    [Plugin] Guide Tools (1.3.0) — 21 October 2010
    99 Posts 34 Posters 121.3k Views 34 Watching
    • jeff hammondJ
      can someone check this file just to see if we're getting similar results?
      if i use cPoint at Arc Center on an arc then no cpoint.. if i use cPoint at Circle Center on a circle then no cPoint.
      if i use cPoint at Exploded Arc Center then it will work on an exploded arc as well as an arc or circle.
      guidetoolprob.skp
      in reality, it's better (imo) to have the one command work on all scenarios.. i'm just curious if other are seeing the same thing
      thanks
      (TT_Lib 2.9.8 with guideTools 1.4)
        @jeff
        same result here in Windows 8
        • jeff hammondJ
          interesting.
          up til now, I've been using a couple of different plugins to accomplish the same thing as this one command.
          @thomthom. are you aware of this behavior? and if you're just now becoming aware of it, don't fix it 😄
          (unless the simplification is removing some seemingly redundant and non-working items from the menu)
          • kuponoK
            kupono
            Using Guide Tools 1.4.0 with SU Pro 2013 on Win8
            circle-- cPoint at Circle Center worked fine
            arc-- cPoint at Arc Center worked fine
            same arc-- Exploded Arc Center worked fine
            Everything seemed to work okay.
            • jeff hammondJ
              thanks for checking it Kupono.
              I'll try it a little later in 2013 to see if it's a version issue.
              • tt_suT
                tt_su
                What version of SketchUp are you using it on?
                  That was due to an SU2014 incompatibility. I've made an update and it's live on PluginStore and pending review on Extension Warehouse.
                  • mariochaM
                    mariocha
                    I too would like to have a plugin that turns an exploded circle back to a real one with a center point, not just a curve.
                    %(#008000)[Mario C.
                    • B
                      bjnobre
                      There is a known issue on SU2017? I've installed plugin, but the only commando working is CPoint at circle center.
                        I just ran it in SU2017 and had no problem getting the various tools to work.
                        Cpoint at Arc Center
                        Cpoint at Insertion Point
                        Cpoint at Bounds Center
                        Cpoint at Bounds Bottom Center
                        Cpoint at Exploded Arc Center
                        Cpoint at Camera Eye also works but not shown in the screen shot.
                        What version have you installed?
                        • mariochaM
                          mariocha
                          Yeah, same here. All working.
                          plugin version 1.4.1
                          %(#008000)[Mario C.
                          • 5 / 5
