    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • E
      Einstein
      It comes from global X axis. Local is ignored.
      vector pushpull.skp
      • CadFatherC
        CadFather
        had to go back to previous version, as often the pushpull goes the opposite way. can't find the reason but will keep posted if i experiment more with it.
        • fredo6F
          Thanks to elaborate on this, while I am at fixing JPP.
          Is it when you type in the VCB, or when you drag, or when you drag and then use the VCB?
          • CadFatherC
            CadFather
            just when i drag - typing a negative/positive value works as expected
            • fredo6F
              Not clear
              • one particular tool or all tools?
              • if you drag, how does this happen exactly?
              • fredo6F
                NEW RELEASE: JointPushPull Interactive v4.3c - 27 Feb 18
                JointPushPull Interactive 4.3c fixes bugs in the Vector tool, as signaled by Einstein (see this post). You also need to upgrade LibFredo6 to v8.1c.
                JointPushPull 4.3c requires LibFredo6 8.1c or above
                See plugin home page of JointPushPull for Download of JointPushPull.
                Main Post of the JointPushPull thread on this forum
                • CadFatherC
                  CadFather
                  like here, but it happens on others too (ie. follow etc.)
                  • fredo6F
                    Impressive, clearly a bug or a mystery.
                    Could you post the model, so that I try to understand what happens.
                    EDIT: I could reproduce the problem (when the group is upside down). Fixing it. Thanks for signaling.
                    • fredo6F
                      NEW RELEASE: JointPushPull Interactive v4.3d - 27 Feb 18
                      JointPushPull Interactive 4.3d fixes bugs preventing to have a correct orientation of the pushpull direction when used on groups and components, as signaled by Cadather (see this post). You also need to upgrade LibFredo6 to v8.1c.
                      JointPushPull 4.3d requires LibFredo6 8.1c or above
                      • fredo6F
                        NEW RELEASE: JointPushPull Interactive v4.3e - 28 Feb 18
                        JointPushPull Interactive 4.3e fixes remaining bugs preventing to have a correct orientation of the pushpull direction when used on groups and components, as signaled by CadFather (see this post). You also need to upgrade LibFredo6 to v8.1c.
                        JointPushPull 4.3e requires LibFredo6 8.1c or above
                        • fredo6F
                          NEW RELEASE: JointPushPull Interactive v4.3f - 02 Mar 18
                          JointPushPull Interactive 4.3f fixes a major bug introduced in v4.3e. Thanks for upgrading and sorry for inconvenience[/b].
                          JointPushPull 4.3f requires LibFredo6 8.1c or above
                          • boofredlayB
                            boofredlay
                            I tried a few times to install 4.3f and get this error each time.
                            I have LibFredo6 8.1c installed.
                            • HornOxxH
                              HornOxx
                              ... if interested and not yet known or seen so far, TheSketchUpEssentials has recently posted a pretty good and worth seeing video about this tool with the mysterious title "8 SECRET FUNCTIONS of the SketchUp Joint Push Pull Extension" 😄 on YouTube
                              https://www.youtube.com/watch?v=wOl9qQXwwbw&t=210s
                              never trust a skinny cook
                              • fredo6F
                                Very strange! How do you install it
                                • from the Sketchup RBZ installer
                                • from the Sketchucation PluginStore?
                                • boofredlayB
                                  boofredlay
                                  I downloaded it from here:
                                  https://sketchucation.com/plugin/715-jointpushpull
                                  I try installing through the Extension Manager
                                  Click image to see the gif.
                                    FYI
                                    I have successfully installed this version's using the PluginStore's downloaded RBZ, using the native Extension Manager's red-button, in both v2017 & v2018, on both PC & MAC.
                                    I have also successfully installed it using the SketchUcation ExtensionStore³ dialog's 'AutoInstall' red-button, again in both of those SketchUp versions and OSs.
                                    I also pre-installed the latest LibFredo6 in those 4 permutations...
                                    • boofredlayB
                                      boofredlay
                                      Hm, odd.
                                      I have not had this issue before. I installed each update you have put up the past week as well.
                                      I get the same error trying to install in 2017 through the Extension Manager also. Must be something on my end although I don't know what. Restarting my computer did not solve it.
                                      I have never tried the installing through the Sketchucation PluginStore.
                                      • boofredlayB
                                        boofredlay
                                        -Solved-
                                        Well this is even more strange. It was definitely an issue on my end.
                                        I went to try it again just now, after about a half hour of trying it last time, and the extension was not in the folder I saved it in. It was just gone. I am assuming it is an issue with our server profile here at work as we have seen files disappear before. I also assume on my previous attempts to install this plugin that the server was showing the file but it was not actually there. Not sure.
                                        Anyway, I downloaded a fresh .rbz and it installed just fine.
                                        Sorry for the uproar.
                                        • fredo6F
                                          Good for you.
                                          It's anyway good to know this case, as it may happen to someone else, including when try to open a skp file.
                                            SnakeDog
                                            Thanks for creating these awesome tools! i just tried the JPP "project on a plane" trick on some topo i created and I'm getting a Ruby Error. it says "Error in generation of the geometry" and "Not enough points - at least 3 required". Any Idea what is going on?
                                            -thanks
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 30
                                            • 31
                                            • 16 / 31
