    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
    • TIGT Online
      Thanks for the reports.
      I see it too... investigating...
      It's the way v2017 replaces an exploded entity with a duplicate, with another ID, and so you can no longer collect a reference to it before exploding, it must be done as part of the explode itself to get the correct reference...
      Working on it - I suspect it affects many of the tools...
      • CadFatherC Offline
        CadFather
        Hi TIG - if you can - have a look at the offset please, it seems the reading is slightly off (no pun!). didn't have time to look at the code myself
        • TIGT Online
          The whole ExtrudeToolset is foobar thanks to the way v2017 handles exploded entities and looses references but while keeping id's...
          I'm working on a fix... ๐Ÿ˜ฎ
            CadFather
            yes, the offset was always a smidge off (only in terms of measurements) - other than that, the script works fine on both (on my super system of course), thanks!
            • H Offline
              hell0304
              It's worked great on SU2016 but some Error happen on SU2017. Can u please fix it soon???
              • TIGT Online
                I know !
                The new API in v2017 breaks some things [references, IDs etc]
                I have been working on a fix for the last few weeks...
                It has proven awkward !
                Watch for updates...
                • pbacotP Offline
                  Thsnks TIG, Watching for this. Though I am holding off on using v2017.
                  • GMthompsonG Offline
                    GMthompson
                    i cannot get eebf to work in 2017 I have uninstalled and reinstalled 2017 one plugin at a time starting with freedo tools any suggestions
                    you can learn something everyday by paying attention
                      @gmthompson said:
                      ...any suggestions
                      Suggestions? Yes. Read TIG's last post in this thread. He's working on a fix. I'm sure when he has a suitable fix, he'll release an update.
                      • TIGT Online
                        Update is 90% done... but it's not there yet...
                        ๐Ÿ˜ฒ
                          TIG, we are lucky to get these valuable tools in the first place, I am not going to be pushy over the fix, I can always sort the one piece of geometry in sketchup 2016 until this is sorted to your satisfaction. Many thanks for making sketchup better by your hard work.
                            jbnarch25
                            Updates needed for Sketchup 2017 on "Extrude Edges by Rails" , Lattice, face. Works good on 16 guess it has something to do with ruby 2.2 used in 17.
                            • TIGT Online
                              If you look a couple of posts earlier on in this thread, you'll see that the update is in progress...
                              • TIGT Online
                                I know 'they' broke it in v2017.
                                They changed the way exploded groups etc no longer keep an enduring reference to the contents !
                                I have fixed this in several plugins.
                                I have fixed it in this toolset too, but I;ve not reissued yet, because I have an intractable bugsplat occurring if the user does an undo after making some forms, in some of the tools.
                                This is very odd, since it seems unrelated to the main problem they created.
                                In essence, the paths [profiles/rails] are temporarily grouped during the processing to stop them getting messed up by the later processes. At the end it is exploded back as it was. That works fine, but if the user does an undo it bugsplats...
                                It is very odd.
                                I am considering alternative solutions...
                                  simoncastle
                                  Hi TIG thank you very much for these plugins.
                                  I dont know if you are aware that "THEY" broke something in their API which causes the extrude on rails to fail in 2017, its still working correctly in 2016.
                                  Im not sure what the problem is, I have a singe cure with 2 rails that join at a pint.
                                  As I said its file in 2016. If you cant reproduce it let me know and I will try to upload my file.
                                  Sorry for posting this, didn't read the latest posts.
                                  Feeling stupid now.
                                  ๐Ÿ˜ณ
                                  ... Simon
                                    rilian
                                    @tig said:
                                    It is very odd.
                                    Bump? Any further news on your bugsplat?
                                    • TIGT Online
                                      I have most of the problems fixed.
                                      However, I might need to recast how some of the tools exit, as I am finding that no permutations of the current exit strategies avoid a BugSplat !
                                      ๐Ÿ˜ฎ
                                      • 2 Offline
                                        2k328ci
                                        Hi TIG,
                                        I love your tools especially this one! Glad you're working on a 2017 solution. Any news on possible updates? Thanks so much for all your efforts.
                                        • TIGT Online
                                          Here's v4.0
                                          https://sketchucation.com/pluginstore?pln=ExtrudeTools
                                          It's now recoded for v2017/v2018 compatibility.
                                          However, please be aware it is more prone to BugSplats [especially with an 'undo'] in these newer SketchUp versions, so use with care and always remember to save your model before using these tools...
                                          You've been warned !
                                          • BoxB Offline
                                            Thank you thank you thank you.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 29 / 32
