    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.4k Views 170 Watching
      Anton_S
      @jo-ke said:
      I have problems with textures. what did I wrong?
      @box said:
      Make sure the texture is applied to the faces not the group.
      In addition to Box's response, to apply a texture to a simulated cloth, follow the step below:
      1. Select the simulated cloth
      2. Click on the undrape icon. This should reset the layout of the cloth
      3. Enter the context of the cloth
      4. Apply a desired texture directly to the front and/or back faces
      5. Exit the context of the cloth
      6. Click on the toggle draped icon again to renew the layout of the cloth
      Here is the part of the Draping Sphere video performing these steps (starts at 1:25):
      https://youtu.be/u-DZ17Nls9k?t=1m25s
        Anton_S
        @boofredlay said:
        @solo said:
        I want to create chains following a path, I use copy along path normally to get chain links to follow a line, I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails. So, will there be a way to drape a line? (I do not need a mesh, just a line so I can either copy along or use follow me if I want a rope.).
        Yep.
        Draw a line, divide it and drape.
        And if you apply Loop Subdivision to the simulated edges group, the edges would subdivide just like cloth.
        • I
          imabzeous
          I tried to buy the plugin but unfortunately i can only buy it via paypal which isn't supported in my country. only master cards visa cards works. so if author or sketchucation admins can help me out?
          • FrederikF
            Frederik
            @pixero said:
            Doesn't Bezier spline Polyline divider for Animation do what you want?
            @solo said:
            bezier spline worked like a charm.
            Perhaps you should read all posts before posting a reply...
            Cheers
            Kim Frederik
            • PixeroP
              Pixero
              @solo said:
              [Too bad there is no plugin that can divide a welded line into equal segments.
              Draw any curve or use the Freehand tool or weld lines. Right click. Convert to Polyline divider for animation and set max length.
              (That was once made on my request when I was making advanced animation paths in SketchUp.)
              Sometimes, if the curve doesn't fit with the Max length, there can be one edge with different length at the end.
              • BoxB
                Actually Frederik, Pixero was answering the question/statement that Solo made after he said it worked like a charm.
                • BoxB
                  Here's a bit of a summer print skirt made by dropping a cloth with a hole in it over a rudimentary waist. A sphere with a pulled top and scaled to an oval.
                  • PixeroP
                    Pixero
                    @Frederik:
                    In his reply he asked for a way of dividing lines into equal segments and my reply answered that.
                      sofie9536
                      clothwork is a great tool to create models in sketchup and to use in iclone. Here is a little example:
                      coll. objects
                      in iclone
                      • HornOxxH
                        HornOxx
                        @sofie9536 said:
                        ...Here is a little example
                        ๐Ÿ‘ this upper Collider is a good isea !
                        never trust a skinny cook
                        • FrederikF
                          Frederik
                          All good...
                          I interpreted it as if you hadn't read all posts...
                          Cheers
                          Kim Frederik
                            Anton_S
                            Announcing version 1.1.0: https://sketchucation.com/pluginstore?pln=ClothWorks
                            1. Fixed toolbar and dialogs on Mac OS X. Now dialogs are no longer displayed as modal dialogs and toolbars can be updated.
                            2. Improved UI slider performance when simulation is active.
                            3. Added a feature to split edges. Now in addition to Weld Edges option there is a Split Edges option, allowing you to assign maximum spacing.
                            • alsomarA
                              alsomar Extension Creator
                              I really love this extension. Thank you so much Anton! ๐Ÿ˜„
                              Here's my last test using ClothWorks and Thea Render. The statue I've used is "Le Transi de Rene de Chalon" from Three D Scans
                              https://alejandrosoriano.xyz/wp-content/uploads/2018/03/Chalon_skp.jpg
                              https://alejandrosoriano.xyz/wp-content/uploads/2018/03/Chalon_thea.png
                              Alejandro Soriano Visuals ยท All my links
                              • BoxB
                                Somewhat reminiscent of Priscilla queen of the desert......
                                • alsomarA
                                  Anyway it's a good refecence, isn't it? ๐Ÿ˜„
                                  http://i.dailymail.co.uk/i/pix/2015/02/03/254C4B0D00000578-2938162-image-m-10_1422980924360.jpg
                                  • BoxB
                                    That's the one!
                                    Chris of the desert isn't quite the same somehow....
                                      So funny! ๐Ÿ˜Ž
                                      • BoxB
                                        Party Time!
                                        https://i.imgur.com/FPx0XGD.gif
                                        • ntxdaveN
                                          ntxdave
                                          Box, that is really intriguing! Can that be combined with other animations? As an example, could you rotate the base and streamers at the same time as the animation you did?
                                          I do car wash equipment and the brushes are a challenge. When the brush is not in action, the cloth strips just hang down when they go into action, they fly out somewhat similar to your animation except that the brush rotates and the pieces stand out similar to your animation and spin around as well.
                                          Watching the thing you guys are doing with this plugin make me wonder it it could also be used to produce some water effects by using the same techniques but with a water texture instead of cloth. If not, maybe this could be Anton's next challenge (developing a plugin for presenting water in some manners similar o this plugin).
                                          Press F1...thank me later
                                          • HornOxxH
                                            HornOxx
                                            @box said:
                                            Party Time!
                                            ๐Ÿ˜ฎ ๐Ÿ˜ฎ astonishment time ๐Ÿ˜„ ๐Ÿ˜„
                                            just WOW !!! You're taking it to a new cool level ๐Ÿ‘ ๐Ÿ˜„
                                            • 36
                                            • 37
                                            • 6 / 37
