    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 643.3k Views 161 Watching
      sofie9536
      clothwork is a great tool to create models in sketchup and to use in iclone. Here is a little example:
      coll. objects
      in iclone
      • HornOxxH Offline
        HornOxx
        @sofie9536 said:
        ...Here is a little example
        👍 this upper Collider is a good isea !
        never trust a skinny cook
        • FrederikF Offline
          Frederik
          @pixero said:
          In his reply he asked for a way of dividing lines into equal segments and my reply answered that.
          All good...
          I interpreted it as if you hadn't read all posts...
          Cheers
          Kim Frederik
            Anton_S
            Announcing version 1.1.0: https://sketchucation.com/pluginstore?pln=ClothWorks
            1. Fixed toolbar and dialogs on Mac OS X. Now dialogs are no longer displayed as modal dialogs and toolbars can be updated.
            2. Improved UI slider performance when simulation is active.
            3. Added a feature to split edges. Now in addition to Weld Edges option there is a Split Edges option, allowing you to assign maximum spacing.
            • alsomarA Offline
              alsomar Extension Creator
              I really love this extension. Thank you so much Anton! 😄
              Here's my last test using ClothWorks and Thea Render. The statue I've used is "Le Transi de Rene de Chalon" from Three D Scans
              https://alejandrosoriano.xyz/wp-content/uploads/2018/03/Chalon_skp.jpg
              https://alejandrosoriano.xyz/wp-content/uploads/2018/03/Chalon_thea.png
              Alejandro Soriano Visuals · All my links
              • BoxB Offline
                Somewhat reminiscent of Priscilla queen of the desert......
                • alsomarA Offline
                  Anyway it's a good refecence, isn't it? 😄
                  http://i.dailymail.co.uk/i/pix/2015/02/03/254C4B0D00000578-2938162-image-m-10_1422980924360.jpg
                  • BoxB Offline
                    That's the one!
                    Chris of the desert isn't quite the same somehow....
                      So funny! 😎
                      • BoxB Offline
                        Party Time!
                        https://i.imgur.com/FPx0XGD.gif
                        • ntxdaveN Offline
                          ntxdave
                          Box, that is really intriguing! Can that be combined with other animations? As an example, could you rotate the base and streamers at the same time as the animation you did?
                          I do car wash equipment and the brushes are a challenge. When the brush is not in action, the cloth strips just hang down when they go into action, they fly out somewhat similar to your animation except that the brush rotates and the pieces stand out similar to your animation and spin around as well.
                          Watching the thing you guys are doing with this plugin make me wonder it it could also be used to produce some water effects by using the same techniques but with a water texture instead of cloth. If not, maybe this could be Anton's next challenge (developing a plugin for presenting water in some manners similar o this plugin).
                          Press F1...thank me later
                          • HornOxxH Offline
                            HornOxx
                            @box said:
                            Party Time!
                            😮 😮 astonishment time 😄 😄
                            just WOW !!! You're taking it to a new cool level 👍 😄
                            • HornOxxH Offline
                              HornOxx
                              just another test - here I condensed(?) the clothes surface by giving it a wavy shape first to receive more cloth materia density for more "crumpled" cloth on my collider... (what a complicated sentence 😄 )
                              I forgot to mention that I copied the final drop state of the cloth into a new skup instance, deleted the entire surface to get only the frame line with which I produced a follow-me figure to simulate a cloth border with thickness ...
                              • H Offline
                                huckrorick
                                I don't know if I'll have time to do a lot with this, but I just bought it because watching what people have done with it, or just playing with it, is more fun than the movies.
                                Great work Anton.
                                Can you post something that explains a bit of how it works? What are the factors that influence the simulation?
                                I was imagining using it in the design of tent structures and hanging structures. Knowing how it works would help in understanding how to use it and how good it would be for such structures.
                                Also, the "end" state would be most important in this case.
                                • BoxB Offline
                                  You probably could but you would need some serious computing power. I edited my gif to give it some speed, here it is in real time on my ancient PC, notice how it stops when I orbit.
                                  • alsomarA Offline
                                    I tried to combine animations from SketchUp and ClockWorks with a rendered pic made with Thea Render. I used Photoshop to put them all together into a video file. The bust model is from Three D Scans.
                                    • HieruH Offline
                                      Hieru
                                      @box said:
                                      ...notice how it stops when I orbit.
                                      Isn't that part of the functionality of the pugin (to prevent it from hanging up due to the extra computations required)?
                                      www.davidhier.co.uk
                                      • chippwaltersC Offline
                                        chippwalters
                                        Just so everyone understands, Anton's plugin is not intended as an animation tool. Animating cloth is part of the simulation to achieve proper draping and is used in pretty much all cloth draping toolsets I know of.
                                        So, if you've ever used Marvelous Designer, Blender, or even Poser, you'll find a similar workflow where you position the cloth and then let the affectors act on it (like gravity, wind, elasticity, density, etc..) until it comes to a final resting position (or before if you stop the simulation).
                                        The animations seen above are just screen captures of the simulation as it happens. Sometimes, depending on the complexity of the simulation, the frames go by very slow-- and in those cases the screen capture video is later sped up. Hope that helps.
                                        Currently working with Cross-Reality technologies
                                        • alsomarA Offline
                                          But it can generate animations! Once the simulation is done, you can export all the frames to files (like jpg, png, etc) and put them together into a video file. Have a look to the last video I've uploaded (a couple of posts above)
                                            chippwalters
                                            Thank you Alejandro, I stand corrected!
                                            Also, you can export frames as OBJ files for use in another program as well. Pretty snazzy.
                                            Still, animations are not the primary use of this tool. It is certainly not at this time worked into any sort of animation workflow within SketchUp, which is understandable given it's nature.
                                            • 34
                                            • 35
                                            • 4 / 35
