    [Plugin] Animator - v4.6a - 18 Dec 25
    renderpluginsextensions
    600 Posts 120 Posters 2.3m Views 120 Watching
    • fredo6F
      Can you at least confirm whether you get freezing situations when you do not use Thea.
      For Thea, I'll have a look, but it may depend on the rendering mode you use. In past tests, I have noticed that 'unbiased' and 'adaptive' always had problem with the API of Thea (on top of being slow), maybe because the calculation is progressive. So the Thea API may miss the signal for termination.
      In general, for an animation, IR Presto is good enough.
      • T
        Treadshot A1
        Confirm: No Freezing with Natural Rendering.
        Restarted Trinity's animation with Natural Rendering on two machines again to confirm; both animations were successful with no freezing, no frames repeated. Script Errors happened on both machines for Frames 1-10 on both; one machine also had Script Errors for the last 3 Frames, the other had them for the last 10 Frames.
        You're right on the rendering mode, I had left it Unbiased which definitely added to the rendering time, IR Presto - AO with Interactive unchecked works fine. Tested Thea rendering with IR Presto, using a different model to make sure Trinity wasn't the issue, appears to me Thea has finished a render, Animator and Sketchup move the the next frame, the Thea doesn't start. This is after I get a Script Error.
        Anyway, I'll keep testing on my end. Sorry to keep pointing out problems, hope it'll all work soon. πŸ˜„
        • fredo6F
          Could you tell me which Script Errors you get in Natural rendering.
          • T
            Treadshot A1
            Consistently get "Invalid Argument" Script Errors. Not sure what that means though.
            • fredo6F
              Which version of Windows do you have?
              • T
                Treadshot A1
                Happens on both Windows 8 and Windows 10. Internet Explorer is up to date, Ive unchecked the 'Display a notification about every script error' box in settings, and checked both 'Disable Script Debugging (Internet Explorer)' and 'Disable Script Debugging (Others)'.
                  mike_fr60
                  Hello sorry with my English, I will try to make a question regarding this post. I have also freezing screen, when I launch "Generate video for the film".
                  I have Windows 10 and sketchup 2015 and 2016 and that is the same problem.
                  I have 2 computers laptop, and with same project and same configuration one works( Samsung ) and not the other ( Asus ).
                  I made the film on the Asus, and copy to the Samsung , the generate panel open immediately.
                  I tried to delete the Lib and the animator plugins and reinstall, and nothing happend.
                  That is a problem, with the processor ? with the video program missing or something else ?
                  Thank you for your help.
                  Michel ( France )
                  • fredo6F
                    @michel,
                    Could you open the Ruby console and check if there are errors.
                    Also can you be more precise on the 'freezing'
                    • is this with Natural rendering (i.e. no rendering) ?
                    • do you see some frames process before the freeze ?
                      mike_fr60
                      Thank you for your quick answer.
                      I don't see any frame. I don't see the panel to manage the type of video or output to chose.
                      I have an error in the Ruby console. You are right !! I have SU Podium render on the computer where the problem is. And not on the other computer where all is working.
                      I didn't know that your Animator could be in accordance with a rendering program.
                      I thought it was only a simple rendering like the basic Sketchup rendering.
                      What can I do to generate basic rendering ? And is it possible to have a SU Podium rendering ?
                      Here the Ruby console's error message :
                      ambient init nil nil
                      Twilight declare nil
                      Error: #<NameError: undefined method rendering_podium_frame' for class Traductor::VideoManager'>
                      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:414:in method' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:414:in block in rendering_init'
                      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:413:in each' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:413:in rendering_init'
                      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_animator/animatordialogvideogeneration.rbe:334:in dialog_invoke' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_animator/animatortool.rbe:1820:in movie_dialog'
                      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_animator/animatortool.rbe:1790:in movie_clip_generation' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_animator/animatorpalette.rbe:771:in block in palette_clip_name_duration_video'
                      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3407:in call' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3407:in execute_button'
                      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/body_lib6palette.rbe:3212:in onLButtonUp' c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_!libfredo6/lib6palette.rbe:93:in onLButtonUp'
                      c:/users/michel/appdata/roaming/sketchup/sketchup 2016/sketchup/plugins/fredo6_animator/animatortool.rbe:1159:in `onLButtonUp'
                      • fredo6F
                        My fault! Animator detects Podium, but does not check whether animated rendering is supported.
                        I'll fix that in a next version.
                        • fredo6F
                          New Release: Animator - v1.5a - 12 Dec 17
                          Requirement: LibFredo6 v7.5a
                          **Maintenance release
                          • bug fixing and cosmetic changes
                          • introduction of Trajectory Visual effect (see video)**
                          See main post for RBZ files
                          • ntxdaveN
                            ntxdave
                            OK - Fredo, there is now another product for you to connect with. I do not know if you have seen the thread about Enscape but the product looks amazing and would really be awesome combined with Animator.
                            Press F1...thank me later
                            • T
                              Treadshot A1
                              Well, I finally updated to Animator's newest version (thanks to the old version reminding me it was expired). I had a working animation before, but I can't access it now because v1.5a doesn't open. The Video Player and Clip Editor don't seem to load(?); at least, it never gets to showing the UI. Animator 1.5a is running with LibFredo 7.5b, SU8Free.
                              Ruby console output is attached; first section is what happens when I open a model, and try to open clip editor without doing anything else. The model_name.skp and model_name.animator files were functional in v1.4. Second section is trying to open clip editor again, since the first time didn't result in anything showing up on screen. The "(eval):249" line at the end seems to be consistently where it stops when clip editor is opened, except for not reaching that line the first time it's opened after opening the model.
                              *I have no idea what the TrajectoryManager it asks for is; is it something I need to install separately?
                              • fredo6F
                                New Release: Animator - v1.5b - 15 Mar 17
                                Maintenance release
                                • bug fixing for SU8 and SU2013, as reported by Treadshot A1
                                • T
                                  Treadshot A1
                                  @fredo6 said:
                                  Maintenance release
                                  Wow, that was fast! Thanks a lot fredo, I'm almost convinced there's some wizardry/magic involved in how you fixed the code so quickly. πŸ˜„
                                  That said, I'm not sure if what I have for you is good news or bad news. I can confirm v1.5b works on SU8Free (which is awesome!). I still have the "Script Error" popup I mentioned before, difference is I see the actual consequences now. Previously, all it meant was I pressed "Interrupt", then "Cancel", and it would redo the frame (say, stuck on Frame 5, okay, Animator regenerates Frame 5). Now, same process, it regenerates Frame 5, but actually with Frame 6's data (I can see components move when I hit "Cancel" to their new positions). This gets saved as "Frame_004" (yes 004), even though it's actually Frame 6.
                                  Let's say that it's stuck on Frame 5, then I interrupt and cancel to get it going again, then it gets stuck again. I repeat the process. Then I get a "Frame_004", but with Frame 7's data. It's consistent, each time it freezes, it moves one frame's worth of data ahead. I've attached to screenshots from File Explorer of the frames being generated, with 004 overwritten, while Animator says it is stuck on Frame 5 (the overwritten 4 is pictured 2 frames later, I think).
                                  *I did check if maybe Animator was simply saving the picture before moving to the next frame and not actually stuck, just in case I wasn't patient enough; can confirm Task Manager shows 0% activity from Sketchup-related processes.
                                  *This happens only with Thea rendering on; Natural rendering works fine, no glitches. I do recall suggestions that Trial versions of Thea may have issues with weird dimensions, so I tried 16:9, 4:3, Viewport settings. Glitch above still happens regardless.
                                  EDIT: Sorry, forgot to screenshot Ruby output. Attached are "test_2" images of frames overwritten, and ruby output.
                                  • fredo6F
                                    Actually, there is a problem with Thea which does not always notify Animator when it has finished rendering a frame.
                                    Other users are encountering similar problems, even on SU2017. See this thread.
                                    • T
                                      Treadshot A1
                                      Ah, I see. My apologies Fredo, I was not aware of that thread before. You are correct, starting animation from Thea does indeed work, frames are coming out smoothly. Tested on SU8Free, Win 10. Will show the results when done.
                                      As always, thank you very much Fredo! πŸ˜„
                                      • ithilI
                                        ithil
                                        Good day, Fredo!
                                        Thanks again for the great plugin.
                                        I wanted to ask, can you add the option - "save as default" forMovement?
                                        I'm doing an assembly diagram and all the movements have to be said for three seconds and the Easing is the same. Now I have to constantly monitor this.
                                        • ithilI
                                          ithil
                                          One more question.
                                          Can you add the option "start numbering from 0 seconds"?
                                          I use the Images Sequence to save the animation. My video has more than 2500 frames. And it's rendered for a long time.
                                          If I need to fix just a few seconds of this movie I'm trying to use "Start at:" and "End at:" options.
                                          But as a result I get files with numberings like this "Image0001"
                                          It would be better if it was possible to call the file not from scratch but from the current position. E.g. Image1551
                                          • fredo6F
                                            Ithil,
                                            You are right. Because rendering and video generation are long, it is a good idea to find a way to have partial re-generation.
                                            I need to think about it.
                                            • 29
                                            • 30
                                            • 6 / 30
