    MSPhysics 1.0.3 (16 October 2017)
    927 Posts 171 Posters 1.1m Views 172 Watching
      Anton_S
      Hi, Armand,
      A hinge with no parent groups will act stationary. In order for the hinge to move, it must have a parent group. What I think is going on in your model is that the hinges are top level groups. If you want a hinge to link two groups together, and still move, simply create a hinge joint within one of the groups andd then, using the joint connection tool, connect it to the other group. That way the hinge joint will have a parent body, which will allow it to move.
      Check out this mini clip:
      Movable Joints Example
      The message is there so that people using your model would know that they need MSPhysics in order to run it.
      Regards,
      Anton
      • gillesG Offline
        gilles
        I think I have some issue with hinge when I link it to a parent:
        Mac OSX 10.8.5, SU2015.
          Anton_S
          Hi, gilles,
          To fix that, you have to select the joint, open MSPhysics UI, and check the "connected collide" option.
          Regards,
          Anton
          • robintR Offline
            robint
            @anton_s said:
            Hi, Robin,
            I'm glad I could help.
            Best regards,
            Anton
            I made a simple mass/spring damper system as per model, but I get some odd results not like the damped sinusoid
            Am I on the right track or have I made some basic errors
            Also the block doesn't sit still on the plane but wanders off
            I am also having difficulty tying in the UI with real values of spring rate N/m and damping c*velocity Ns/m
            Any advice, most appreciated
            Cheers
            Robin
            BTW I looked at the Ruby docs but couldnt tie up real units to the constants
            classic spring damper
            As one door closes another one slams in your face
            • gillesG Offline
              gilles
              @anton_s said:
              Hi, gilles,
              Regards,
              Anton
              Works fine ๐Ÿ‘
              A lot to dig in, I go back to the mine.
                Anton_S
                Hi, Robin,
                The block doesn't sit still probably because you disabled the friction. Enabling the friction checkbox option for the block and for the floor contacting the block will fix the wandering off behavior.
                I will add an option to control accel and damp with the SI units in the upcoming release. At the moment, I figured that spring constant is roughly equals to (accel * 7 - damp), when spring joint stiffness is set to 1.0.
                Edit: Ensure that both anuglar and linear damping for all bodies are set to zero. This improves the closeness.
                Anton
                • robintR Offline
                  robint
                  Hi Anton
                  I'm sure I tried every way with the friction coeffs, and it didnt seem to help much, unless Im doing something wrong. If you could get real SI units into the spring damper model this would be fantastic. Classic maths leaves everything in normalised units which is really hard for students to translate into the real world - thats what MS physics is about. I try to encourage my student to abandon th suck-it-and-see approach in favour of understanding what is really happening and calculating the effect. I know that math is a real turn off for most users, but I try
                  cheers Robin
                  • robintR Offline
                    robint
                    @anton_s said:
                    Hi, Robin,
                    Anton
                    Yes indeed, improved action, I missed the friction box
                    Herewith a revised model changing block mass from 0 - 0.5 kg gives a displacement of 0 - 1.0 so the spring rate is 2
                    spring stiff 1 (what does this do?)
                    Accel 1, damp 1.5 (gives critical damping approx)
                    changing sample rate from 1/60 to 1/240 changes the whole model performance
                    iterations 16 - improves stability
                    the plane has a mass of 0.01kg, lowest i could get without instability
                    So Ive actually got a spring damper that sort of behaves but it seems like the spring has inertial mass - an ideal spring should be zero mass and friction
                    What do you think? Anything I can do to help (ruby dummy just now)
                    Cheers
                    Robin) ๐Ÿ˜›
                    V 2
                      Anton_S
                      Hi, Robin,
                      I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
                      Regards,
                      Anton
                      • robintR Offline
                        robint
                        @anton_s said:
                        Hi, Robin,
                        Regards,
                        Anton
                        Hi Anton
                        It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
                        BTW just seen some example in Sketchucation, blown away with the talent out there
                        Hope my little exercises aren' t too dull
                        Cheers
                        Robin
                        • gillesG Offline
                          gilles
                          What am I doing wrong?
                          THEO-JANSEN2.skp
                            Anton_S
                            Hi, gilles,
                            You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
                            Anton
                            • gillesG Offline
                              gilles
                              Thanks Anton,
                              Very nice tool you made there.
                              THEO.skp
                                Anton_S
                                Very clever, gilles!
                                I'm sure there is a way to improve performance and stiffness of that thing.
                                Anton
                                • gillesG Offline
                                  gilles
                                  Thรฉo Jansen.
                                  http://www.strandbeest.com/index.php ๐Ÿ‘
                                    The peaceful robots! ๐Ÿ˜Ž
                                    • gillesG Offline
                                      gilles
                                      I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
                                      Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
                                      Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
                                      Just for anybody else having the same troubles.
                                        Anton_S
                                        Yeah, I'm working on that. Thanks for the report, gilles!
                                        • robintR Offline
                                          robint
                                          [attachment=0:3sqfwcxi]<!-- ia0 -->MS-UI.gif<!-- ia0 -->[/attachment:3sqfwcxi]
                                          Hi gilles
                                          I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry
                                          kinda convoluted
                                          Robin
                                            Anton_S
                                            Announcing 0.9.9!
                                            This version comes with mainly an improved dialog and joints.
                                            View changelog for details: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                                            Anton
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 46
                                            • 47
                                            • 26 / 47
