    SketchUp 2018
    173 Posts 63 Posters 70.7k Views 63 Watching
      @khai said:
      So, urm. Want to save from the free version (on my tablet) to then work on it on my desktop....
      You can upload the model to the 3D Warehouse which will convert it to earlier versions for you.
      • K
        Khai
        I'll pass on that. I don't use the Warehouse anyway so.. No point in adding another step into my hobby flow...
        • K
          Khai
          Oh I and should add. Deal breakers for the Web version...
          Slow. (tried with Chrome and Firefox)
          No Ruby support.
          Save limited. (as above. If I have to upload to a 3rd party, that's a limit)
          • B
            Ben Ritter
            If you upgrade to SU2018 from SU2017, why won't it be possible to have 2017 and 2018 reside on the computer at the same time?
            • jujuJ
              juju
              It works that way already.
              • sketch3d.deS
                sketch3d.de
                @ben ritter said:
                ...why won't it be possible to have 2017 and 2018 reside on the computer at the same time?
                it can and should be installed side-by-side sothat you are able doing a fallback to version 2017 if required because e.g. plugins are not compatible (yet).
                Actually do not deactivate product activations of existing previous versions because they cannot be reactivated after activating SU 2018 again even on the same system! Use the 30 day trial runtime before activating a new version anyhow.
                • B
                  Ben Ritter
                  I'll have to get the exact quote from Trimble, but I didn't upgrade because there was some language stating that 2017 would become inoperative after 30 days. Not sure if anyone else saw this too?
                  • N
                    nickchun
                    @Ken
                    You can change the anti alias settings etc for each program via Windows or your graphics card set up(i.e Nvidia control panel accessed by right clicking on empty screen). Mine appears under 'Manage 3D settings' where you can override each applications 3D settings. I changed mine to 8x, and its much better. There was a thread about it a while ago but as usual I can't find it.
                    • sketch3d.deS
                      sketch3d.de
                      @ben ritter said:
                      ...stating that 2017 would become inoperative after 30 days.
                      meant are additional activations which actually are not possible since day zero now (see above), do not deactivate resp. activate all 2017 program installations before activating version 2018... after the 30 day trial if unsure how rev. 2018 performs.
                      • kimi kimiK
                        kimi kimi
                        I'm waiting for a few developers to join together and make an alternative to SketchUp. I'll pay filthy money for it. Just do it. Make yourself rich. You know what it needs to be.
                        • andybotA
                          andybot
                          True story. Happened to me with 2016 after I installed 2017. Worked fine alongside until later I had to reinstall my OS, and then I couldn't get 2016 activated.
                          • B
                            Bruce Watt
                            Thank you, Trimble, I am happy with Sketchup Pro 2018, keep up the good work.
                            SKUP PRO 2021 latest version / update
                            Windows 10 Pro
                            Dell Alienware Aurora R10 AMD
                            AMD Ryzen™ 9 3900X
                            NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
                            • pbacotP
                              @juju said:
                              Does anyone have the ETA for SketchUp 2018? SU2017 was released 7 November 2016, so I'm guessing any time in the next month probably...
                              Oh. To answer your question. Yes, I happen to know it will be released in November. 😄
                              • pbacotP
                                This may be a "first" on Sketchucation!
                                • utilerU
                                  utiler
                                  Hi SJS, your plugins should work as they did in 2017...
                                  Just Curious...
                                  • chippwaltersC
                                    chippwalters
                                    OK, I now understand there is a focus on trying to get extensions to work in the cloud sometime in the future. I suppose we can expect the whole app (PRO + FREE) to end up in the cloud at some point. If not, then this truly is a waste of valuable developer resources.
                                    Pros
                                    • Eventually when SU Pro goes to the cloud, we’re back to one code base set.
                                    • Nothing to download (except I suspect there will need to be a ‘cached’ app somewhere so when you’re not connected to the cloud you can still do work like GApps.)
                                    • Easy to update all at once.
                                    • Can perhaps run on slower machines as most heavy processing can be done in the cloud (aka OnShape).
                                    • If prefs ever get implemented, it will be nice to have them stored online for all computers.
                                    • No license per computer and no dreaded licensing conundrum Trimble has put us through year after year.
                                    • Makes the Google Chromebooks team happy!
                                    Cons
                                    • Not pipeline or ecosystem friendly. If you can’t quickly save and open the program in a different app. In fact I’m not even sure how to actually download the file. If it’s not as simple as SAVE to FOLDER then it’s a fail for working in any sort of workflow, pipeline or other ecosystem. And because there is no renderer, no animator and other missing items, it’s necessary to go to 3rd parties to get things done.
                                    • By focussing on the cloud, valuable resources are usurped which could be used to actually add some new and needed features. Those resources are now focussed on making the proper frameworks, trying to get existing extensions to play, client-side code, and the whole cloud architecture, among other things.
                                    • Takes a long time to put everything in place-- and meanwhile SketchUp core features keeps getting further and further behind. SU2018 is such an example. It’s more than clear all the dev resources are now focused on the cloud as this is the lamest update I can ever remember.
                                    • Sometimes instant updates create serious problems and if not adequately tested can be very problematic for professionals on a schedule. I hope you consider the ability for customers to roll back to previous versions.
                                    So, instead of finally getting a fillet or chamfer command, or UV mapping (after all it is 2017), or better booleans, or even a decent renderer, we are now watching the programmers spend all their time on trying to figure out load balancing on servers and how to get around the limitations of different browsers.
                                    I sure would’ve like to have been in THAT meeting where the decision was made to allocate major development resources to move the whole codebase to the cloud. Perhaps the decision was made by programmers knowing they need to add significant cloud development capabilities to their resume?
                                    It is more and more apparent to me there is little focus at Trimble on what users need to actually model and render buildings, products, and 3D prints in 2018. There have been very few tools added over the past decade. Yes, I know we all EXPECT the plugin developers to create them for Trimble. Still, even the magnificent Fredo can’t easily build the standard filleting tool every other poly modeler has because of the internal architecture of SU.
                                    Here’s what SketchUp 2 looked like in 2003. Mostly all the same tools. That was 15 years ago!
                                    https://filedn.com/lLMW4jXsJqxXkRYjd1UCoKL/3d/psketchadv.jpg
                                    Yes, I know the original design was a departure from standard vertex poly modelers…and a good one at that. Even so, there are so many ways to make it better. Trimble seems very reluctant to actually add the necessary features, and instead they’ve decided to now spend significant resources towards isolating the program, and it’s users, in the cloud. I’m just wondering if the programmers are actual 3D guys, or former Google Cloud computing developers?
                                    Currently working with Cross-Reality technologies
                                    • masterpaulM
                                      masterpaul
                                      Like Shape? I dunno how its gonna turn out, it's not out yet.
                                      404 Not Found
                                      (aecmag.com)
                                      and there's also
                                      http://www.formz.com/products/formzfree.html
                                      but I never used it.
                                        slbaumgartner
                                        Competition would be good. But I think there are patents that would prevent replicating some of our favorite features such as push-pull. It would be interesting to see what others could come up with.
                                        • G
                                          Glenn at home
                                          Not really, AutoCAD has similar with it's "presspull" command set. As does Fusion 360. Form-Z also has a similar toolset. None are as user friendly as SU but as you said..."competition would be good".
                                          • SJS66S
                                            SJS66
                                            All plugins seem to be working ok so far, although haven't tested all of them yet.
                                            Been having issues with Windows 10 Creators Fall update more so lately. Had to reset my computer twice due to black screen of death.
                                            So now I have Creators Fall updates installed, I've noticed SketchUp backup files (.skb) aren't recognised in Windows 10 explorer now & trying to set SketchUp 2018 as the default program to open files is proving to be a bit tricky. In attached image I've selected .skb file extension but SketchUp 2018 doesn't come up as an option, only "Look for an app in the Store". Tried a few other ways but no luck so far.
                                            Anyone got the same problem? Probably should post as new thread.
                                            • 9 / 9
