    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.2m Views 120 Watching
    • fredo6F
      New Release: Animator - v1.5b - 15 Mar 17
      Requirement: LibFredo6 v7.5a
      Maintenance release
      • bug fixing for SU8 and SU2013, as reported by Treadshot A1
      See main post for RBZ files
      • T
        Treadshot A1
        @fredo6 said:
        Maintenance release
        Wow, that was fast! Thanks a lot fredo, I'm almost convinced there's some wizardry/magic involved in how you fixed the code so quickly. 😄
        That said, I'm not sure if what I have for you is good news or bad news. I can confirm v1.5b works on SU8Free (which is awesome!). I still have the "Script Error" popup I mentioned before, difference is I see the actual consequences now. Previously, all it meant was I pressed "Interrupt", then "Cancel", and it would redo the frame (say, stuck on Frame 5, okay, Animator regenerates Frame 5). Now, same process, it regenerates Frame 5, but actually with Frame 6's data (I can see components move when I hit "Cancel" to their new positions). This gets saved as "Frame_004" (yes 004), even though it's actually Frame 6.
        Let's say that it's stuck on Frame 5, then I interrupt and cancel to get it going again, then it gets stuck again. I repeat the process. Then I get a "Frame_004", but with Frame 7's data. It's consistent, each time it freezes, it moves one frame's worth of data ahead. I've attached to screenshots from File Explorer of the frames being generated, with 004 overwritten, while Animator says it is stuck on Frame 5 (the overwritten 4 is pictured 2 frames later, I think).
        *I did check if maybe Animator was simply saving the picture before moving to the next frame and not actually stuck, just in case I wasn't patient enough; can confirm Task Manager shows 0% activity from Sketchup-related processes.
        *This happens only with Thea rendering on; Natural rendering works fine, no glitches. I do recall suggestions that Trial versions of Thea may have issues with weird dimensions, so I tried 16:9, 4:3, Viewport settings. Glitch above still happens regardless.
        EDIT: Sorry, forgot to screenshot Ruby output. Attached are "test_2" images of frames overwritten, and ruby output.
        • fredo6F
          Actually, there is a problem with Thea which does not always notify Animator when it has finished rendering a frame.
          Other users are encountering similar problems, even on SU2017. See this thread.
          • T
            Treadshot A1
            Ah, I see. My apologies Fredo, I was not aware of that thread before. You are correct, starting animation from Thea does indeed work, frames are coming out smoothly. Tested on SU8Free, Win 10. Will show the results when done.
            As always, thank you very much Fredo! 😄
            • ithilI
              ithil
              Good day, Fredo!
              Thanks again for the great plugin.
              I wanted to ask, can you add the option - "save as default" forMovement?
              I'm doing an assembly diagram and all the movements have to be said for three seconds and the Easing is the same. Now I have to constantly monitor this.
              • ithilI
                ithil
                One more question.
                Can you add the option "start numbering from 0 seconds"?
                I use the Images Sequence to save the animation. My video has more than 2500 frames. And it's rendered for a long time.
                If I need to fix just a few seconds of this movie I'm trying to use "Start at:" and "End at:" options.
                But as a result I get files with numberings like this "Image0001"
                It would be better if it was possible to call the file not from scratch but from the current position. E.g. Image1551
                • fredo6F
                  Ithil,
                  You are right. Because rendering and video generation are long, it is a good idea to find a way to have partial re-generation.
                  I need to think about it.
                  • T
                    Treadshot A1
                    @ithil said:
                    One more question.
                    Just out of interest, what renderer are you using? When I'm rendering with Thea, I call the animation from Thea, which lets me choose what frames to render. When I was rendering my Jaguar model, if I wanted to redo frames jaguar_0100 to jaguar_0120, I can just go into Thea and set it to render frames 100 to 120, which it correctly names. I've not tried messing with Animator's built in "Start at:" and "End at:" options, but that's mainly because I find a frame range to be more precise for what I'm testing now.
                    That said, I agree that such an option would be useful natively in Animator.
                    • ithilI
                      ithil
                      I use direct save from sketchup to sequencing .png files.
                      But it's still quite long. Approximately 40-50 minutes.
                      For a part of 100-150 frames, I do not want to lose these minutes.
                      • alvisA
                        alvis
                        Hi Fredo. I have difficulty with the camera. I want the camera to move around the object. Now around the headboard camera moves irregularly. Maybe there is a way to clone Sketchup cameras from scenes ?
                        Sketchup scenes
                        Animator scenes
                        • fredo6F
                          Sketchup scenes
                          Animator scenes
                          Animator offers two modes of transition between views (called fadeout)
                          • Linear, which is is more for step by step camera animation
                          • circular, which is closer to what Sketchup does between scenes
                            I suggest you try with both
                            Alex37550
                            Bonjour,
                            j'ai découvert en début d'année ce formidable Plugin Animator! Merci Fredo. 👍
                            Je n'avais pas eu de souci sur mes 1ères animations, mais là, j'ai travaillé à partir d'une photo adaptée et l'image adaptée est déformée (coupée en 2 avec des zooms différents apparemment).
                            J'ai d'abord pensé que je n'avais peut-être pas fait les mises à jour.
                            J'ai chargé Animator 1.5b
                            j'avais déjà LibFredo 7.5b
                            mais c'est pareil
                            je joins une image extrait du Test image. la vidéo est pareille.
                            j'ai fait un essai avec une autre photo, une nouvelle animation, un autre ordinateur, même résultat. et parfois ça revient comme il faut.
                            Est ce un bug? quelqu'un a t il le même problème?
                            Je profite de cette question pour savoir si on peut définir un chemin à suivre pour un mouvement (enchainement, ligne droite, courbe...), je n'ai pas vu si cela existait?
                            Merci d'avance
                            • chriC
                              chri
                              Bonjour Alex
                              Peut-etre ce POST peut-il t'aider
                              http://sketchucation.com/forums/viewtopic.php?f=401%26amp;t=65237
                              Chri
                              • fredo6F
                                @alex37550 said:
                                Bonjour,
                                mais c'est pareil
                                Merci d'avance
                                Je ne comprends pas bien le probleme. Est ce que les images servent simplement de fond.
                                Dans tous les cas, Animator travaillant seulement sur des groupes et components, il est prudent de mettre les images dans un groupe.
                                • ntxdaveN
                                  ntxdave
                                  Just curious: Are any new updates planned for the near future?
                                  Press F1...thank me later
                                  • fredo6F
                                    Next update in one week, with Scale and a preliminary version of Follow Path.
                                    • ntxdaveN
                                      ntxdave
                                      YAHOO!!!! 👍 👍 👍 👍 👍
                                      Now if you could work with Enscape, that would be absolutely awesome..........
                                        Fredo President! 😉
                                          Alex37550
                                          @alex37550 said:
                                          problème d'image déformée sur une animation
                                          Bonjour,
                                          J'utilise une image que j'ai importé pour l'adapter qui me sert donc de fond. (je ne fais donc pas bouger la caméra sinon elle ne serait plus visible, mais ce n'est pas grave.)
                                          L'image que j'ai jointe est ce que j'obtiens en aperçu avant de faire la vidéo. Si je fais le montage, la vidéo ressemble à cette image.
                                          Le problème est que ce "bug" n'est pas systématique, donc je ne sais pas dire dans quelle condition il se produit. On a réussi finalement à avoir une image non déformée, mais sans savoir ce qui a été efficace. On a essayé par exemple de déplacer les axes du dessin ou de la photo adaptée.
                                          Avez vous déjà essayé animator avec une photo adaptée? quand on utilise le zoom, c'est bizarre, la photo est figée mais on retrouve l'échelle, on récupérant la position de départ sauvegardée. (Donc pas grave, même si la 1ère fois, on pense avoir perdu l'échelle par rapport à la photo)
                                          Alexandre, fan des plug in de Fredo! Merci Fredo
                                            adrihal
                                            While working with the plugin, several problems arose.
                                            There is no way to make a render of any size - just the size of the screen.
                                            Can not record the reverse playback.
                                            There is a wish - I would like to receive lines on which the assembly is disassembled.
                                            As if the circuit for assembling complex structures.
                                            The effect is the damping for the pendulum and the rebound with the damping for the ball.
                                            These inserts revitalized the videos
                                            • 29
                                            • 30
                                            • 6 / 30
