    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • ntxdaveN
      ntxdave
      Very interesting textures...........
      Press F1...thank me later
      • N
        nlipovac
        In render? πŸ’š
        After modeling it I did not have any will left. 😳
        • tuna1957T
          tuna1957
          nlipovac, great job. hard to believe it's your first try at an upholstered chair. πŸ‘
          • N
            nlipovac
            Thank you Tuna1957, but this is not my first try, it is my first successful finished armchair model. 😎
            I have over 20 models that I start and never finished and on all occasions, i lost my temper and aborted them (with a lot of screaming and swearing). πŸ˜• 😳
              @nlipovac said:
              Unfinished models are good practice! You try things you normally wouldn't attempt in these unfinished projects.
              Eventually, all the unfinished practice yields benefits like the chair you shared. Really goo model πŸ‘
              • N
                nlipovac
                Thanks, Rich.
                I know, I even started learning Blender to get some solid knowledge on Subdivision.
                I do have some more furniture models I would like to model myself so we will see how that will go. πŸ’š
                • Collage ArchitectureC
                  @nlipovac said:
                  Thanks, Rich.
                  Your model and render looks quite nice!
                  Thanks for sharing!
                  I love Sketchup
                  • BoxB
                    This was a 10 min model to help someone in another forum.
                    Thought I would throw it in here if anyone wants to use it as something to start from and see what you can make of it.
                    http://i.imgur.com/HoKgPG6.gif
                    SUbD CartoonMan.skp
                      Is it a self-portrait?
                      • BoxB
                        Almost Rich, but only from the neck up.
                          here's a raygun model i was doodling with last week.
                          now to finish texturing it...
                          • BoxB
                            Do you call it Ronald?
                            Very nice by the way.
                              No, I call it Ben. When you pull the trigger it over reacts. πŸ˜›
                              • BoxB
                                Good old Ben Gun, Treasure Island I think?
                                • C
                                  Charlie__V
                                  Thanks Box,
                                  You inspired me to at least try: SubD...Vertex tools & Quad face tools.
                                  I think I made a sufficient mess of your cartoon man.(see Non-SubD .skp)
                                  I learned enough today, to know I need to research some more, before learning/forming any really bad habits.
                                  Best regards,
                                  Charlie
                                  PS/FYI...SubD file too large to upload
                                  Non SubD due to file limit
                                  • andybotA
                                    andybot
                                    [attachment=0:2glttolj]<!-- ia0 -->Substance Painter_2017-07-14_21-32-24.png<!-- ia0 -->[/attachment:2glttolj]
                                    That's rendered in Sketchup, Thea? Texturing looks sweet, I gotta try out substance painter.
                                    • StinkieS
                                      Stinkie
                                      Me too.
                                        That direct in the Substance Painter viewport. If you're half thinking of adding SP to your workflow don't waste time procrastinating it. Dive in. Best decision I ever made.
                                        The reason WrapR got kickstarted. SketchUp needed a better way to get UVs.
                                        • C
                                          Carto
                                          Hello Rich,
                                          Just a quick FYI...Substance Painter and associated software is on sale. That being said would you recommend just Painter or the entire Substance Pack?
                                          Regards
                                          • JQLJ
                                            JQL
                                            Painter is used to directly paint materials (colors, height, roughness, normal, etc...) into a correctly UV unwrap mesh. You can also use ready made materials, with special effects that are affected by the shape of your mesh. You can also import textures and paint your mesh and there are other more advanced options. It's incredibly powerful at that but it really requires a UV unwrapped mesh without it it won't work.
                                            Designer is a material creation sofware that is also capable of texture your model. You can create materials procedurally or based on images, you can combine materials and texture your model. You can also apply effects that react to your model's geometry but you cannot handpaint your model.
                                            The materials used in painter are created with designer, but designer allows you to create materials for any software that uses bitmap textures for materials.
                                            Bitmap to Material is a very very "simplified version of Designer" where you can create materials from base textures for any render engine or software.
                                            Without knowing what you do, Rich cannot recommend any of the above. I would recommend designer for people that use sketchup and render software for stuff like architecture where you need to create materials even if you will eventually texture some of it using UV unwrap meshes.
                                            I would recommend painter for people that use sketchup for isolated objects as it's more likely that they are able to UV unwrap them. If you know that your texture process will eventually lead you to a UV unwrapped mesh, painter is definetelly worth it as you can see in the raygun above.
                                            I would recommend Bitmap to Material for people that will only search for images and convert them to materials.
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 83
                                            • 84
                                            • 47 / 84
