    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • F
      faust07
      Thanks Anton for making MSPhysics better and better. First impression of running an old model with Curvy Pistons with version 0.9.9 - all moves but some objects move backwards... - I will test in the next days what I must change to get the desired results.
      Merry Christmas to all friends of SketchUp, physics and animation.
      • robintR
        robint
        Hi MSP's
        Herewith my mortar gun model, run and tap space bar, adjust azimuth with rotate tool on all the gun. Adjust charge by piston rate
        I thought I might add display of distance to first landing (just like a real gun spotter?
        mortar.skp
        As one door closes another one slams in your face
          SketchyPhysicsNutt
          Hi robint your original model falling block8 and script anton
          helped u with i found very interesting thx.
          I set block material to gold / elasticity to 2.00 and got a
          bouncing ball i like the affect max elasticity gives u.
          Gif starts on 2nd bounce then breaks free on 3rd and keeps bouncing
          http://s24.postimg.org/41779b5dx/bounce.gif
          Tez
          • robintR
            robint
            Indeed, it becomes quite addictive I found. I wish I knew more about ruby script
            I want to xfer the script to my mortar gun, try to get muzzle velocity, distance to target and time of flight
            cheers, have fun
            Robin
              SketchyPhysicsNutt
              Im no script monkey as well wish i was....but im experimenting connecting two servo's for swivel and tilt with your mortar gun model no luck yet πŸ˜„
              Antons original script has come in handy with my trebuchet/catapult models and projectiles
              THX Robin happy new year
              Tez
              • robintR
                robint
                Yes I tried that, but the outer gun barrel has to be made up of 4 flat slabs grouped together and made static which is why it wont move, else the ball just falls through it
                only way I found was to use the rotate tool before hitting go
                not very elegant
                perhaps someone else will pitch in
                Cheers
                Robin
                • robintR
                  robint
                  Anyone know how to put sound into script eg a sound wav called "cannon" to be played when I press space bar (which also fires the cannon ball
                  I put the sound byte into the UI sound tab, but nothing happens? WOTODO?
                  Robin
                  • P
                    PituPhysics
                    Robin
                    Hello Robin. I wrote a script to display the distance of bullet and target, the time of flight and play the sound. But the "Update Timestep" change it to Normal 1/60 on the Simulation tab.
                    Try this:
                    mortar 2.skp
                      SketchyPhysicsNutt
                      Great script inside PituPhysics 'Distance and time of flight' perfect for projectiles
                      thx
                      Tez
                      • robintR
                        robint
                        Hi PP
                        some good stuff there, doesnt make the sound?
                        take a look at my falling block as it uses the ontouch procedure to capture the distance at the moment of first impact
                        Another way might be to insert some magnetism into the ball, floor and target so that the missile sticks to its first landing place, as with a real mortar
                        Have tried to use magnetism in UI but doesnt seem to have any effect? 😲
                        What am I doing wrong?
                        Robin
                        mortar 3.skp
                        • P
                          PituPhysics
                          I made more models to be more opportunities.
                          1.) Frozen: mortar 4.1.skp
                          2.) Hide: mortar 4.2.skp
                          3.) Simulation pause: mortar 4.3.skp
                          And magnet test:magnet.skp
                          • robintR
                            robint
                            Hi PP
                            tried your magnet and I am baffled as to why its so very slow, <2fps. tried everything to speed it up. Sketchy physic was much faster? I made ther executive balls desktop toy by putting all the balls as pendulums in a frame and colliding. It was fast and realistic?
                            Robin
                            • robintR
                              robint
                              Even stranger, I managed to get my balls to clang together at 30 fps, but unable to simulate repulsion even with negative magnet values? I notice that perhaps magnet is a wrong term as it behave more like gravity between two masses (hence no repulsion effect)
                              Universal gravitation equation
                              F = GMm/R2
                              where
                              F is the force of attraction between two objects in newtons (N)
                              G is the Universal Gravitational Constant = 6.674*10βˆ’11 N-m2/kg2
                              M and m are the masses of the two objects in kilograms (kg)
                              R is the separation in meters (m) between the objects, as measured from their centers of mass
                              notice how the ball is attracted to the target even though the target has no magnetic force
                              for example
                              Robin
                              my magnetic balls 1.skp
                              • robintR
                                robint
                                Hi PP
                                Got as far as 4.3 and it certainly is the cats whiskers, like the disappering effect in 4.2, all we need is a little pop up explosion (still no sound on mine?)
                                I dont understand what is affecting the fps so drastically? It goes from 30fps down to 4 or less
                                Robin
                                • robintR
                                  robint
                                  Playing with real shells. Wonder how I can get the nose pointing along the path? hmmm ❓ notice the fps is 27, yet on some of the models its very slow 2fps
                                  mortar 5.1.skp
                                  • P
                                    PituPhysics
                                    For me 63 fps.
                                    mortar 5.2.skp
                                    • robintR
                                      robint
                                      Wow PP that has blown me away, havent looked into detail yet, tomorrow am
                                      Now could this be mounted on a tank? Forward, left, right track
                                      Then we could have two or more, multi players
                                      Tank battle, forests, obstacles, terrain, mines, smoke etc
                                      Pls assume all rights, I'll be your beta tester and write the manual
                                      Robin
                                      Ps I wrote a game like this in BASIC years ago, for four players, it was extemely addictive, hidng under tree cover trying to guess where you opponents were. Each tank had a home base corner and had to return for new ammo and fuel. we spent hours on it
                                      I turned this into a kids game sliding around on mats on a polished wood floor blindfold, getting coded instruction from their base commanders. They fired foam tennis balls at each other and only had three reserve tanks. Couldn't get them out of the classroom, oh and they had to give their instructions in a foreign language, French German, Italian and swedish - a summer uni job - but the kids loved it
                                      Robin
                                      • robintR
                                        robint
                                        Hi PP
                                        changed the angle so its a cannon 0 - 80deg azimuth control
                                        just gets better πŸ˜„
                                        mortar 5.3.skp
                                        • I
                                          INVR
                                          I have a little issue where sometimes when I run the sim (simple hinges) it starts scanning and objects seem to disappear. I can control the camera and see them or half of the object. But it gets worse and worst until I have to reset it. Is there any steps I can take to fix this?
                                            Anton_S
                                            INVR, camera clipping is very like caused by some objects falling down too far away from camera. To fix this, find the objects that fall down non stop and draw a floor below them or set them to ignore if they are not necessary for the simulation. These objects could be hidden groups or hidden layers. So uif you unhinde everything, and run simulation, you should be able to notice which objects do that.
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 46
                                            • 47
                                            • 27 / 47
