    [Plugin][$] JointPushPull Interactive - v4.9a - 02 Apr 25
    619 Posts 156 Posters 971.2k Views 155 Watching
    • fredo6F
      @einstein said:
      Perhaps it's my misunderstanding but it still goes along global, no local
      How did you set the X direction: via keyboard or clicking on the palette button?
      • E
        Einstein
        Tried both with the same result.
        • fredo6F
          Could you post your model, because I don't see where this weird direction in red comes from.
          • E
            Einstein
            It comes from global X axis. Local is ignored.
            vector pushpull.skp
            • CadFatherC
              CadFather
              had to go back to previous version, as often the pushpull goes the opposite way. can't find the reason but will keep posted if i experiment more with it.
              • fredo6F
                Thanks to elaborate on this, while I am at fixing JPP.
                Is it when you type in the VCB, or when you drag, or when you drag and then use the VCB?
                • CadFatherC
                  CadFather
                  just when i drag - typing a negative/positive value works as expected
                  • fredo6F
                    Not clear
                    • one particular tool or all tools?
                    • if you drag, how does this happen exactly?
                    • fredo6F
                      NEW RELEASE: JointPushPull Interactive v4.3c - 27 Feb 18
                      JointPushPull Interactive 4.3c fixes bugs in the Vector tool, as signaled by Einstein (see this post). You also need to upgrade LibFredo6 to v8.1c.
                      JointPushPull 4.3c requires LibFredo6 8.1c or above
                      See plugin home page of JointPushPull for Download of JointPushPull.
                      Main Post of the JointPushPull thread on this forum
                      • CadFatherC
                        CadFather
                        like here, but it happens on others too (ie. follow etc.)
                        • fredo6F
                          Impressive, clearly a bug or a mystery.
                          Could you post the model, so that I try to understand what happens.
                          EDIT: I could reproduce the problem (when the group is upside down). Fixing it. Thanks for signaling.
                          • fredo6F
                            NEW RELEASE: JointPushPull Interactive v4.3d - 27 Feb 18
                            JointPushPull Interactive 4.3d fixes bugs preventing to have a correct orientation of the pushpull direction when used on groups and components, as signaled by Cadather (see this post). You also need to upgrade LibFredo6 to v8.1c.
                            JointPushPull 4.3d requires LibFredo6 8.1c or above
                            • fredo6F
                              NEW RELEASE: JointPushPull Interactive v4.3e - 28 Feb 18
                              JointPushPull Interactive 4.3e fixes remaining bugs preventing to have a correct orientation of the pushpull direction when used on groups and components, as signaled by CadFather (see this post). You also need to upgrade LibFredo6 to v8.1c.
                              JointPushPull 4.3e requires LibFredo6 8.1c or above
                              • fredo6F
                                NEW RELEASE: JointPushPull Interactive v4.3f - 02 Mar 18
                                JointPushPull Interactive 4.3f fixes a major bug introduced in v4.3e. Thanks for upgrading and sorry for inconvenience[/b].
                                JointPushPull 4.3f requires LibFredo6 8.1c or above
                                • boofredlayB
                                  boofredlay
                                  I tried a few times to install 4.3f and get this error each time.
                                  I have LibFredo6 8.1c installed.
                                  • HornOxxH
                                    HornOxx
                                    ... if interested and not yet known or seen so far, TheSketchUpEssentials has recently posted a pretty good and worth seeing video about this tool with the mysterious title "8 SECRET FUNCTIONS of the SketchUp Joint Push Pull Extension" 😄 on YouTube
                                    https://www.youtube.com/watch?v=wOl9qQXwwbw&t=210s
                                    never trust a skinny cook
                                    • fredo6F
                                      Very strange! How do you install it
                                      • from the Sketchup RBZ installer
                                      • from the Sketchucation PluginStore?
                                      • boofredlayB
                                        boofredlay
                                        I downloaded it from here:
                                        https://sketchucation.com/plugin/715-jointpushpull
                                        I try installing through the Extension Manager
                                        Click image to see the gif.
                                          FYI
                                          I have successfully installed this version's using the PluginStore's downloaded RBZ, using the native Extension Manager's red-button, in both v2017 & v2018, on both PC & MAC.
                                          I have also successfully installed it using the SketchUcation ExtensionStore³ dialog's 'AutoInstall' red-button, again in both of those SketchUp versions and OSs.
                                          I also pre-installed the latest LibFredo6 in those 4 permutations...
                                          • boofredlayB
                                            boofredlay
                                            Hm, odd.
                                            I have not had this issue before. I installed each update you have put up the past week as well.
                                            I get the same error trying to install in 2017 through the Extension Manager also. Must be something on my end although I don't know what. Restarting my computer did not solve it.
                                            I have never tried the installing through the Sketchucation PluginStore.
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 30
                                            • 31
                                            • 16 / 31
