    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      SketchyPhysicsNutt
      Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
      in Sketchyphysics i just tick the OnTouch panel and use
      playSound('Sound1')
      what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error?
      its no bug ..just me don't understand MS scripts yet.
      Tez
      • robintR
        robint
        Hi Anton, installed 0.9.9 and restarted SU
        but its screwed up my model?
        It falls downwards and I cant get the static floor to work as before, also the script stopped working
        Did I do a corrupt installation?
        Should I have deleted 0.9.8 first - you didnt say?
        I assumed it would overwrite and update itself
        Where to go? delete and start fresh installation or go back to 0.9.8?
        What to do? 😳
        Robin
        falling block7.skp
        As one door closes another one slams in your face
          Anton_S
          Tez,
          In the Sound tab of the MSPhysics UI, whenever a sound is added, a piece of code for playing the sounds is displayed below. For your case, after you add the sound to the MSPhysics UI, the code for playing it would be:
          onTouch { |toucher, position, normal, force, speed|
            simulation.play_sound("Sound1")
          You can also refer to this scripting documentation link for playing 3D sounds: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/master/file/Overview.md#Music___Sound
          Anton
            Anton_S
            Robin,
            I assume the script you talk about is the controllable sphere thingy. There has been some scripting changes and the documentation for the controllable sphere is updated. For your case, you will have to replace the add_force2 function with the add_force function.
            Now, I don't know how the static floor behaved previously. Basing on the model you posted, everything is working fine. I don't see any issues.
            If you want to revert to on original version, you may always refer to the instructions on the homepage.
            Anton
            • robintR
              robint
              Very strange Anton, I removed the sphere from the model to avaoid confusion , but on mine Falling block 7 the whole model falls. I must assume I got a corrupt installation, so will start again afresh back to 0.9.8 and fb 6
              Cheers
              Robin
              • robintR
                robint
                I am pleased to report, that after a tedious uninstall of msp and a clean instal of 0.9.9, everything now seems to work ok
                Overwriting existing files looks unwise and it was severely screwed up
                I would advise users
                Cheers
                Robin
                PS I made the block and floor out of tungsten carbide, so the block didnt penetrate AKAIK, but bounces as expected
                falling block8.skp
                • F
                  faust07
                  Thanks Anton for making MSPhysics better and better. First impression of running an old model with Curvy Pistons with version 0.9.9 - all moves but some objects move backwards... - I will test in the next days what I must change to get the desired results.
                  Merry Christmas to all friends of SketchUp, physics and animation.
                  • robintR
                    robint
                    Hi MSP's
                    Herewith my mortar gun model, run and tap space bar, adjust azimuth with rotate tool on all the gun. Adjust charge by piston rate
                    I thought I might add display of distance to first landing (just like a real gun spotter?
                    mortar.skp
                      SketchyPhysicsNutt
                      Hi robint your original model falling block8 and script anton
                      helped u with i found very interesting thx.
                      I set block material to gold / elasticity to 2.00 and got a
                      bouncing ball i like the affect max elasticity gives u.
                      Gif starts on 2nd bounce then breaks free on 3rd and keeps bouncing
                      http://s24.postimg.org/41779b5dx/bounce.gif
                      Tez
                      • robintR
                        robint
                        Indeed, it becomes quite addictive I found. I wish I knew more about ruby script
                        I want to xfer the script to my mortar gun, try to get muzzle velocity, distance to target and time of flight
                        cheers, have fun
                        Robin
                          SketchyPhysicsNutt
                          Im no script monkey as well wish i was....but im experimenting connecting two servo's for swivel and tilt with your mortar gun model no luck yet πŸ˜„
                          Antons original script has come in handy with my trebuchet/catapult models and projectiles
                          THX Robin happy new year
                          Tez
                          • robintR
                            robint
                            Yes I tried that, but the outer gun barrel has to be made up of 4 flat slabs grouped together and made static which is why it wont move, else the ball just falls through it
                            only way I found was to use the rotate tool before hitting go
                            not very elegant
                            perhaps someone else will pitch in
                            Cheers
                            Robin
                            • robintR
                              robint
                              Anyone know how to put sound into script eg a sound wav called "cannon" to be played when I press space bar (which also fires the cannon ball
                              I put the sound byte into the UI sound tab, but nothing happens? WOTODO?
                              Robin
                              • P
                                PituPhysics
                                Robin
                                Hello Robin. I wrote a script to display the distance of bullet and target, the time of flight and play the sound. But the "Update Timestep" change it to Normal 1/60 on the Simulation tab.
                                Try this:
                                mortar 2.skp
                                  SketchyPhysicsNutt
                                  Great script inside PituPhysics 'Distance and time of flight' perfect for projectiles
                                  thx
                                  Tez
                                  • robintR
                                    robint
                                    Hi PP
                                    some good stuff there, doesnt make the sound?
                                    take a look at my falling block as it uses the ontouch procedure to capture the distance at the moment of first impact
                                    Another way might be to insert some magnetism into the ball, floor and target so that the missile sticks to its first landing place, as with a real mortar
                                    Have tried to use magnetism in UI but doesnt seem to have any effect? 😲
                                    What am I doing wrong?
                                    Robin
                                    mortar 3.skp
                                    • P
                                      PituPhysics
                                      I made more models to be more opportunities.
                                      1.) Frozen: mortar 4.1.skp
                                      2.) Hide: mortar 4.2.skp
                                      3.) Simulation pause: mortar 4.3.skp
                                      And magnet test:magnet.skp
                                      • robintR
                                        robint
                                        Hi PP
                                        tried your magnet and I am baffled as to why its so very slow, <2fps. tried everything to speed it up. Sketchy physic was much faster? I made ther executive balls desktop toy by putting all the balls as pendulums in a frame and colliding. It was fast and realistic?
                                        Robin
                                        • robintR
                                          robint
                                          Even stranger, I managed to get my balls to clang together at 30 fps, but unable to simulate repulsion even with negative magnet values? I notice that perhaps magnet is a wrong term as it behave more like gravity between two masses (hence no repulsion effect)
                                          Universal gravitation equation
                                          F = GMm/R2
                                          where
                                          F is the force of attraction between two objects in newtons (N)
                                          G is the Universal Gravitational Constant = 6.674*10βˆ’11 N-m2/kg2
                                          M and m are the masses of the two objects in kilograms (kg)
                                          R is the separation in meters (m) between the objects, as measured from their centers of mass
                                          notice how the ball is attracted to the target even though the target has no magnetic force
                                          for example
                                          Robin
                                          my magnetic balls 1.skp
                                          • robintR
                                            robint
                                            Hi PP
                                            Got as far as 4.3 and it certainly is the cats whiskers, like the disappering effect in 4.2, all we need is a little pop up explosion (still no sound on mine?)
                                            I dont understand what is affecting the fps so drastically? It goes from 30fps down to 4 or less
                                            Robin
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 46
                                            • 47
                                            • 27 / 47
