    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    716 Posts 167 Posters 883.3k Views 166 Watching
    • HieruH
      Hieru
      Does anyone know why there is a huge difference in results when applying SubD vs Artisan to ClothWorks generated geometry?
      I can't seem to get smooth results with SubD as it generates extra geometry and everything appears tessellated. Notice all the dimples with hidden lines turned off.
      DuvetTest.skp
      www.davidhier.co.uk
      • HieruH
        Hieru
        QFT doesn't like that at all...tons of duplicate and reverse faces plus surface weirdness.
        www.davidhier.co.uk
          How are you converting from ClothWorks to QFT?
          • HieruH
            Hieru
            I was using Convert Wireframe To Quads....that was my mistake. Convert Triangulated Mesh To Quads does the trick. I got there in the end - thanks for pointing me in the right direction Rich.
            www.davidhier.co.uk
              An easier way to use SUbD to subdivide the plane and explode to apply SUbD. Then convert that QFT compliant mesh to a cloth.
              Make sure Boundary Corners is set to Sharp in the SUbD dialog.
              • HieruH
                Hieru
                I'll give that a go, thanks.
                Looking good so far, but I need to dig into the manual so that I can appreciate the full potential.
                www.davidhier.co.uk
                • jo-keJ
                  jo-ke
                  thank you for that beautyfull plugin
                  http://www.zz7.de
                  • soloS
                    I want to create chains following a path, I use copy along path normally to get chain links to follow a line, I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails. So, will there be a way to drape a line? (I do not need a mesh, just a line so I can either copy along or use follow me if I want a rope.).
                      It alreadt support draping lines. Read the tutorial in the manual.
                      • jo-keJ
                        jo-ke
                        I have problems with textures. what did I wrong?
                        http://www.zz7.de
                        • BoxB
                          Make sure the texture is applied to the faces not the group.
                          • jujuJ
                            juju
                            I saw that "Rope Fall" is also subscription these days, very inspiring...
                            • boofredlayB
                              boofredlay
                              Yep.
                              Draw a line, divide it and drape.
                              Before
                              After
                              • soloS
                                @boofredlay said:
                                Yep.
                                Divide works on a simple line, but what about a more complex line, divide is not an option, is there a plugin to divide multiple attached lines?
                                • BoxB
                                  Either Fredo's Bezier Spline or Fredo Tools will give you suitable options for dividing or segmenting.
                                  • jujuJ
                                    juju
                                    Have you tried welding the complex line?
                                    • soloS
                                      bezier spline worked like a charm.
                                      Too bad there is no plugin that can divide a welded line into equal segments.
                                      • BoxB
                                        Both will, particularly Fredo Tools, Divide Edges.
                                        Unless I'm not understanding what you want. But after 4am need sleep now.
                                        • dereiD
                                          derei
                                          @Box
                                          @box said:
                                          Ooops, I think I made my cargo net just a bit too flexible!
                                          I didn't really understand all controls for Cloth, how do you control the elasticity of a material without making the cloth stiffer?
                                          For example, in your case, for the ball to not slip through the holes in the net, but the net to fall naturally?
                                          DESIGNER AND ARTIST DEREI.UK
                                          • jo-keJ
                                            jo-ke
                                            that's it. Thank you
                                            http://www.zz7.de
                                            • 35
                                            • 36
                                            • 5 / 36
