    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
      Anton_S
      Very clever, gilles!
      I'm sure there is a way to improve performance and stiffness of that thing.
      Anton
      • gillesG Offline
        gilles
        Thรฉo Jansen.
        http://www.strandbeest.com/index.php ๐Ÿ‘
          The peaceful robots! ๐Ÿ˜Ž
          • gillesG Offline
            gilles
            I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
            Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
            Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
            Just for anybody else having the same troubles.
            Mac OSX 10.8.5, SU2015.
              Anton_S
              Yeah, I'm working on that. Thanks for the report, gilles!
              • robintR Offline
                robint
                [attachment=0:3sqfwcxi]<!-- ia0 -->MS-UI.gif<!-- ia0 -->[/attachment:3sqfwcxi]
                Hi gilles
                I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry
                kinda convoluted
                Robin
                As one door closes another one slams in your face
                  Anton_S
                  Announcing 0.9.9!
                  This version comes with mainly an improved dialog and joints.
                  View changelog for details: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                  Anton
                    SketchyPhysicsNutt
                    Thanks Anton for fixing the full-screen issue my animations are back to normal ๐Ÿ˜„
                    MSPhysics 0.9.9
                    tested on win 8.1 and sketchup 2015/2016 working fine.
                    the new plane joint works great on single or two different planes ๐Ÿ‘
                    thx again and merry xmas
                    Tez
                      Anton_S
                      Hello, Tez,
                      Good to hear that it's working now. And merry Christmas to you too!
                      Best regards,
                      Anton
                        SketchyPhysicsNutt
                        Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
                        in Sketchyphysics i just tick the OnTouch panel and use
                        playSound('Sound1')
                        what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error?
                        its no bug ..just me don't understand MS scripts yet.
                        Tez
                        • robintR Offline
                          robint
                          Hi Anton, installed 0.9.9 and restarted SU
                          but its screwed up my model?
                          It falls downwards and I cant get the static floor to work as before, also the script stopped working
                          Did I do a corrupt installation?
                          Should I have deleted 0.9.8 first - you didnt say?
                          I assumed it would overwrite and update itself
                          Where to go? delete and start fresh installation or go back to 0.9.8?
                          What to do? ๐Ÿ˜ณ
                          Robin
                          falling block7.skp
                            Anton_S
                            Tez,
                            In the Sound tab of the MSPhysics UI, whenever a sound is added, a piece of code for playing the sounds is displayed below. For your case, after you add the sound to the MSPhysics UI, the code for playing it would be:
                            onTouch { |toucher, position, normal, force, speed|
                              simulation.play_sound("Sound1")
                            You can also refer to this scripting documentation link for playing 3D sounds: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/master/file/Overview.md#Music___Sound
                            Anton
                              Anton_S
                              Robin,
                              I assume the script you talk about is the controllable sphere thingy. There has been some scripting changes and the documentation for the controllable sphere is updated. For your case, you will have to replace the add_force2 function with the add_force function.
                              Now, I don't know how the static floor behaved previously. Basing on the model you posted, everything is working fine. I don't see any issues.
                              If you want to revert to on original version, you may always refer to the instructions on the homepage.
                              Anton
                              • robintR Offline
                                robint
                                Very strange Anton, I removed the sphere from the model to avaoid confusion , but on mine Falling block 7 the whole model falls. I must assume I got a corrupt installation, so will start again afresh back to 0.9.8 and fb 6
                                Cheers
                                Robin
                                • robintR Offline
                                  robint
                                  I am pleased to report, that after a tedious uninstall of msp and a clean instal of 0.9.9, everything now seems to work ok
                                  Overwriting existing files looks unwise and it was severely screwed up
                                  I would advise users
                                  Cheers
                                  Robin
                                  PS I made the block and floor out of tungsten carbide, so the block didnt penetrate AKAIK, but bounces as expected
                                  falling block8.skp
                                  • F Offline
                                    faust07
                                    Thanks Anton for making MSPhysics better and better. First impression of running an old model with Curvy Pistons with version 0.9.9 - all moves but some objects move backwards... - I will test in the next days what I must change to get the desired results.
                                    Merry Christmas to all friends of SketchUp, physics and animation.
                                    • robintR Offline
                                      robint
                                      Hi MSP's
                                      Herewith my mortar gun model, run and tap space bar, adjust azimuth with rotate tool on all the gun. Adjust charge by piston rate
                                      I thought I might add display of distance to first landing (just like a real gun spotter?
                                      mortar.skp
                                        SketchyPhysicsNutt
                                        Hi robint your original model falling block8 and script anton
                                        helped u with i found very interesting thx.
                                        I set block material to gold / elasticity to 2.00 and got a
                                        bouncing ball i like the affect max elasticity gives u.
                                        Gif starts on 2nd bounce then breaks free on 3rd and keeps bouncing
                                        http://s24.postimg.org/41779b5dx/bounce.gif
                                        Tez
                                        • robintR Offline
                                          robint
                                          Indeed, it becomes quite addictive I found. I wish I knew more about ruby script
                                          I want to xfer the script to my mortar gun, try to get muzzle velocity, distance to target and time of flight
                                          cheers, have fun
                                          Robin
                                            SketchyPhysicsNutt
                                            Im no script monkey as well wish i was....but im experimenting connecting two servo's for swivel and tilt with your mortar gun model no luck yet ๐Ÿ˜„
                                            Antons original script has come in handy with my trebuchet/catapult models and projectiles
                                            THX Robin happy new year
                                            Tez
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 46
                                            • 47
                                            • 26 / 47
