    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.3k Views 170 Watching
    • jo-keJ
      jo-ke
      thank you for that beautyfull plugin
      http://www.zz7.de
      • soloS
        I want to create chains following a path, I use copy along path normally to get chain links to follow a line, I used to use 'Rope fall' to create the path line but that is too slow and the author is AWOL does not answer his emails. So, will there be a way to drape a line? (I do not need a mesh, just a line so I can either copy along or use follow me if I want a rope.).
          It alreadt support draping lines. Read the tutorial in the manual.
          • jo-keJ
            jo-ke
            I have problems with textures. what did I wrong?
            http://www.zz7.de
            • BoxB
              Make sure the texture is applied to the faces not the group.
              • jujuJ
                juju
                I saw that "Rope Fall" is also subscription these days, very inspiring...
                • boofredlayB
                  boofredlay
                  Yep.
                  Draw a line, divide it and drape.
                  Before
                  After
                  • soloS
                    @boofredlay said:
                    Yep.
                    Divide works on a simple line, but what about a more complex line, divide is not an option, is there a plugin to divide multiple attached lines?
                    • BoxB
                      Either Fredo's Bezier Spline or Fredo Tools will give you suitable options for dividing or segmenting.
                      • jujuJ
                        juju
                        Have you tried welding the complex line?
                        • soloS
                          bezier spline worked like a charm.
                          Too bad there is no plugin that can divide a welded line into equal segments.
                          • BoxB
                            Both will, particularly Fredo Tools, Divide Edges.
                            Unless I'm not understanding what you want. But after 4am need sleep now.
                            • dereiD
                              derei
                              @Box
                              @box said:
                              Ooops, I think I made my cargo net just a bit too flexible!
                              I didn't really understand all controls for Cloth, how do you control the elasticity of a material without making the cloth stiffer?
                              For example, in your case, for the ball to not slip through the holes in the net, but the net to fall naturally?
                              DESIGNER AND ARTIST DEREI.UK
                              • jo-keJ
                                jo-ke
                                that's it. Thank you
                                http://www.zz7.de
                                • HornOxxH
                                  HornOxx
                                  ... with ClothWorks you can catch a lot of animals - but not a fish - a bug? πŸ˜„ πŸ˜„ πŸ˜„
                                  never trust a skinny cook
                                    smashor
                                    @dave r said:
                                    This is with one of the SUC fabrics.
                                    [attachment=1:2ig71rmb]<!-- ia1 -->AC desk plaid cu.png<!-- ia1 -->[/attachment:2ig71rmb]
                                    [attachment=0:2ig71rmb]<!-- ia0 -->AC desk plaid.png<!-- ia0 -->[/attachment:2ig71rmb]
                                    How did you do those wrinkles? Looks very cool!
                                      Anton_S
                                      Haven't checked but fish can be one of Known Limits and Limitations. And of course, I'm going to improve contact generation in a major release, which could fix the issue. We'll see.
                                        Anton_S
                                        I may have to add this as a workflow feature. Should be very simple.
                                          Anton_S
                                          In addition to Box's response, to apply a texture to a simulated cloth, follow the step below:
                                          1. Select the simulated cloth
                                          2. Click on the undrape icon. This should reset the layout of the cloth
                                          3. Enter the context of the cloth
                                          4. Apply a desired texture directly to the front and/or back faces
                                          5. Exit the context of the cloth
                                          6. Click on the toggle draped icon again to renew the layout of the cloth
                                          Here is the part of the Draping Sphere video performing these steps (starts at 1:25):
                                          https://youtu.be/u-DZ17Nls9k?t=1m25s
                                            Anton_S
                                            @boofredlay said:
                                            Yep.
                                            And if you apply Loop Subdivision to the simulated edges group, the edges would subdivide just like cloth.
                                            • 36
                                            • 37
                                            • 5 / 37
