    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 768.3k Views 175 Watching
    • F Offline
      fergutierrezg
      Holaa ! Me podrĂ­as decir como descargo el plugin? por favor, no encuentro el link de descarga...
        Look at the bottom of the first post.
        • E Offline
          Extractor
          Hi there,
          I have problems with Extrude Tools and Sketchup 2017:
          Even after disabling all other plugins I get the following results running for instance “Extrude Edges by Rails” or “Extrude Edges by Rails To Lattice”:
          The tool only creates the control/construction points (no faces) and I get some information in the Ruby Console:
          Another example: “Extrude Edges by Loft” creates triangulated faces but no Quad Faces if I select this option.
          (Some information: Extrude Tools 3.0 (I installed it using the SketchUcation Tool, no problems with Sketchup 2016, system: windows 7, 64 bit, Intel i7 3770, NVidia GTX 750 Ti, drivers: 375.57 and the newest 375.86)
          Any ideas?
            Thanks for the reports.
            I see it too... investigating...
            It's the way v2017 replaces an exploded entity with a duplicate, with another ID, and so you can no longer collect a reference to it before exploding, it must be done as part of the explode itself to get the correct reference...
            Working on it - I suspect it affects many of the tools...
            • CadFatherC Offline
              CadFather
              Hi TIG - if you can - have a look at the offset please, it seems the reading is slightly off (no pun!). didn't have time to look at the code myself
                The whole ExtrudeToolset is foobar thanks to the way v2017 handles exploded entities and looses references but while keeping id's...
                I'm working on a fix... 😮
                  CadFather
                  yes, the offset was always a smidge off (only in terms of measurements) - other than that, the script works fine on both (on my super system of course), thanks!
                  • H Offline
                    hell0304
                    It's worked great on SU2016 but some Error happen on SU2017. Can u please fix it soon???
                      I know !
                      The new API in v2017 breaks some things [references, IDs etc]
                      I have been working on a fix for the last few weeks...
                      It has proven awkward !
                      Watch for updates...
                      • pbacotP Offline
                        Thsnks TIG, Watching for this. Though I am holding off on using v2017.
                        • GMthompsonG Offline
                          GMthompson
                          i cannot get eebf to work in 2017 I have uninstalled and reinstalled 2017 one plugin at a time starting with freedo tools any suggestions
                          you can learn something everyday by paying attention
                            @gmthompson said:
                            ...any suggestions
                            Suggestions? Yes. Read TIG's last post in this thread. He's working on a fix. I'm sure when he has a suitable fix, he'll release an update.
                              Update is 90% done... but it's not there yet...
                                TIG, we are lucky to get these valuable tools in the first place, I am not going to be pushy over the fix, I can always sort the one piece of geometry in sketchup 2016 until this is sorted to your satisfaction. Many thanks for making sketchup better by your hard work.
                                  jbnarch25
                                  Updates needed for Sketchup 2017 on "Extrude Edges by Rails" , Lattice, face. Works good on 16 guess it has something to do with ruby 2.2 used in 17.
                                    If you look a couple of posts earlier on in this thread, you'll see that the update is in progress...
                                      I know 'they' broke it in v2017.
                                      They changed the way exploded groups etc no longer keep an enduring reference to the contents !
                                      I have fixed this in several plugins.
                                      I have fixed it in this toolset too, but I;ve not reissued yet, because I have an intractable bugsplat occurring if the user does an undo after making some forms, in some of the tools.
                                      This is very odd, since it seems unrelated to the main problem they created.
                                      In essence, the paths [profiles/rails] are temporarily grouped during the processing to stop them getting messed up by the later processes. At the end it is exploded back as it was. That works fine, but if the user does an undo it bugsplats...
                                      It is very odd.
                                      I am considering alternative solutions...
                                        simoncastle
                                        Hi TIG thank you very much for these plugins.
                                        I dont know if you are aware that "THEY" broke something in their API which causes the extrude on rails to fail in 2017, its still working correctly in 2016.
                                        Im not sure what the problem is, I have a singe cure with 2 rails that join at a pint.
                                        As I said its file in 2016. If you cant reproduce it let me know and I will try to upload my file.
                                        Sorry for posting this, didn't read the latest posts.
                                        Feeling stupid now.
                                        ... Simon
                                          rilian
                                          @tig said:
                                          It is very odd.
                                          Bump? Any further news on your bugsplat?
                                            I have most of the problems fixed.
                                            However, I might need to recast how some of the tools exit, as I am finding that no permutations of the current exit strategies avoid a BugSplat !
                                            • 31
                                            • 32
                                            • 2 / 32
