    [Plugin][$] TopoShaper - v2.7b - 30 Jan 26
    460 Posts 145 Posters 905.0k Views 144 Watching
    • john2J
      john2
      @tig said:
      Have you also installed the very latest LibFredo ?
      Yes
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
        Have you re-launched SketchUp ?
        • john2J
          john2
          Yes. Every time I start sketchup, I am getting this dialogue box.
            Is the LibFredo activated in the Extension Manager dialog ?
            • john2J
              john2
              I am using Sketchup 2016 version. The libfredo is activated and I see a tick mark right next to its name in the list which I accessed by going to System preferences>extensions
              • fredo6F
                I think the best would be to have a snapshot of your Sketchup Plugins Directory. It looks like there is an old LibFredo6 somewhere.
                • fredo6F
                  WARNING: Potential issues in TopoShaper (IsoContour) with LibFredo6 7.7d.
                  I will publish a fix in LibFredo6 v7.7e as soon as the Extension Ware House site works again.
                  • H
                    hiryfi
                    Greetings,
                    I am a extreme beginner with SU and am trying to use toposhaper to generate a topo of a piece of land I recently purchased. Reading, researching, and a lot of trial and error!
                    I am using previous survey data and septic design plans to do this. I have a .txt file with 144 points of xyz data. I imported that into SU with point gadget in a .csv file and have all the points imported. My problem is getting toposhaper to accept the points. I either get a I have tried to install toposhaper with libfredo6_v7.7e prior multiple times with no luck. I could not find the auto-installer and have installed via the extension manager. I'm sure I am screwing something up, just can't pinpoint what I am doing wrong. Any tips are much appreciated. I will continue to search through the libfredo post as well. I have attached my data and some screen shots of the messages I am generating. I see others have had similar issues so I'm sure its some user issue on my end.
                    I am using SU Make 2017, Windows 7
                    Thanks,
                    hiryfi
                    Lot 19S Topo 7.25.15 (1).txt
                    pdf given from data, firm would not give .dwg due to liability.
                    LibFredo6Trace_17_1506099534865.txt
                    SU17
                    Very Green
                    • fredo6F
                      @hiryfi
                      From the trace, it seems you have installed LibFredo6, TopoShaper (and FredoTools) correctly. Can you confirm?
                      For generating a terrain from the point cloud, Toposhaper requires that the points are
                      • Construction point (Guide Point in Sketchup), positioned at their altitude.
                      • all enclosed within a group
                      • If you add one or several faces within the group, they will delimit the boundary of the terrain by projection.
                      There are tools to import point clouds from CSV or TXT file (one by Didier Bur and one by TIG), I think.
                      Also, have a look at the videos in the first post of this thread for TopoShaper generation of terrain from point clouds.
                      • H
                        hiryfi
                        @fredo
                        Thanks for the help, I used a different importer from TIG and yielded much better results. I made a small donation to your paypal on 9/22 for your time and wonderfully narrated videos on TopoShaper.
                        Cheers,
                        hiryfi
                        SU17
                        Very Green
                          Slagothoric
                          Thank you for this wonderful plugin. I do have a question about the cell sizes. Is there a way to increase the cell size beyond 200? The current contour profiles that I'm using is set at 2 foot intervals. Unfortunately for the size of the profiles, the 200 limit on cell sizes is producing a less than desirable resolution for the entire map. I will gladly donate as this is an exceptional tool, but could you provide guidance or suggestions on any way to increase the cell size limit. Thank you in advance and kind regards.
                          • fredo6F
                            NEW RELEASE: TopoShaper v2.3b - 06 Dec 17
                            This is a minor release with an increase of the grid resolution for the Contour tool
                            • up to 200 by Default
                            • up to 2000, by changing in the Default Parameters dialog box
                            • fredo6F
                              @slagothoric
                              The purpose of TopShaper is to smooth the terrain to a grid. so this is why a too detailed grid is usually not necessary. In addition, the algorithm is quite greedy, so oversampling the grid may lead to very long computation times.
                              Anyway, I just published a new version, TopoShaper (v2.3b), where the default maximum value for the grid resolution an be increased up to 2000, by going to the Default Parameters box of TopoShaper (default is still 200). But be prepared to have a long coffee break...!
                              • pbacotP
                                Nice! Thanks Fredo!
                                  Slagothoric
                                  Fredo, thank you so much for addressing my issue. That is truly some amazing support. Please include your preferred link and I will gladly donate for your efforts!
                                    @slagothoric said:
                                    ...Please include your preferred link and I will gladly donate for your efforts!
                                    Many authors provide a 'Donate' link-button [yellow] on their PluginStore entries listings...
                                    • E
                                      edarchm2
                                      where ccan i download it?#
                                      • fredo6F
                                        You can download the RBZ at https://sketchucation.com/pluginstore?pln=TopoShaper
                                        Note that you need to install also the companion library LibFredo6.
                                        Otherwise, the best is to install the Sketchucation ExtensionStore plugin and then auto-install TopoShaper and any of the 800 plugins in the store in one click.
                                          rv1974
                                          Hi Fredo,
                                          *) How do I solve 'needle eye' obstacle (see attached)? Plugin get stuck at this stage forever.
                                          *) Second very primitive mesh crashes on generating. Could you take a look at this example?
                                          P.S. I always had scruples to ask, What is purpose of this 2nd 'zoomed' mesh in beige square?
                                          Untitled.skp
                                          • fredo6F
                                            @rv1974 said:
                                            Hi Fredo,
                                            Your models seems 'unprepared' for TopoShaper. I don't see contour lines, but instead lot of edges with intersections and different altitudes.
                                            The blocking on Needle Eye is actually just a Ruby error due to the convoluted configuration of contours, but even if I fixed it, I don't see how you can generate a terrain from your input data.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 22
                                            • 23
                                            • 13 / 23
