    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 916.9k Views 155 Watching
    • fredo6F Offline
      @cadfather said:
      like here, but it happens on others too (ie. follow etc.)
      Impressive, clearly a bug or a mystery.
      Could you post the model, so that I try to understand what happens.
      EDIT: I could reproduce the problem (when the group is upside down). Fixing it. Thanks for signaling.
      • fredo6F Offline
        NEW RELEASE: JointPushPull Interactive v4.3d - 27 Feb 18
        JointPushPull Interactive 4.3d fixes bugs preventing to have a correct orientation of the pushpull direction when used on groups and components, as signaled by Cadather (see this post). You also need to upgrade LibFredo6 to v8.1c.
        JointPushPull 4.3d requires LibFredo6 8.1c or above
        See plugin home page of JointPushPull for Download of JointPushPull.
        Main Post of the JointPushPull thread on this forum
        • fredo6F Offline
          NEW RELEASE: JointPushPull Interactive v4.3e - 28 Feb 18
          JointPushPull Interactive 4.3e fixes remaining bugs preventing to have a correct orientation of the pushpull direction when used on groups and components, as signaled by CadFather (see this post). You also need to upgrade LibFredo6 to v8.1c.
          JointPushPull 4.3e requires LibFredo6 8.1c or above
          • fredo6F Offline
            NEW RELEASE: JointPushPull Interactive v4.3f - 02 Mar 18
            JointPushPull Interactive 4.3f fixes a major bug introduced in v4.3e. Thanks for upgrading and sorry for inconvenience[/b].
            JointPushPull 4.3f requires LibFredo6 8.1c or above
            • boofredlayB Offline
              boofredlay
              I tried a few times to install 4.3f and get this error each time.
              I have LibFredo6 8.1c installed.
              • HornOxxH Offline
                HornOxx
                ... if interested and not yet known or seen so far, TheSketchUpEssentials has recently posted a pretty good and worth seeing video about this tool with the mysterious title "8 SECRET FUNCTIONS of the SketchUp Joint Push Pull Extension" 😄 on YouTube
                https://www.youtube.com/watch?v=wOl9qQXwwbw&t=210s
                never trust a skinny cook
                • fredo6F Offline
                  Very strange! How do you install it
                  • from the Sketchup RBZ installer
                  • from the Sketchucation PluginStore?
                    boofredlay
                    I downloaded it from here:
                    https://sketchucation.com/plugin/715-jointpushpull
                    I try installing through the Extension Manager
                    Click image to see the gif.
                      FYI
                      I have successfully installed this version's using the PluginStore's downloaded RBZ, using the native Extension Manager's red-button, in both v2017 & v2018, on both PC & MAC.
                      I have also successfully installed it using the SketchUcation ExtensionStore³ dialog's 'AutoInstall' red-button, again in both of those SketchUp versions and OSs.
                      I also pre-installed the latest LibFredo6 in those 4 permutations...
                        boofredlay
                        Hm, odd.
                        I have not had this issue before. I installed each update you have put up the past week as well.
                        I get the same error trying to install in 2017 through the Extension Manager also. Must be something on my end although I don't know what. Restarting my computer did not solve it.
                        I have never tried the installing through the Sketchucation PluginStore.
                          boofredlay
                          -Solved-
                          Well this is even more strange. It was definitely an issue on my end.
                          I went to try it again just now, after about a half hour of trying it last time, and the extension was not in the folder I saved it in. It was just gone. I am assuming it is an issue with our server profile here at work as we have seen files disappear before. I also assume on my previous attempts to install this plugin that the server was showing the file but it was not actually there. Not sure.
                          Anyway, I downloaded a fresh .rbz and it installed just fine.
                          Sorry for the uproar.
                          • fredo6F Offline
                            Good for you.
                            It's anyway good to know this case, as it may happen to someone else, including when try to open a skp file.
                              SnakeDog
                              Thanks for creating these awesome tools! i just tried the JPP "project on a plane" trick on some topo i created and I'm getting a Ruby Error. it says "Error in generation of the geometry" and "Not enough points - at least 3 required". Any Idea what is going on?
                              -thanks
                              • fredo6F Offline
                                -thanks
                                I would need to get the model, and also have the full text of the error message.
                                  thelorax4
                                  I used to use this tool extensively to create curbs from complicated terrain, and it worked almost perfectly. The new version, however, with all it's options, no longer has a tool for extruding in z axis, which baffles me. Does anyone know if there's a variable that can be changed in settings to fix this, or know of another tool to achieve the same effect?
                                  • fredo6F Offline
                                    Could you show a sample of model to illustrate your problem.
                                      jwhida
                                      Hi FREDO,
                                      This plugin is sooo good. Thankyou. Donation on its way.
                                      There is one quirk that i dont understand and makes the plugin unuseful when dealing with 'group copies'
                                      If editing a group of which copies have been made, all group copies are also affected. I'd expect this behaviour only for components not groups.
                                      The behaviour id expect is that if i joint push pull a face of a group, that only that group is modified, not every other instance.
                                      Have I overlooked some setting to turn this behaviour off ?
                                      Cheers
                                      John
                                      • fredo6F Offline
                                        I'll probably have to fix this general issue, not just for JPP, which comes from a side effect of Sketchup (freshly copied groups behave as components until they are edited, for optimization).
                                        In the meantime, I would suggest that you go inside the group to do the Joint Push Pull, as you would do for the native Push Pull. The capability to operate across boundaries of group and components is just a convenience.
                                          jwhida
                                          Ok that makes sense, i was aware of that optimisation of the group definition.
                                          I'll happily edit from within the group for now, but definitely look forward to an option to treat group copies as individual groups when using joint push pull when you get time to implement it.
                                          Thanks 😄
                                          • E Offline
                                            Einstein
                                            Hi!
                                            I caught a bug. Here it is:
                                            I extruded several connected faces with JPP and choose the option which removes source faces, leaving only extrusion. I confirmed the extrusion and then did UNDO. Unfortunately undoing can't be done in one go. Instead, it's "broken" into small steps and it brings back my source geometry edge by edge so I have to press UNDO many times.
                                            It happens with every sub-tool of JPP.
                                            I'm using SU17 with newest JPP and newest LibFredo.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 30
                                            • 31
                                            • 16 / 31
