    [Plugin] Guide Tools (1.3.0) — 21 October 2010
    99 Posts 34 Posters 122.9k Views 34 Watching
      Unless SketchUp thinks it is an arc or a circle, the native inferencing won't be able to identify a center and neither will the Guide Tool. It's not a deficiency with this plugin. I think Chris Fullmer (or maybe Jim Foltz) did a plugin that can figure out the center of curves that aren't circles or arcs. A search of the Plugins index should turn up what you need.
        jtri
        Thanks for the help.
        • cottyC
          cotty
          e.g. Chris: Exploded arc centerpoint finder
          my SketchUp gallery
          • jeff hammondJ
            can someone check this file just to see if we're getting similar results?
            if i use cPoint at Arc Center on an arc then no cpoint.. if i use cPoint at Circle Center on a circle then no cPoint.
            if i use cPoint at Exploded Arc Center then it will work on an exploded arc as well as an arc or circle.
            guidetoolprob.skp
            in reality, it's better (imo) to have the one command work on all scenarios.. i'm just curious if other are seeing the same thing
            thanks
            (TT_Lib 2.9.8 with guideTools 1.4)
              @jeff
              same result here in Windows 8
              • jeff hammondJ
                interesting.
                up til now, I've been using a couple of different plugins to accomplish the same thing as this one command.
                @thomthom. are you aware of this behavior? and if you're just now becoming aware of it, don't fix it 😄
                (unless the simplification is removing some seemingly redundant and non-working items from the menu)
                • kuponoK
                  kupono
                  Using Guide Tools 1.4.0 with SU Pro 2013 on Win8
                  circle-- cPoint at Circle Center worked fine
                  arc-- cPoint at Arc Center worked fine
                  same arc-- Exploded Arc Center worked fine
                  Everything seemed to work okay.
                  • jeff hammondJ
                    thanks for checking it Kupono.
                    I'll try it a little later in 2013 to see if it's a version issue.
                    • tt_suT
                      tt_su
                      What version of SketchUp are you using it on?
                        That was due to an SU2014 incompatibility. I've made an update and it's live on PluginStore and pending review on Extension Warehouse.
                        • mariochaM
                          mariocha
                          I too would like to have a plugin that turns an exploded circle back to a real one with a center point, not just a curve.
                          %(#008000)[Mario C.
                          • B
                            bjnobre
                            There is a known issue on SU2017? I've installed plugin, but the only commando working is CPoint at circle center.
                              I just ran it in SU2017 and had no problem getting the various tools to work.
                              Cpoint at Arc Center
                              Cpoint at Insertion Point
                              Cpoint at Bounds Center
                              Cpoint at Bounds Bottom Center
                              Cpoint at Exploded Arc Center
                              Cpoint at Camera Eye also works but not shown in the screen shot.
                              What version have you installed?
                              • mariochaM
                                mariocha
                                Yeah, same here. All working.
                                plugin version 1.4.1
                                %(#008000)[Mario C.
                                • 5 / 5
