    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 927.6k Views 172 Watching
      Anton_S
      Announcing 0.9.9!
      This version comes with mainly an improved dialog and joints.
      View changelog for details: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
      Anton
        SketchyPhysicsNutt
        Thanks Anton for fixing the full-screen issue my animations are back to normal πŸ˜„
        MSPhysics 0.9.9
        tested on win 8.1 and sketchup 2015/2016 working fine.
        the new plane joint works great on single or two different planes πŸ‘
        thx again and merry xmas
        Tez
          Anton_S
          Hello, Tez,
          Good to hear that it's working now. And merry Christmas to you too!
          Best regards,
          Anton
            SketchyPhysicsNutt
            Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
            in Sketchyphysics i just tick the OnTouch panel and use
            playSound('Sound1')
            what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error?
            its no bug ..just me don't understand MS scripts yet.
            Tez
            • robintR Offline
              robint
              Hi Anton, installed 0.9.9 and restarted SU
              but its screwed up my model?
              It falls downwards and I cant get the static floor to work as before, also the script stopped working
              Did I do a corrupt installation?
              Should I have deleted 0.9.8 first - you didnt say?
              I assumed it would overwrite and update itself
              Where to go? delete and start fresh installation or go back to 0.9.8?
              What to do? 😳
              Robin
              falling block7.skp
              As one door closes another one slams in your face
                Anton_S
                Tez,
                In the Sound tab of the MSPhysics UI, whenever a sound is added, a piece of code for playing the sounds is displayed below. For your case, after you add the sound to the MSPhysics UI, the code for playing it would be:
                onTouch { |toucher, position, normal, force, speed|
                  simulation.play_sound("Sound1")
                You can also refer to this scripting documentation link for playing 3D sounds: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/master/file/Overview.md#Music___Sound
                Anton
                  Anton_S
                  Robin,
                  I assume the script you talk about is the controllable sphere thingy. There has been some scripting changes and the documentation for the controllable sphere is updated. For your case, you will have to replace the add_force2 function with the add_force function.
                  Now, I don't know how the static floor behaved previously. Basing on the model you posted, everything is working fine. I don't see any issues.
                  If you want to revert to on original version, you may always refer to the instructions on the homepage.
                  Anton
                  • robintR Offline
                    robint
                    Very strange Anton, I removed the sphere from the model to avaoid confusion , but on mine Falling block 7 the whole model falls. I must assume I got a corrupt installation, so will start again afresh back to 0.9.8 and fb 6
                    Cheers
                    Robin
                    • robintR Offline
                      robint
                      I am pleased to report, that after a tedious uninstall of msp and a clean instal of 0.9.9, everything now seems to work ok
                      Overwriting existing files looks unwise and it was severely screwed up
                      I would advise users
                      Cheers
                      Robin
                      PS I made the block and floor out of tungsten carbide, so the block didnt penetrate AKAIK, but bounces as expected
                      falling block8.skp
                      • F Offline
                        faust07
                        Thanks Anton for making MSPhysics better and better. First impression of running an old model with Curvy Pistons with version 0.9.9 - all moves but some objects move backwards... - I will test in the next days what I must change to get the desired results.
                        Merry Christmas to all friends of SketchUp, physics and animation.
                        • robintR Offline
                          robint
                          Hi MSP's
                          Herewith my mortar gun model, run and tap space bar, adjust azimuth with rotate tool on all the gun. Adjust charge by piston rate
                          I thought I might add display of distance to first landing (just like a real gun spotter?
                          mortar.skp
                            SketchyPhysicsNutt
                            Hi robint your original model falling block8 and script anton
                            helped u with i found very interesting thx.
                            I set block material to gold / elasticity to 2.00 and got a
                            bouncing ball i like the affect max elasticity gives u.
                            Gif starts on 2nd bounce then breaks free on 3rd and keeps bouncing
                            http://s24.postimg.org/41779b5dx/bounce.gif
                            Tez
                            • robintR Offline
                              robint
                              Indeed, it becomes quite addictive I found. I wish I knew more about ruby script
                              I want to xfer the script to my mortar gun, try to get muzzle velocity, distance to target and time of flight
                              cheers, have fun
                              Robin
                                SketchyPhysicsNutt
                                Im no script monkey as well wish i was....but im experimenting connecting two servo's for swivel and tilt with your mortar gun model no luck yet πŸ˜„
                                Antons original script has come in handy with my trebuchet/catapult models and projectiles
                                THX Robin happy new year
                                Tez
                                • robintR Offline
                                  robint
                                  Yes I tried that, but the outer gun barrel has to be made up of 4 flat slabs grouped together and made static which is why it wont move, else the ball just falls through it
                                  only way I found was to use the rotate tool before hitting go
                                  not very elegant
                                  perhaps someone else will pitch in
                                  Cheers
                                  Robin
                                  • robintR Offline
                                    robint
                                    Anyone know how to put sound into script eg a sound wav called "cannon" to be played when I press space bar (which also fires the cannon ball
                                    I put the sound byte into the UI sound tab, but nothing happens? WOTODO?
                                    Robin
                                      PituPhysics
                                      Robin
                                      Hello Robin. I wrote a script to display the distance of bullet and target, the time of flight and play the sound. But the "Update Timestep" change it to Normal 1/60 on the Simulation tab.
                                      Try this:
                                      mortar 2.skp
                                        SketchyPhysicsNutt
                                        Great script inside PituPhysics 'Distance and time of flight' perfect for projectiles
                                        thx
                                        Tez
                                        • robintR Offline
                                          robint
                                          Hi PP
                                          some good stuff there, doesnt make the sound?
                                          take a look at my falling block as it uses the ontouch procedure to capture the distance at the moment of first impact
                                          Another way might be to insert some magnetism into the ball, floor and target so that the missile sticks to its first landing place, as with a real mortar
                                          Have tried to use magnetism in UI but doesnt seem to have any effect? 😲
                                          What am I doing wrong?
                                          Robin
                                          mortar 3.skp
                                            PituPhysics
                                            I made more models to be more opportunities.
                                            1.) Frozen: mortar 4.1.skp
                                            2.) Hide: mortar 4.2.skp
                                            3.) Simulation pause: mortar 4.3.skp
                                            And magnet test:magnet.skp
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 42
                                            • 46
                                            • 47
                                            • 40 / 47
