    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 927.6k Views 172 Watching
    • robintR Offline
      robint
      @anton_s said:
      Hi, Robin,
      I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
      Regards,
      Anton
      Hi Anton
      It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
      BTW just seen some example in Sketchucation, blown away with the talent out there
      Hope my little exercises aren' t too dull
      Cheers
      Robin
      As one door closes another one slams in your face
      • gillesG Offline
        gilles
        What am I doing wrong?
        THEO-JANSEN2.skp
          Anton_S
          Hi, gilles,
          You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
          Anton
          • gillesG Offline
            gilles
            Thanks Anton,
            Very nice tool you made there.
            THEO.skp
              Anton_S
              Very clever, gilles!
              I'm sure there is a way to improve performance and stiffness of that thing.
              Anton
              • gillesG Offline
                gilles
                Thรฉo Jansen.
                http://www.strandbeest.com/index.php ๐Ÿ‘
                  The peaceful robots! ๐Ÿ˜Ž
                  • gillesG Offline
                    gilles
                    I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
                    Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
                    Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
                    Just for anybody else having the same troubles.
                    Mac OSX 10.8.5, SU2015.
                      Anton_S
                      Yeah, I'm working on that. Thanks for the report, gilles!
                      • robintR Offline
                        robint
                        [attachment=0:3sqfwcxi]<!-- ia0 -->MS-UI.gif<!-- ia0 -->[/attachment:3sqfwcxi]
                        Hi gilles
                        I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry
                        kinda convoluted
                        Robin
                          Anton_S
                          Announcing 0.9.9!
                          This version comes with mainly an improved dialog and joints.
                          View changelog for details: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                          Anton
                            SketchyPhysicsNutt
                            Thanks Anton for fixing the full-screen issue my animations are back to normal ๐Ÿ˜„
                            MSPhysics 0.9.9
                            tested on win 8.1 and sketchup 2015/2016 working fine.
                            the new plane joint works great on single or two different planes ๐Ÿ‘
                            thx again and merry xmas
                            Tez
                              Anton_S
                              Hello, Tez,
                              Good to hear that it's working now. And merry Christmas to you too!
                              Best regards,
                              Anton
                                SketchyPhysicsNutt
                                Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
                                in Sketchyphysics i just tick the OnTouch panel and use
                                playSound('Sound1')
                                what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error?
                                its no bug ..just me don't understand MS scripts yet.
                                Tez
                                • robintR Offline
                                  robint
                                  Hi Anton, installed 0.9.9 and restarted SU
                                  but its screwed up my model?
                                  It falls downwards and I cant get the static floor to work as before, also the script stopped working
                                  Did I do a corrupt installation?
                                  Should I have deleted 0.9.8 first - you didnt say?
                                  I assumed it would overwrite and update itself
                                  Where to go? delete and start fresh installation or go back to 0.9.8?
                                  What to do? ๐Ÿ˜ณ
                                  Robin
                                  falling block7.skp
                                    Anton_S
                                    Tez,
                                    In the Sound tab of the MSPhysics UI, whenever a sound is added, a piece of code for playing the sounds is displayed below. For your case, after you add the sound to the MSPhysics UI, the code for playing it would be:
                                    onTouch { |toucher, position, normal, force, speed|
                                      simulation.play_sound("Sound1")
                                    You can also refer to this scripting documentation link for playing 3D sounds: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/master/file/Overview.md#Music___Sound
                                    Anton
                                      Anton_S
                                      Robin,
                                      I assume the script you talk about is the controllable sphere thingy. There has been some scripting changes and the documentation for the controllable sphere is updated. For your case, you will have to replace the add_force2 function with the add_force function.
                                      Now, I don't know how the static floor behaved previously. Basing on the model you posted, everything is working fine. I don't see any issues.
                                      If you want to revert to on original version, you may always refer to the instructions on the homepage.
                                      Anton
                                      • robintR Offline
                                        robint
                                        Very strange Anton, I removed the sphere from the model to avaoid confusion , but on mine Falling block 7 the whole model falls. I must assume I got a corrupt installation, so will start again afresh back to 0.9.8 and fb 6
                                        Cheers
                                        Robin
                                        • robintR Offline
                                          robint
                                          I am pleased to report, that after a tedious uninstall of msp and a clean instal of 0.9.9, everything now seems to work ok
                                          Overwriting existing files looks unwise and it was severely screwed up
                                          I would advise users
                                          Cheers
                                          Robin
                                          PS I made the block and floor out of tungsten carbide, so the block didnt penetrate AKAIK, but bounces as expected
                                          falling block8.skp
                                          • F Offline
                                            faust07
                                            Thanks Anton for making MSPhysics better and better. First impression of running an old model with Curvy Pistons with version 0.9.9 - all moves but some objects move backwards... - I will test in the next days what I must change to get the desired results.
                                            Merry Christmas to all friends of SketchUp, physics and animation.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 46
                                            • 47
                                            • 20 / 47
