[Plugin] ClothWorks v1.8.0 - 28 Apr 2024
Hieru and Oxer - your examples just above are so great !!
how do you manage to generate these voluminous cloth shapes - whether as a pillow or a sack full of potatoes? what I mean is, which kind of cloth surface collides here onto or around which collider to get such a complex kind of result? -
A picture is worth more than 1000 words.
New test, ClothWorks+MSPhysics, I modeled the potatoes and they placed with MSPhysics.
Hi Anton.
Bought and testing. Simply AWESOME. It's just what I needed. Anton, you're amazing.
still trying to make pillows.
but I'm not getting on...
Any ideas or tutorials?
@ Oxer: how did you fix the frame?
draping simple grids works fine. I've made a model of my curtain samples
please help me out of my hole - I try and try but don't get any idea what to do in which way to achieve such kind of shapes
The frame is a pin, select the frame > right click > Make Pin
oxer
Thank you for the pictures. Please forgive my dullness, but could you explain how to use each of the pictures? -
That's very smart...it will probably remove a step when I record my pillow workflow .
impressive work oxer!
Thank you, oxer
You're welcome!
Care Frederik!! "The curiosity killed the cat"
The possibilities are endless, you can use ClothWorks to create a lot of different organic objects, more examples at the end of the day or tomorrow.
thank you Oxer for your second sketch
I continue to fail at the simplest things How do I make cloth and Pin sticking together?
But seriously...
When I converge the cloth+frame with the balls (collider), the cloth doesn't bend as I would expect...I press the ClothWorks play button, click the frame (pin) and drag the red arrow towards the balls, but the cloth just remain stiff and doesn't fold around the balls...
I don't get the result HornOxx is showing in his animation...
I assume that's caused by the cloth isn't "inside" the frame...?!? -
HornOxx & Frederik, the trick is to create the frame with 3 elements because if the frame is an unique object ClothWorks creates a box for the pin and this makes that the cloth does not move. See the image.
REMEMBER: The cloth should enter a little in the frame.
