    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
    • gillesG Offline
      gilles
      I think I have some issue with hinge when I link it to a parent:
      Mac OSX 10.8.5, SU2015.
        Anton_S
        Hi, gilles,
        To fix that, you have to select the joint, open MSPhysics UI, and check the "connected collide" option.
        Regards,
        Anton
        • robintR Offline
          robint
          @anton_s said:
          Hi, Robin,
          I'm glad I could help.
          Best regards,
          Anton
          I made a simple mass/spring damper system as per model, but I get some odd results not like the damped sinusoid
          Am I on the right track or have I made some basic errors
          Also the block doesn't sit still on the plane but wanders off
          I am also having difficulty tying in the UI with real values of spring rate N/m and damping c*velocity Ns/m
          Any advice, most appreciated
          Cheers
          Robin
          BTW I looked at the Ruby docs but couldnt tie up real units to the constants
          classic spring damper
          As one door closes another one slams in your face
          • gillesG Offline
            gilles
            @anton_s said:
            Hi, gilles,
            Regards,
            Anton
            Works fine ๐Ÿ‘
            A lot to dig in, I go back to the mine.
              Anton_S
              Hi, Robin,
              The block doesn't sit still probably because you disabled the friction. Enabling the friction checkbox option for the block and for the floor contacting the block will fix the wandering off behavior.
              I will add an option to control accel and damp with the SI units in the upcoming release. At the moment, I figured that spring constant is roughly equals to (accel * 7 - damp), when spring joint stiffness is set to 1.0.
              Edit: Ensure that both anuglar and linear damping for all bodies are set to zero. This improves the closeness.
              Anton
              • robintR Offline
                robint
                Hi Anton
                I'm sure I tried every way with the friction coeffs, and it didnt seem to help much, unless Im doing something wrong. If you could get real SI units into the spring damper model this would be fantastic. Classic maths leaves everything in normalised units which is really hard for students to translate into the real world - thats what MS physics is about. I try to encourage my student to abandon th suck-it-and-see approach in favour of understanding what is really happening and calculating the effect. I know that math is a real turn off for most users, but I try
                cheers Robin
                • robintR Offline
                  robint
                  @anton_s said:
                  Hi, Robin,
                  Anton
                  Yes indeed, improved action, I missed the friction box
                  Herewith a revised model changing block mass from 0 - 0.5 kg gives a displacement of 0 - 1.0 so the spring rate is 2
                  spring stiff 1 (what does this do?)
                  Accel 1, damp 1.5 (gives critical damping approx)
                  changing sample rate from 1/60 to 1/240 changes the whole model performance
                  iterations 16 - improves stability
                  the plane has a mass of 0.01kg, lowest i could get without instability
                  So Ive actually got a spring damper that sort of behaves but it seems like the spring has inertial mass - an ideal spring should be zero mass and friction
                  What do you think? Anything I can do to help (ruby dummy just now)
                  Cheers
                  Robin) ๐Ÿ˜›
                  V 2
                    Anton_S
                    Hi, Robin,
                    I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
                    Regards,
                    Anton
                    • robintR Offline
                      robint
                      @anton_s said:
                      Hi, Robin,
                      Regards,
                      Anton
                      Hi Anton
                      It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
                      BTW just seen some example in Sketchucation, blown away with the talent out there
                      Hope my little exercises aren' t too dull
                      Cheers
                      Robin
                      • gillesG Offline
                        gilles
                        What am I doing wrong?
                        THEO-JANSEN2.skp
                          Anton_S
                          Hi, gilles,
                          You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
                          Anton
                          • gillesG Offline
                            gilles
                            Thanks Anton,
                            Very nice tool you made there.
                            THEO.skp
                              Anton_S
                              Very clever, gilles!
                              I'm sure there is a way to improve performance and stiffness of that thing.
                              Anton
                              • gillesG Offline
                                gilles
                                Thรฉo Jansen.
                                http://www.strandbeest.com/index.php ๐Ÿ‘
                                  The peaceful robots! ๐Ÿ˜Ž
                                  • gillesG Offline
                                    gilles
                                    I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
                                    Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
                                    Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
                                    Just for anybody else having the same troubles.
                                      Anton_S
                                      Yeah, I'm working on that. Thanks for the report, gilles!
                                      • robintR Offline
                                        robint
                                        [attachment=0:3sqfwcxi]<!-- ia0 -->MS-UI.gif<!-- ia0 -->[/attachment:3sqfwcxi]
                                        Hi gilles
                                        I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry
                                        kinda convoluted
                                        Robin
                                          Anton_S
                                          Announcing 0.9.9!
                                          This version comes with mainly an improved dialog and joints.
                                          View changelog for details: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                                          Anton
                                            SketchyPhysicsNutt
                                            Thanks Anton for fixing the full-screen issue my animations are back to normal ๐Ÿ˜„
                                            MSPhysics 0.9.9
                                            tested on win 8.1 and sketchup 2015/2016 working fine.
                                            the new plane joint works great on single or two different planes ๐Ÿ‘
                                            thx again and merry xmas
                                            Tez
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 46
                                            • 47
                                            • 26 / 47
