    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
      mike_fr60
      Thank you for your quick answer.
      I don't see any frame. I don't see the panel to manage the type of video or output to chose.
      I have an error in the Ruby console. You are right !! I have SU Podium render on the computer where the problem is. And not on the other computer where all is working.
      I didn't know that your Animator could be in accordance with a rendering program.
      I thought it was only a simple rendering like the basic Sketchup rendering.
      What can I do to generate basic rendering ? And is it possible to have a SU Podium rendering ?
      Here the Ruby console's error message :
      ambient init nil nil
      Twilight declare nil
      Error: #<NameError: undefined method rendering_podium_frame' for class Traductor::VideoManager'>
      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:414:in method' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:414:in block in rendering_init'
      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:413:in each' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:413:in rendering_init'
      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:334:in dialog_invoke' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_animator/animatortool.rbe:1820:in movie_dialog'
      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_animator/animatortool.rbe:1790:in movie_clip_generation' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_animator/animatorpalette.rbe:771:in block in palette_clip_name_duration_video'
      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3407:in call' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3407:in execute_button'
      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3212:in onLButtonUp' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:93:in onLButtonUp'
      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_animator/animatortool.rbe:1159:in `onLButtonUp'
      • fredo6F
        My fault! Animator detects Podium, but does not check whether animated rendering is supported.
        I'll fix that in a next version.
        • fredo6F
          New Release: Animator - v1.5a - 12 Dec 17
          Requirement: LibFredo6 v7.5a
          **Maintenance release
          • bug fixing and cosmetic changes
          • introduction of Trajectory Visual effect (see video)**
          See main post for RBZ files
          • ntxdaveN
            ntxdave
            OK - Fredo, there is now another product for you to connect with. I do not know if you have seen the thread about Enscape but the product looks amazing and would really be awesome combined with Animator.
            Press F1...thank me later
            • T
              Treadshot A1
              Well, I finally updated to Animator's newest version (thanks to the old version reminding me it was expired). I had a working animation before, but I can't access it now because v1.5a doesn't open. The Video Player and Clip Editor don't seem to load(?); at least, it never gets to showing the UI. Animator 1.5a is running with LibFredo 7.5b, SU8Free.
              Ruby console output is attached; first section is what happens when I open a model, and try to open clip editor without doing anything else. The model_name.skp and model_name.animator files were functional in v1.4. Second section is trying to open clip editor again, since the first time didn't result in anything showing up on screen. The "(eval):249" line at the end seems to be consistently where it stops when clip editor is opened, except for not reaching that line the first time it's opened after opening the model.
              *I have no idea what the TrajectoryManager it asks for is; is it something I need to install separately?
              • fredo6F
                New Release: Animator - v1.5b - 15 Mar 17
                Maintenance release
                • bug fixing for SU8 and SU2013, as reported by Treadshot A1
                • T
                  Treadshot A1
                  @fredo6 said:
                  Maintenance release
                  Wow, that was fast! Thanks a lot fredo, I'm almost convinced there's some wizardry/magic involved in how you fixed the code so quickly. 😄
                  That said, I'm not sure if what I have for you is good news or bad news. I can confirm v1.5b works on SU8Free (which is awesome!). I still have the "Script Error" popup I mentioned before, difference is I see the actual consequences now. Previously, all it meant was I pressed "Interrupt", then "Cancel", and it would redo the frame (say, stuck on Frame 5, okay, Animator regenerates Frame 5). Now, same process, it regenerates Frame 5, but actually with Frame 6's data (I can see components move when I hit "Cancel" to their new positions). This gets saved as "Frame_004" (yes 004), even though it's actually Frame 6.
                  Let's say that it's stuck on Frame 5, then I interrupt and cancel to get it going again, then it gets stuck again. I repeat the process. Then I get a "Frame_004", but with Frame 7's data. It's consistent, each time it freezes, it moves one frame's worth of data ahead. I've attached to screenshots from File Explorer of the frames being generated, with 004 overwritten, while Animator says it is stuck on Frame 5 (the overwritten 4 is pictured 2 frames later, I think).
                  *I did check if maybe Animator was simply saving the picture before moving to the next frame and not actually stuck, just in case I wasn't patient enough; can confirm Task Manager shows 0% activity from Sketchup-related processes.
                  *This happens only with Thea rendering on; Natural rendering works fine, no glitches. I do recall suggestions that Trial versions of Thea may have issues with weird dimensions, so I tried 16:9, 4:3, Viewport settings. Glitch above still happens regardless.
                  EDIT: Sorry, forgot to screenshot Ruby output. Attached are "test_2" images of frames overwritten, and ruby output.
                  • fredo6F
                    Actually, there is a problem with Thea which does not always notify Animator when it has finished rendering a frame.
                    Other users are encountering similar problems, even on SU2017. See this thread.
                    • T
                      Treadshot A1
                      Ah, I see. My apologies Fredo, I was not aware of that thread before. You are correct, starting animation from Thea does indeed work, frames are coming out smoothly. Tested on SU8Free, Win 10. Will show the results when done.
                      As always, thank you very much Fredo! 😄
                      • ithilI
                        ithil
                        Good day, Fredo!
                        Thanks again for the great plugin.
                        I wanted to ask, can you add the option - "save as default" forMovement?
                        I'm doing an assembly diagram and all the movements have to be said for three seconds and the Easing is the same. Now I have to constantly monitor this.
                        • ithilI
                          ithil
                          One more question.
                          Can you add the option "start numbering from 0 seconds"?
                          I use the Images Sequence to save the animation. My video has more than 2500 frames. And it's rendered for a long time.
                          If I need to fix just a few seconds of this movie I'm trying to use "Start at:" and "End at:" options.
                          But as a result I get files with numberings like this "Image0001"
                          It would be better if it was possible to call the file not from scratch but from the current position. E.g. Image1551
                          • fredo6F
                            Ithil,
                            You are right. Because rendering and video generation are long, it is a good idea to find a way to have partial re-generation.
                            I need to think about it.
                            • T
                              Treadshot A1
                              @ithil said:
                              One more question.
                              Just out of interest, what renderer are you using? When I'm rendering with Thea, I call the animation from Thea, which lets me choose what frames to render. When I was rendering my Jaguar model, if I wanted to redo frames jaguar_0100 to jaguar_0120, I can just go into Thea and set it to render frames 100 to 120, which it correctly names. I've not tried messing with Animator's built in "Start at:" and "End at:" options, but that's mainly because I find a frame range to be more precise for what I'm testing now.
                              That said, I agree that such an option would be useful natively in Animator.
                              • ithilI
                                ithil
                                I use direct save from sketchup to sequencing .png files.
                                But it's still quite long. Approximately 40-50 minutes.
                                For a part of 100-150 frames, I do not want to lose these minutes.
                                • alvisA
                                  alvis
                                  Hi Fredo. I have difficulty with the camera. I want the camera to move around the object. Now around the headboard camera moves irregularly. Maybe there is a way to clone Sketchup cameras from scenes ?
                                  Sketchup scenes
                                  Animator scenes
                                  • fredo6F
                                    Sketchup scenes
                                    Animator scenes
                                    Animator offers two modes of transition between views (called fadeout)
                                    • Linear, which is is more for step by step camera animation
                                    • circular, which is closer to what Sketchup does between scenes
                                      I suggest you try with both
                                      Alex37550
                                      Bonjour,
                                      j'ai dĂ©couvert en dĂ©but d'annĂ©e ce formidable Plugin Animator! Merci Fredo. 👍
                                      Je n'avais pas eu de souci sur mes 1Úres animations, mais là, j'ai travaillé à partir d'une photo adaptée et l'image adaptée est déformée (coupée en 2 avec des zooms différents apparemment).
                                      J'ai d'abord pensĂ© que je n'avais peut-ĂȘtre pas fait les mises Ă  jour.
                                      J'ai chargé Animator 1.5b
                                      j'avais déjà LibFredo 7.5b
                                      mais c'est pareil
                                      je joins une image extrait du Test image. la vidéo est pareille.
                                      j'ai fait un essai avec une autre photo, une nouvelle animation, un autre ordinateur, mĂȘme rĂ©sultat. et parfois ça revient comme il faut.
                                      Est ce un bug? quelqu'un a t il le mĂȘme problĂšme?
                                      Je profite de cette question pour savoir si on peut définir un chemin à suivre pour un mouvement (enchainement, ligne droite, courbe...), je n'ai pas vu si cela existait?
                                      Merci d'avance
                                      • chriC
                                        chri
                                        Bonjour Alex
                                        Peut-etre ce POST peut-il t'aider
                                        http://sketchucation.com/forums/viewtopic.php?f=401%26amp;t=65237
                                        Chri
                                        • fredo6F
                                          @alex37550 said:
                                          Bonjour,
                                          mais c'est pareil
                                          Merci d'avance
                                          Je ne comprends pas bien le probleme. Est ce que les images servent simplement de fond.
                                          Dans tous les cas, Animator travaillant seulement sur des groupes et components, il est prudent de mettre les images dans un groupe.
                                          • ntxdaveN
                                            ntxdave
                                            Just curious: Are any new updates planned for the near future?
                                            • 29
                                            • 30
                                            • 6 / 30
