    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 951.1k Views 155 Watching
    • CadFatherC
      CadFather
      just when i drag - typing a negative/positive value works as expected
      • fredo6F
        Not clear
        • one particular tool or all tools?
        • if you drag, how does this happen exactly?
        • fredo6F
          NEW RELEASE: JointPushPull Interactive v4.3c - 27 Feb 18
          JointPushPull Interactive 4.3c fixes bugs in the Vector tool, as signaled by Einstein (see this post). You also need to upgrade LibFredo6 to v8.1c.
          JointPushPull 4.3c requires LibFredo6 8.1c or above
          See plugin home page of JointPushPull for Download of JointPushPull.
          Main Post of the JointPushPull thread on this forum
          • CadFatherC
            CadFather
            like here, but it happens on others too (ie. follow etc.)
            • fredo6F
              Impressive, clearly a bug or a mystery.
              Could you post the model, so that I try to understand what happens.
              EDIT: I could reproduce the problem (when the group is upside down). Fixing it. Thanks for signaling.
              • fredo6F
                NEW RELEASE: JointPushPull Interactive v4.3d - 27 Feb 18
                JointPushPull Interactive 4.3d fixes bugs preventing to have a correct orientation of the pushpull direction when used on groups and components, as signaled by Cadather (see this post). You also need to upgrade LibFredo6 to v8.1c.
                JointPushPull 4.3d requires LibFredo6 8.1c or above
                • fredo6F
                  NEW RELEASE: JointPushPull Interactive v4.3e - 28 Feb 18
                  JointPushPull Interactive 4.3e fixes remaining bugs preventing to have a correct orientation of the pushpull direction when used on groups and components, as signaled by CadFather (see this post). You also need to upgrade LibFredo6 to v8.1c.
                  JointPushPull 4.3e requires LibFredo6 8.1c or above
                  • fredo6F
                    NEW RELEASE: JointPushPull Interactive v4.3f - 02 Mar 18
                    JointPushPull Interactive 4.3f fixes a major bug introduced in v4.3e. Thanks for upgrading and sorry for inconvenience[/b].
                    JointPushPull 4.3f requires LibFredo6 8.1c or above
                    • boofredlayB
                      boofredlay
                      I tried a few times to install 4.3f and get this error each time.
                      I have LibFredo6 8.1c installed.
                      • HornOxxH
                        HornOxx
                        ... if interested and not yet known or seen so far, TheSketchUpEssentials has recently posted a pretty good and worth seeing video about this tool with the mysterious title "8 SECRET FUNCTIONS of the SketchUp Joint Push Pull Extension" 😄 on YouTube
                        https://www.youtube.com/watch?v=wOl9qQXwwbw&t=210s
                        never trust a skinny cook
                        • fredo6F
                          Very strange! How do you install it
                          • from the Sketchup RBZ installer
                          • from the Sketchucation PluginStore?
                          • boofredlayB
                            boofredlay
                            I downloaded it from here:
                            https://sketchucation.com/plugin/715-jointpushpull
                            I try installing through the Extension Manager
                            Click image to see the gif.
                              FYI
                              I have successfully installed this version's using the PluginStore's downloaded RBZ, using the native Extension Manager's red-button, in both v2017 & v2018, on both PC & MAC.
                              I have also successfully installed it using the SketchUcation ExtensionStore³ dialog's 'AutoInstall' red-button, again in both of those SketchUp versions and OSs.
                              I also pre-installed the latest LibFredo6 in those 4 permutations...
                              • boofredlayB
                                boofredlay
                                Hm, odd.
                                I have not had this issue before. I installed each update you have put up the past week as well.
                                I get the same error trying to install in 2017 through the Extension Manager also. Must be something on my end although I don't know what. Restarting my computer did not solve it.
                                I have never tried the installing through the Sketchucation PluginStore.
                                • boofredlayB
                                  boofredlay
                                  -Solved-
                                  Well this is even more strange. It was definitely an issue on my end.
                                  I went to try it again just now, after about a half hour of trying it last time, and the extension was not in the folder I saved it in. It was just gone. I am assuming it is an issue with our server profile here at work as we have seen files disappear before. I also assume on my previous attempts to install this plugin that the server was showing the file but it was not actually there. Not sure.
                                  Anyway, I downloaded a fresh .rbz and it installed just fine.
                                  Sorry for the uproar.
                                  • fredo6F
                                    Good for you.
                                    It's anyway good to know this case, as it may happen to someone else, including when try to open a skp file.
                                      SnakeDog
                                      Thanks for creating these awesome tools! i just tried the JPP "project on a plane" trick on some topo i created and I'm getting a Ruby Error. it says "Error in generation of the geometry" and "Not enough points - at least 3 required". Any Idea what is going on?
                                      -thanks
                                      • fredo6F
                                        -thanks
                                        I would need to get the model, and also have the full text of the error message.
                                        • T
                                          thelorax4
                                          I used to use this tool extensively to create curbs from complicated terrain, and it worked almost perfectly. The new version, however, with all it's options, no longer has a tool for extruding in z axis, which baffles me. Does anyone know if there's a variable that can be changed in settings to fix this, or know of another tool to achieve the same effect?
                                          • fredo6F
                                            Could you show a sample of model to illustrate your problem.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 30
                                            • 31
                                            • 16 / 31
