    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    715 Posts 166 Posters 870.7k Views 165 Watching
    • BoxB Offline
      It's pure geometry Pete, I think if it was a png on a plane the ball wouldn't be able to slip through.
      Edit: Here you can see the chainlink fence texture on a plane doesn't let the ball slip through.
      • HornOxxH Offline
        HornOxx
        @box said:
        It's pure geometry Pete,...
        ...this is so awsome again ๐Ÿ‘ ๐Ÿ˜ฎ ๐Ÿ‘
        never trust a skinny cook
          @hieru said:
          Does anyone know why there is a huge difference in results when applying SubD vs Artisan to ClothWorks generated geometry?
          I can't seem to get smooth results with SubD as it generates extra geometry and everything appears tessellated. Notice all the dimples with hidden lines turned off.
          ClothWorks is not generating QFT quads. Convert the Clothworks mesh to Quads.
          • HieruH Offline
            Hieru
            DuvetTest.skp
            www.davidhier.co.uk
            • HieruH Offline
              Hieru
              QFT doesn't like that at all...tons of duplicate and reverse faces plus surface weirdness.
              www.davidhier.co.uk
                How are you converting from ClothWorks to QFT?
                • HieruH Offline
                  Hieru
                  I was using Convert Wireframe To Quads....that was my mistake. Convert Triangulated Mesh To Quads does the trick. I got there in the end - thanks for pointing me in the right direction Rich.
                  www.davidhier.co.uk
                    An easier way to use SUbD to subdivide the plane and explode to apply SUbD. Then convert that QFT compliant mesh to a cloth.
                    Make sure Boundary Corners is set to Sharp in the SUbD dialog.
                    • HieruH Offline
                      Hieru
                      I'll give that a go, thanks.
                      Looking good so far, but I need to dig into the manual so that I can appreciate the full potential.
                      www.davidhier.co.uk
                      • jo-keJ Offline
                        jo-ke
                        thank you for that beautyfull plugin
                        http://www.zz7.de
                        • soloS Offline
                          I want to create chains following a path, I use copy along path normally to get chain links to follow a line, I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails. So, will there be a way to drape a line? (I do not need a mesh, just a line so I can either copy along or use follow me if I want a rope.).
                            It alreadt support draping lines. Read the tutorial in the manual.
                            • jo-keJ Offline
                              jo-ke
                              I have problems with textures. what did I wrong?
                              http://www.zz7.de
                              • BoxB Offline
                                Make sure the texture is applied to the faces not the group.
                                • jujuJ Offline
                                  juju
                                  I saw that "Rope Fall" is also subscription these days, very inspiring...
                                  • boofredlayB Offline
                                    boofredlay
                                    Yep.
                                    Draw a line, divide it and drape.
                                    Before
                                    After
                                    • soloS Offline
                                      @boofredlay said:
                                      Yep.
                                      Divide works on a simple line, but what about a more complex line, divide is not an option, is there a plugin to divide multiple attached lines?
                                      • BoxB Offline
                                        Either Fredo's Bezier Spline or Fredo Tools will give you suitable options for dividing or segmenting.
                                        • jujuJ Offline
                                          juju
                                          Have you tried welding the complex line?
                                          • soloS Offline
                                            bezier spline worked like a charm.
                                            Too bad there is no plugin that can divide a welded line into equal segments.
                                            • 35
                                            • 36
                                            • 5 / 36
