    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 579.6k Views 135 Watching
      Very cool! β˜€ πŸ‘
      I suppose I am not the only one! πŸ’š
      • K
        kaas
        I don't know if this is a new feature but I was pleasantly surprised to learn about it:
        In the 3dWarehouse, select a model, look at the statistics in the panel on the right, if you hover / click on a tag (materials/components) you can import just one of those elements instead of the whole model.
        Great feature if you just need 1 material of 1 element from a collection.
        • boofredlayB
          boofredlay
          @dave r said:
          You probably missed this, too. If you want to place the same radius on other corners, double click near them.
          https://media.giphy.com/media/EldfH1VJdbrwY/giphy.gif
          • HornOxxH
            HornOxx
            @pilou said:
            ...I suppose I am not the only one! πŸ’š
            πŸ˜„ πŸ˜„ I'm also a member of this unsuspecting club...
            never trust a skinny cook
              rv1974
              At last we have a fastest\easiest tool for ramps/stairs/roads!
              Check s4u Stair() in Plugin Store.
              Absolutely worth every penny.
              β˜€
              • L
                Thank you, thank you, thank you!
                • david_hD
                  david_h
                  I know I should know this (being a top sketchukator and all--- πŸ’š Yeah, I am having a hard time containing my laughter too. . .)but as I said. .I know I should know this but I don't:
                  as I go between scenes with sections how can I toggle between them and keep the section plane window off so I dont have to manually turn them off each time? I have always found the scene menu in SU very confusing and conveluted and I can't seem to get this to work as I want. Help please? Thanks.
                  David_H
                    David, you can access them in the Outliner. Right click on the desired section cut in Outliner and activate it or deactivate as needed.
                    • david_hD
                      david_h
                      Dave. . thanks for the response and please excuse the follow up. . . I guess I'm not following, or i didn't make my question clear and I don't use outliiner that much. . .is there a way to save the scene updates so that the windows just stay off? I don't see how Outline does that for me.
                      Thx,
                      D
                      • david_hD
                        david_h
                        Never mind. .. I think I got it. I just update after the outliner thing. Correct?
                        Thx,
                        D
                          Oh. Sorry. I didn't get that part. The display of section planes is a style setting thing so edit the style to turn them off, update the style and update the scenes.
                          Actually, if you edit the style and then update the scene, you should get a warning that tells you the style has been edited and asking if you want to update the style or create a new one.
                          • david_hD
                            david_h
                            Thank you! it's really quite amazing how much of the basic stuff you forget when you don't dealwith it that often.
                            D
                              Yes it is amazing indeed.
                              And it shows how deep SketchUp can be.
                                rv1974
                                Curic Extend is amazing!
                                https://gumroad.com/curic
                                50% discount code:
                                10k followers
                                  A tool EXTRUDE EDGES BY VECTOR BY tig don't make the same ? πŸ˜‰
                                  http://forum.zbrush.fr/index.php?action=dlattach;topic=1622.0;attach=18111;image
                                    rv1974
                                    no, Curic works with multiple independent objects (groups, components) and\or its faces instantly.
                                    Does Tig's one extrude to a curved object?
                                      Yes.
                                        rv1974
                                        Very good, but once again ability to process multiple objects regardless the context makes night and day difference.
                                          My EE... tool extends selected edges and by connection their faces to any objects in the way of the vector-path, or a picked point on that path - whichever is appropriate. It doesn't process the contents of selected groups etc, so you must edit them and select the geometry to process.
                                          The objects to which it extrudes must include some faces [even if nested inside groups etc] - so curved surfaces are accommodated...
                                          • K
                                            Khai
                                            My biggest Doh!
                                            Struggling with microfaces on a component..
                                            Brain : this is a component!
                                            Me : I know
                                            Brain : no, this is a component, get it?
                                            Me : I know! Will you shuv up?
                                            Brain : idiot. Copy it, enlarge it 500% over there, and then work on it, they won't be microfaces anymore and life will be easy. Pillock.
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 34 / 35
