx
                                        "...but I went over the top as usual..." ๐Ÿ˜„ ๐Ÿ‘ ๐Ÿ˜„ and as usual you manage to turn the "simplest" thing into a so wonderful complex shape - I love it!
                                        • alsomarA
                                          alsomar Extension Creator
                                          Work in progress. A knife, maybe a short sword. QFT + VT + SUbD.
                                          Alejandro Soriano Visuals ยท All my links
                                          • BoxB
                                            Another bit of SUbD fun for no other reason than it makes me smile.
                                            https://i.imgur.com/QyfQSr1.gif
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 83
                                            • 84
                                            • 59 / 84
