    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 991.0k Views 175 Watching
      @gmthompson said:
      ...any suggestions
      Suggestions? Yes. Read TIG's last post in this thread. He's working on a fix. I'm sure when he has a suitable fix, he'll release an update.
      • TIGT Online
        Update is 90% done... but it's not there yet...
        ๐Ÿ˜ฒ
          TIG, we are lucky to get these valuable tools in the first place, I am not going to be pushy over the fix, I can always sort the one piece of geometry in sketchup 2016 until this is sorted to your satisfaction. Many thanks for making sketchup better by your hard work.
            jbnarch25
            Updates needed for Sketchup 2017 on "Extrude Edges by Rails" , Lattice, face. Works good on 16 guess it has something to do with ruby 2.2 used in 17.
            • TIGT Online
              If you look a couple of posts earlier on in this thread, you'll see that the update is in progress...
              • TIGT Online
                I know 'they' broke it in v2017.
                They changed the way exploded groups etc no longer keep an enduring reference to the contents !
                I have fixed this in several plugins.
                I have fixed it in this toolset too, but I;ve not reissued yet, because I have an intractable bugsplat occurring if the user does an undo after making some forms, in some of the tools.
                This is very odd, since it seems unrelated to the main problem they created.
                In essence, the paths [profiles/rails] are temporarily grouped during the processing to stop them getting messed up by the later processes. At the end it is exploded back as it was. That works fine, but if the user does an undo it bugsplats...
                It is very odd.
                I am considering alternative solutions...
                  simoncastle
                  Hi TIG thank you very much for these plugins.
                  I dont know if you are aware that "THEY" broke something in their API which causes the extrude on rails to fail in 2017, its still working correctly in 2016.
                  Im not sure what the problem is, I have a singe cure with 2 rails that join at a pint.
                  As I said its file in 2016. If you cant reproduce it let me know and I will try to upload my file.
                  Sorry for posting this, didn't read the latest posts.
                  Feeling stupid now.
                  ๐Ÿ˜ณ
                  ... Simon
                    rilian
                    @tig said:
                    It is very odd.
                    Bump? Any further news on your bugsplat?
                    • TIGT Online
                      I have most of the problems fixed.
                      However, I might need to recast how some of the tools exit, as I am finding that no permutations of the current exit strategies avoid a BugSplat !
                      ๐Ÿ˜ฎ
                      • 2 Offline
                        2k328ci
                        Hi TIG,
                        I love your tools especially this one! Glad you're working on a 2017 solution. Any news on possible updates? Thanks so much for all your efforts.
                        • TIGT Online
                          Here's v4.0
                          https://sketchucation.com/pluginstore?pln=ExtrudeTools
                          It's now recoded for v2017/v2018 compatibility.
                          However, please be aware it is more prone to BugSplats [especially with an 'undo'] in these newer SketchUp versions, so use with care and always remember to save your model before using these tools...
                          You've been warned !
                          • BoxB Offline
                            Thank you thank you thank you.
                              Thx for the efforts! ๐Ÿ˜Ž
                              • JQLJ Offline
                                JQL
                                They will be the most welcome bugsplats. Thanks!
                                www.casca.pt
                                Visit us on facebook!
                                  Coolz8
                                  Hi TIG! There's a function of the Extrude Edges by Face tool that doesn't seem to work.
                                  https://www.youtube.com/watch?v=Oq55prLHBhs (Skip to 19:55)
                                  The first part works fine, but when working with multiple lines, nothing happens. This seems to work on earlier versions. Are we doing something wrong?
                                  • TIGT Online
                                    I see the issue.
                                    I see the cause.
                                    I am working on a fix.
                                    [Looks like a stoopid typo !]
                                    Watch out for an update...
                                      rilian
                                      I ran into an issue w/ the lathe tool. Seems sometimes it doesn't put the starting and ending faces on the lathed object. Pics attached. The face created consists of 2 edges and 1 arc. I've tried making them all curves and even welding them all into one big arc to no avail. The fix is simple. I'm ok w/ it but thought I'd bring it up.
                                      Thanks Tig for all the great tools you've made and maintained over the years! Your work is heartily appreciated!! ๐Ÿ‘
                                      [edit] Using SU Make 2017 for Windows
                                      shows mesh before create. Vertical line is chosen axis of rotation
                                      Shows mesh post-create
                                      Shows fixed mesh and lines that had to be added to fix it.
                                      • E Offline
                                        Einstein
                                        Hi!
                                        Your tool always asks a lot of questions and honestly, it takes time to answer them. What about some dialog box to set default parameters for each sub-tool, like Fredo does, and do not prompting questions every time after making an extrusion?
                                        • Didier BurD Offline
                                          Didier Bur
                                          If it takes you time to answer several question, ask yourself how many hours TIG spent writing this plugin, or draw your extrusion by hand, you surely will go faster ๐Ÿ˜‰
                                          DB
                                            Maybe TIG could release a commercial version that offers some user set parameters instead of the way the free version works.
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 30 / 32
