    [Plugin] Guide Tools (1.3.0) — 21 October 2010
    99 Posts 34 Posters 121.3k Views 34 Watching
      It works for me with SU2013.
      You'll need to be more specific about what happens when you try to use it.
        Any error messages? As Dave mentioned, we'd need more specific info to what "isn't working".
          And seems this intersection don't work! 😮
          Or we can't name that Edge Edge Inetersection? 🤓
            Dear Thomthom can you add a CD Point at Bounds "Top" Center ?
            And a CD Point at Bounds "Bottom" + "Top" Center ?
            I must make some acrobatics for have this result! 😄
            http://sketchucation.com/forums/download/file.php?id=115129&t=1
            Projection by Tak2hata
              jtri
              Great plug in but I noticed if I intersect 2 components, then try and find the center of the circle that is left from the intersection the plug in does not find the center. Also if you add a face to the circle it also does not add the center point. Am I missing something?
              Test.skp
                If you select the edge of the "circle" does SketchUp identify it as a circle in Entity Info?
                  jtri
                  No it is not a circle! But if I weld them it is now a curve, which is closer but not what is needed. Not seeing how to make it a circle, still missing something.
                    Unless SketchUp thinks it is an arc or a circle, the native inferencing won't be able to identify a center and neither will the Guide Tool. It's not a deficiency with this plugin. I think Chris Fullmer (or maybe Jim Foltz) did a plugin that can figure out the center of curves that aren't circles or arcs. A search of the Plugins index should turn up what you need.
                      jtri
                      Thanks for the help.
                      • cottyC
                        cotty
                        e.g. Chris: Exploded arc centerpoint finder
                        my SketchUp gallery
                        • jeff hammondJ
                          can someone check this file just to see if we're getting similar results?
                          if i use cPoint at Arc Center on an arc then no cpoint.. if i use cPoint at Circle Center on a circle then no cPoint.
                          if i use cPoint at Exploded Arc Center then it will work on an exploded arc as well as an arc or circle.
                          guidetoolprob.skp
                          in reality, it's better (imo) to have the one command work on all scenarios.. i'm just curious if other are seeing the same thing
                          thanks
                          (TT_Lib 2.9.8 with guideTools 1.4)
                            @jeff
                            same result here in Windows 8
                            • jeff hammondJ
                              interesting.
                              up til now, I've been using a couple of different plugins to accomplish the same thing as this one command.
                              @thomthom. are you aware of this behavior? and if you're just now becoming aware of it, don't fix it 😄
                              (unless the simplification is removing some seemingly redundant and non-working items from the menu)
                              • kuponoK
                                kupono
                                Using Guide Tools 1.4.0 with SU Pro 2013 on Win8
                                circle-- cPoint at Circle Center worked fine
                                arc-- cPoint at Arc Center worked fine
                                same arc-- Exploded Arc Center worked fine
                                Everything seemed to work okay.
                                • jeff hammondJ
                                  thanks for checking it Kupono.
                                  I'll try it a little later in 2013 to see if it's a version issue.
                                  • tt_suT
                                    tt_su
                                    What version of SketchUp are you using it on?
                                      That was due to an SU2014 incompatibility. I've made an update and it's live on PluginStore and pending review on Extension Warehouse.
                                      • mariochaM
                                        mariocha
                                        I too would like to have a plugin that turns an exploded circle back to a real one with a center point, not just a curve.
                                        %(#008000)[Mario C.
                                        • B
                                          bjnobre
                                          There is a known issue on SU2017? I've installed plugin, but the only commando working is CPoint at circle center.
                                            I just ran it in SU2017 and had no problem getting the various tools to work.
                                            Cpoint at Arc Center
                                            Cpoint at Insertion Point
                                            Cpoint at Bounds Center
                                            Cpoint at Bounds Bottom Center
                                            Cpoint at Exploded Arc Center
                                            Cpoint at Camera Eye also works but not shown in the screen shot.
                                            What version have you installed?
                                            • 5 / 5
