    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 1.0m Views 175 Watching
      @hell0304 said:
      It's worked great on SU2016 but some Error happen on SU2017. Can u please fix it soon???
      I know !
      The new API in v2017 breaks some things [references, IDs etc]
      I have been working on a fix for the last few weeks...
      It has proven awkward !
      Watch for updates...
      • pbacotP
        Thsnks TIG, Watching for this. Though I am holding off on using v2017.
        • GMthompsonG
          GMthompson
          i cannot get eebf to work in 2017 I have uninstalled and reinstalled 2017 one plugin at a time starting with freedo tools any suggestions
          you can learn something everyday by paying attention
            @gmthompson said:
            ...any suggestions
            Suggestions? Yes. Read TIG's last post in this thread. He's working on a fix. I'm sure when he has a suitable fix, he'll release an update.
              Update is 90% done... but it's not there yet...
              ๐Ÿ˜ฒ
                TIG, we are lucky to get these valuable tools in the first place, I am not going to be pushy over the fix, I can always sort the one piece of geometry in sketchup 2016 until this is sorted to your satisfaction. Many thanks for making sketchup better by your hard work.
                  jbnarch25
                  Updates needed for Sketchup 2017 on "Extrude Edges by Rails" , Lattice, face. Works good on 16 guess it has something to do with ruby 2.2 used in 17.
                    If you look a couple of posts earlier on in this thread, you'll see that the update is in progress...
                      I know 'they' broke it in v2017.
                      They changed the way exploded groups etc no longer keep an enduring reference to the contents !
                      I have fixed this in several plugins.
                      I have fixed it in this toolset too, but I;ve not reissued yet, because I have an intractable bugsplat occurring if the user does an undo after making some forms, in some of the tools.
                      This is very odd, since it seems unrelated to the main problem they created.
                      In essence, the paths [profiles/rails] are temporarily grouped during the processing to stop them getting messed up by the later processes. At the end it is exploded back as it was. That works fine, but if the user does an undo it bugsplats...
                      It is very odd.
                      I am considering alternative solutions...
                        simoncastle
                        Hi TIG thank you very much for these plugins.
                        I dont know if you are aware that "THEY" broke something in their API which causes the extrude on rails to fail in 2017, its still working correctly in 2016.
                        Im not sure what the problem is, I have a singe cure with 2 rails that join at a pint.
                        As I said its file in 2016. If you cant reproduce it let me know and I will try to upload my file.
                        Sorry for posting this, didn't read the latest posts.
                        Feeling stupid now.
                        ๐Ÿ˜ณ
                        ... Simon
                          rilian
                          @tig said:
                          It is very odd.
                          Bump? Any further news on your bugsplat?
                            I have most of the problems fixed.
                            However, I might need to recast how some of the tools exit, as I am finding that no permutations of the current exit strategies avoid a BugSplat !
                            ๐Ÿ˜ฎ
                              2k328ci
                              Hi TIG,
                              I love your tools especially this one! Glad you're working on a 2017 solution. Any news on possible updates? Thanks so much for all your efforts.
                                Here's v4.0
                                https://sketchucation.com/pluginstore?pln=ExtrudeTools
                                It's now recoded for v2017/v2018 compatibility.
                                However, please be aware it is more prone to BugSplats [especially with an 'undo'] in these newer SketchUp versions, so use with care and always remember to save your model before using these tools...
                                You've been warned !
                                • BoxB
                                  Thank you thank you thank you.
                                    Thx for the efforts! ๐Ÿ˜Ž
                                    • JQLJ
                                      JQL
                                      They will be the most welcome bugsplats. Thanks!
                                      www.casca.pt
                                      Visit us on facebook!
                                      • C
                                        Coolz8
                                        Hi TIG! There's a function of the Extrude Edges by Face tool that doesn't seem to work.
                                        https://www.youtube.com/watch?v=Oq55prLHBhs (Skip to 19:55)
                                        The first part works fine, but when working with multiple lines, nothing happens. This seems to work on earlier versions. Are we doing something wrong?
                                          I see the issue.
                                          I see the cause.
                                          I am working on a fix.
                                          [Looks like a stoopid typo !]
                                          Watch out for an update...
                                            rilian
                                            I ran into an issue w/ the lathe tool. Seems sometimes it doesn't put the starting and ending faces on the lathed object. Pics attached. The face created consists of 2 edges and 1 arc. I've tried making them all curves and even welding them all into one big arc to no avail. The fix is simple. I'm ok w/ it but thought I'd bring it up.
                                            Thanks Tig for all the great tools you've made and maintained over the years! Your work is heartily appreciated!! ๐Ÿ‘
                                            [edit] Using SU Make 2017 for Windows
                                            shows mesh before create. Vertical line is chosen axis of rotation
                                            Shows mesh post-create
                                            Shows fixed mesh and lines that had to be added to fix it.
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 30 / 32
