    SketchUp 2018
    173 Posts 63 Posters 66.7k Views 63 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      @pixero said:
      If the core code is the same, adding support for extensions to the web version would be possible, right?
      Or does it already have support for extensions built in but not yet exposed?
      No, the Ruby API is not part of the core.
      • SJS66S
        SJS66
        Just downloaded SketchUp 2018 in Oz. Just wondering how my plugins are going to go if I install. Skatter is good apparently, but not sure about any of the others. One way to find out I guess.
        • K
          Khai
          So, urm. Want to save from the free version (on my tablet) to then work on it on my desktop.... And all the "save" does is ask for a login. Oh. It's trimble connect. Erm ok. Where's my file....?
          Oh ok. Free is useless to me then. Nice toy, back to '17 I go
            You can upload the model to the 3D Warehouse which will convert it to earlier versions for you.
            • K
              Khai
              I'll pass on that. I don't use the Warehouse anyway so.. No point in adding another step into my hobby flow...
              • K
                Khai
                Oh I and should add. Deal breakers for the Web version...
                Slow. (tried with Chrome and Firefox)
                No Ruby support.
                Save limited. (as above. If I have to upload to a 3rd party, that's a limit)
                • B
                  Ben Ritter
                  If you upgrade to SU2018 from SU2017, why won't it be possible to have 2017 and 2018 reside on the computer at the same time?
                  • jujuJ
                    juju
                    It works that way already.
                    • sketch3d.deS
                      sketch3d.de
                      @ben ritter said:
                      ...why won't it be possible to have 2017 and 2018 reside on the computer at the same time?
                      it can and should be installed side-by-side sothat you are able doing a fallback to version 2017 if required because e.g. plugins are not compatible (yet).
                      Actually do not deactivate product activations of existing previous versions because they cannot be reactivated after activating SU 2018 again even on the same system! Use the 30 day trial runtime before activating a new version anyhow.
                      • B
                        Ben Ritter
                        I'll have to get the exact quote from Trimble, but I didn't upgrade because there was some language stating that 2017 would become inoperative after 30 days. Not sure if anyone else saw this too?
                        • N
                          nickchun
                          @Ken
                          You can change the anti alias settings etc for each program via Windows or your graphics card set up(i.e Nvidia control panel accessed by right clicking on empty screen). Mine appears under 'Manage 3D settings' where you can override each applications 3D settings. I changed mine to 8x, and its much better. There was a thread about it a while ago but as usual I can't find it.
                          • sketch3d.deS
                            sketch3d.de
                            @ben ritter said:
                            ...stating that 2017 would become inoperative after 30 days.
                            meant are additional activations which actually are not possible since day zero now (see above), do not deactivate resp. activate all 2017 program installations before activating version 2018... after the 30 day trial if unsure how rev. 2018 performs.
                            • kimi kimiK
                              kimi kimi
                              I'm waiting for a few developers to join together and make an alternative to SketchUp. I'll pay filthy money for it. Just do it. Make yourself rich. You know what it needs to be.
                              • andybotA
                                andybot
                                True story. Happened to me with 2016 after I installed 2017. Worked fine alongside until later I had to reinstall my OS, and then I couldn't get 2016 activated.
                                • B
                                  Bruce Watt
                                  Thank you, Trimble, I am happy with Sketchup Pro 2018, keep up the good work.
                                  SKUP PRO 2021 latest version / update
                                  Windows 10 Pro
                                  Dell Alienware Aurora R10 AMD
                                  AMD Ryzen™ 9 3900X
                                  NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
                                  • pbacotP
                                    @juju said:
                                    Does anyone have the ETA for SketchUp 2018? SU2017 was released 7 November 2016, so I'm guessing any time in the next month probably...
                                    Oh. To answer your question. Yes, I happen to know it will be released in November. 😄
                                    • pbacotP
                                      This may be a "first" on Sketchucation!
                                      • utilerU
                                        utiler
                                        Hi SJS, your plugins should work as they did in 2017...
                                        Just Curious...
                                        • chippwaltersC
                                          chippwalters
                                          OK, I now understand there is a focus on trying to get extensions to work in the cloud sometime in the future. I suppose we can expect the whole app (PRO + FREE) to end up in the cloud at some point. If not, then this truly is a waste of valuable developer resources.
                                          Pros
                                          • Eventually when SU Pro goes to the cloud, we’re back to one code base set.
                                          • Nothing to download (except I suspect there will need to be a ‘cached’ app somewhere so when you’re not connected to the cloud you can still do work like GApps.)
                                          • Easy to update all at once.
                                          • Can perhaps run on slower machines as most heavy processing can be done in the cloud (aka OnShape).
                                          • If prefs ever get implemented, it will be nice to have them stored online for all computers.
                                          • No license per computer and no dreaded licensing conundrum Trimble has put us through year after year.
                                          • Makes the Google Chromebooks team happy!
                                          Cons
                                          • Not pipeline or ecosystem friendly. If you can’t quickly save and open the program in a different app. In fact I’m not even sure how to actually download the file. If it’s not as simple as SAVE to FOLDER then it’s a fail for working in any sort of workflow, pipeline or other ecosystem. And because there is no renderer, no animator and other missing items, it’s necessary to go to 3rd parties to get things done.
                                          • By focussing on the cloud, valuable resources are usurped which could be used to actually add some new and needed features. Those resources are now focussed on making the proper frameworks, trying to get existing extensions to play, client-side code, and the whole cloud architecture, among other things.
                                          • Takes a long time to put everything in place-- and meanwhile SketchUp core features keeps getting further and further behind. SU2018 is such an example. It’s more than clear all the dev resources are now focused on the cloud as this is the lamest update I can ever remember.
                                          • Sometimes instant updates create serious problems and if not adequately tested can be very problematic for professionals on a schedule. I hope you consider the ability for customers to roll back to previous versions.
                                          So, instead of finally getting a fillet or chamfer command, or UV mapping (after all it is 2017), or better booleans, or even a decent renderer, we are now watching the programmers spend all their time on trying to figure out load balancing on servers and how to get around the limitations of different browsers.
                                          I sure would’ve like to have been in THAT meeting where the decision was made to allocate major development resources to move the whole codebase to the cloud. Perhaps the decision was made by programmers knowing they need to add significant cloud development capabilities to their resume?
                                          It is more and more apparent to me there is little focus at Trimble on what users need to actually model and render buildings, products, and 3D prints in 2018. There have been very few tools added over the past decade. Yes, I know we all EXPECT the plugin developers to create them for Trimble. Still, even the magnificent Fredo can’t easily build the standard filleting tool every other poly modeler has because of the internal architecture of SU.
                                          Here’s what SketchUp 2 looked like in 2003. Mostly all the same tools. That was 15 years ago!
                                          https://filedn.com/lLMW4jXsJqxXkRYjd1UCoKL/3d/psketchadv.jpg
                                          Yes, I know the original design was a departure from standard vertex poly modelers…and a good one at that. Even so, there are so many ways to make it better. Trimble seems very reluctant to actually add the necessary features, and instead they’ve decided to now spend significant resources towards isolating the program, and it’s users, in the cloud. I’m just wondering if the programmers are actual 3D guys, or former Google Cloud computing developers?
                                          Currently working with Cross-Reality technologies
                                          • masterpaulM
                                            masterpaul
                                            Like Shape? I dunno how its gonna turn out, it's not out yet.
                                            404 Not Found
                                            (aecmag.com)
                                            and there's also
                                            http://www.formz.com/products/formzfree.html
                                            but I never used it.
                                            • 8 / 9
