    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 926.6k Views 172 Watching
      SketchyPhysicsNutt
      Thanks Anton for fixing the full-screen issue my animations are back to normal πŸ˜„
      MSPhysics 0.9.9
      tested on win 8.1 and sketchup 2015/2016 working fine.
      the new plane joint works great on single or two different planes πŸ‘
      thx again and merry xmas
      Tez
        Anton_S
        Hello, Tez,
        Good to hear that it's working now. And merry Christmas to you too!
        Best regards,
        Anton
          SketchyPhysicsNutt
          Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
          in Sketchyphysics i just tick the OnTouch panel and use
          playSound('Sound1')
          what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error?
          its no bug ..just me don't understand MS scripts yet.
          Tez
          • robintR Offline
            robint
            Hi Anton, installed 0.9.9 and restarted SU
            but its screwed up my model?
            It falls downwards and I cant get the static floor to work as before, also the script stopped working
            Did I do a corrupt installation?
            Should I have deleted 0.9.8 first - you didnt say?
            I assumed it would overwrite and update itself
            Where to go? delete and start fresh installation or go back to 0.9.8?
            What to do? 😳
            Robin
            falling block7.skp
            As one door closes another one slams in your face
              Anton_S
              Tez,
              In the Sound tab of the MSPhysics UI, whenever a sound is added, a piece of code for playing the sounds is displayed below. For your case, after you add the sound to the MSPhysics UI, the code for playing it would be:
              onTouch { |toucher, position, normal, force, speed|
                simulation.play_sound("Sound1")
              You can also refer to this scripting documentation link for playing 3D sounds: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/master/file/Overview.md#Music___Sound
              Anton
                Anton_S
                Robin,
                I assume the script you talk about is the controllable sphere thingy. There has been some scripting changes and the documentation for the controllable sphere is updated. For your case, you will have to replace the add_force2 function with the add_force function.
                Now, I don't know how the static floor behaved previously. Basing on the model you posted, everything is working fine. I don't see any issues.
                If you want to revert to on original version, you may always refer to the instructions on the homepage.
                Anton
                • robintR Offline
                  robint
                  Very strange Anton, I removed the sphere from the model to avaoid confusion , but on mine Falling block 7 the whole model falls. I must assume I got a corrupt installation, so will start again afresh back to 0.9.8 and fb 6
                  Cheers
                  Robin
                  • robintR Offline
                    robint
                    I am pleased to report, that after a tedious uninstall of msp and a clean instal of 0.9.9, everything now seems to work ok
                    Overwriting existing files looks unwise and it was severely screwed up
                    I would advise users
                    Cheers
                    Robin
                    PS I made the block and floor out of tungsten carbide, so the block didnt penetrate AKAIK, but bounces as expected
                    falling block8.skp
                    • F Offline
                      faust07
                      Thanks Anton for making MSPhysics better and better. First impression of running an old model with Curvy Pistons with version 0.9.9 - all moves but some objects move backwards... - I will test in the next days what I must change to get the desired results.
                      Merry Christmas to all friends of SketchUp, physics and animation.
                      • robintR Offline
                        robint
                        Hi MSP's
                        Herewith my mortar gun model, run and tap space bar, adjust azimuth with rotate tool on all the gun. Adjust charge by piston rate
                        I thought I might add display of distance to first landing (just like a real gun spotter?
                        mortar.skp
                          SketchyPhysicsNutt
                          Hi robint your original model falling block8 and script anton
                          helped u with i found very interesting thx.
                          I set block material to gold / elasticity to 2.00 and got a
                          bouncing ball i like the affect max elasticity gives u.
                          Gif starts on 2nd bounce then breaks free on 3rd and keeps bouncing
                          http://s24.postimg.org/41779b5dx/bounce.gif
                          Tez
                          • robintR Offline
                            robint
                            Indeed, it becomes quite addictive I found. I wish I knew more about ruby script
                            I want to xfer the script to my mortar gun, try to get muzzle velocity, distance to target and time of flight
                            cheers, have fun
                            Robin
                              SketchyPhysicsNutt
                              Im no script monkey as well wish i was....but im experimenting connecting two servo's for swivel and tilt with your mortar gun model no luck yet πŸ˜„
                              Antons original script has come in handy with my trebuchet/catapult models and projectiles
                              THX Robin happy new year
                              Tez
                              • robintR Offline
                                robint
                                Yes I tried that, but the outer gun barrel has to be made up of 4 flat slabs grouped together and made static which is why it wont move, else the ball just falls through it
                                only way I found was to use the rotate tool before hitting go
                                not very elegant
                                perhaps someone else will pitch in
                                Cheers
                                Robin
                                • robintR Offline
                                  robint
                                  Anyone know how to put sound into script eg a sound wav called "cannon" to be played when I press space bar (which also fires the cannon ball
                                  I put the sound byte into the UI sound tab, but nothing happens? WOTODO?
                                  Robin
                                    PituPhysics
                                    Robin
                                    Hello Robin. I wrote a script to display the distance of bullet and target, the time of flight and play the sound. But the "Update Timestep" change it to Normal 1/60 on the Simulation tab.
                                    Try this:
                                    mortar 2.skp
                                      SketchyPhysicsNutt
                                      Great script inside PituPhysics 'Distance and time of flight' perfect for projectiles
                                      thx
                                      Tez
                                      • robintR Offline
                                        robint
                                        Hi PP
                                        some good stuff there, doesnt make the sound?
                                        take a look at my falling block as it uses the ontouch procedure to capture the distance at the moment of first impact
                                        Another way might be to insert some magnetism into the ball, floor and target so that the missile sticks to its first landing place, as with a real mortar
                                        Have tried to use magnetism in UI but doesnt seem to have any effect? 😲
                                        What am I doing wrong?
                                        Robin
                                        mortar 3.skp
                                          PituPhysics
                                          I made more models to be more opportunities.
                                          1.) Frozen: mortar 4.1.skp
                                          2.) Hide: mortar 4.2.skp
                                          3.) Simulation pause: mortar 4.3.skp
                                          And magnet test:magnet.skp
                                          • robintR Offline
                                            robint
                                            Hi PP
                                            tried your magnet and I am baffled as to why its so very slow, <2fps. tried everything to speed it up. Sketchy physic was much faster? I made ther executive balls desktop toy by putting all the balls as pendulums in a frame and colliding. It was fast and realistic?
                                            Robin
                                            • 46
                                            • 47
                                            • 5 / 47
