    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 271.7k Views 135 Watching
    • E Offline
      Ecuadorian
      I've just spent one hour asking myself why I could not copy-paste from an old SKP file to a new SKP file with a newly imported AutoCAD drawing. I run SketchUp's checkup, GPU-Z, Repaired SketchUp, reinstalled SketchUp... Nothing. Until I remembered these guys send me the AutoCAD drawings in milimeters instead of meters, but I imported it as meters... So the new drawing was gigantic and anything I copy-pasted from the old file was just too tiny to be seen.
      -Miguel Lescano
        Why not use the "Zoom Extended" in a new file ? ๐Ÿ˜ฎ ๐Ÿ˜„
          rv1974
          Today Penny has Dropped:
          XnView is way better BP2 library explorer then a built-in one.
          As well I use XnView as Component explorer for years now. Excellent with 2nd disply + drag'n'drop.
            Sleipnir
            New to this program, looking for a good extension for cabinet building and or wood working draw up.
            Odin's Favorite Eight Legged Horse'
              Super Doh of the day! Thanks Dave! ๐Ÿ‘
              The arc Circle "Knife"! Make a Double Click at the end of the Arc Drawing! ๐Ÿค“
              Excellent! ๐Ÿ˜Ž โ˜€
              Never made the Double Click! (just simple click: as it was not writed on the bottom help line! ๐Ÿ˜ณ
              And I surrely missed it on the manual! ๐Ÿ˜ณ
              Animation by Dave
              https://sketchucation.com/forums/download/file.php?id=148790&mode=view/rokbox.jpg
                You probably missed this, too. If you want to place the same radius on other corners, double click near them.
                Click on pic if it doesn't move.
                  Very cool! โ˜€ ๐Ÿ‘
                  I suppose I am not the only one! ๐Ÿ’š
                    kaas
                    I don't know if this is a new feature but I was pleasantly surprised to learn about it:
                    In the 3dWarehouse, select a model, look at the statistics in the panel on the right, if you hover / click on a tag (materials/components) you can import just one of those elements instead of the whole model.
                    Great feature if you just need 1 material of 1 element from a collection.
                    • boofredlayB Offline
                      boofredlay
                      https://media.giphy.com/media/EldfH1VJdbrwY/giphy.gif
                      • HornOxxH Offline
                        HornOxx
                        @pilou said:
                        ...I suppose I am not the only one! ๐Ÿ’š
                        ๐Ÿ˜„ ๐Ÿ˜„ I'm also a member of this unsuspecting club...
                        never trust a skinny cook
                          rv1974
                          At last we have a fastest\easiest tool for ramps/stairs/roads!
                          Check s4u Stair() in Plugin Store.
                          Absolutely worth every penny.
                          โ˜€
                            Thank you, thank you, thank you!
                            • david_hD Offline
                              david_h
                              I know I should know this (being a top sketchukator and all--- ๐Ÿ’š Yeah, I am having a hard time containing my laughter too. . .)but as I said. .I know I should know this but I don't:
                              as I go between scenes with sections how can I toggle between them and keep the section plane window off so I dont have to manually turn them off each time? I have always found the scene menu in SU very confusing and conveluted and I can't seem to get this to work as I want. Help please? Thanks.
                              David_H
                                David, you can access them in the Outliner. Right click on the desired section cut in Outliner and activate it or deactivate as needed.
                                • david_hD Offline
                                  david_h
                                  Dave. . thanks for the response and please excuse the follow up. . . I guess I'm not following, or i didn't make my question clear and I don't use outliiner that much. . .is there a way to save the scene updates so that the windows just stay off? I don't see how Outline does that for me.
                                  Thx,
                                  D
                                  • david_hD Offline
                                    david_h
                                    Never mind. .. I think I got it. I just update after the outliner thing. Correct?
                                    Thx,
                                    D
                                      Oh. Sorry. I didn't get that part. The display of section planes is a style setting thing so edit the style to turn them off, update the style and update the scenes.
                                      Actually, if you edit the style and then update the scene, you should get a warning that tells you the style has been edited and asking if you want to update the style or create a new one.
                                      • david_hD Offline
                                        david_h
                                        Thank you! it's really quite amazing how much of the basic stuff you forget when you don't dealwith it that often.
                                        D
                                          Yes it is amazing indeed.
                                          And it shows how deep SketchUp can be.
                                            rv1974
                                            Curic Extend is amazing!
                                            https://gumroad.com/curic
                                            50% discount code:
                                            10k followers
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 34
                                            • 35
                                            • 29 / 35
