    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • gillesG
      gilles
      @anton_s said:
      Hi, gilles,
      To fix that, you have to select the joint, open MSPhysics UI, and check the "connected collide" option.
      Regards,
      Anton
      Works fine ๐Ÿ‘
      A lot to dig in, I go back to the mine.
        Anton_S
        Hi, Robin,
        The block doesn't sit still probably because you disabled the friction. Enabling the friction checkbox option for the block and for the floor contacting the block will fix the wandering off behavior.
        I will add an option to control accel and damp with the SI units in the upcoming release. At the moment, I figured that spring constant is roughly equals to (accel * 7 - damp), when spring joint stiffness is set to 1.0.
        Edit: Ensure that both anuglar and linear damping for all bodies are set to zero. This improves the closeness.
        Anton
        • robintR
          robint
          Hi Anton
          I'm sure I tried every way with the friction coeffs, and it didnt seem to help much, unless Im doing something wrong. If you could get real SI units into the spring damper model this would be fantastic. Classic maths leaves everything in normalised units which is really hard for students to translate into the real world - thats what MS physics is about. I try to encourage my student to abandon th suck-it-and-see approach in favour of understanding what is really happening and calculating the effect. I know that math is a real turn off for most users, but I try
          cheers Robin
          As one door closes another one slams in your face
          • robintR
            robint
            @anton_s said:
            Hi, Robin,
            Anton
            Yes indeed, improved action, I missed the friction box
            Herewith a revised model changing block mass from 0 - 0.5 kg gives a displacement of 0 - 1.0 so the spring rate is 2
            spring stiff 1 (what does this do?)
            Accel 1, damp 1.5 (gives critical damping approx)
            changing sample rate from 1/60 to 1/240 changes the whole model performance
            iterations 16 - improves stability
            the plane has a mass of 0.01kg, lowest i could get without instability
            So Ive actually got a spring damper that sort of behaves but it seems like the spring has inertial mass - an ideal spring should be zero mass and friction
            What do you think? Anything I can do to help (ruby dummy just now)
            Cheers
            Robin) ๐Ÿ˜›
            V 2
              Anton_S
              Hi, Robin,
              I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
              Regards,
              Anton
              • robintR
                robint
                @anton_s said:
                Hi, Robin,
                Regards,
                Anton
                Hi Anton
                It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
                BTW just seen some example in Sketchucation, blown away with the talent out there
                Hope my little exercises aren' t too dull
                Cheers
                Robin
                • gillesG
                  gilles
                  What am I doing wrong?
                  THEO-JANSEN2.skp
                    Anton_S
                    Hi, gilles,
                    You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
                    Anton
                    • gillesG
                      gilles
                      Thanks Anton,
                      Very nice tool you made there.
                      THEO.skp
                        Anton_S
                        Very clever, gilles!
                        I'm sure there is a way to improve performance and stiffness of that thing.
                        Anton
                        • gillesG
                          gilles
                          Thรฉo Jansen.
                          http://www.strandbeest.com/index.php ๐Ÿ‘
                            The peaceful robots! ๐Ÿ˜Ž
                            • gillesG
                              gilles
                              I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
                              Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
                              Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
                              Just for anybody else having the same troubles.
                              Mac OSX 10.8.5, SU2015.
                                Anton_S
                                Yeah, I'm working on that. Thanks for the report, gilles!
                                • robintR
                                  robint
                                  [attachment=0:3sqfwcxi]<!-- ia0 -->MS-UI.gif<!-- ia0 -->[/attachment:3sqfwcxi]
                                  Hi gilles
                                  I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry
                                  kinda convoluted
                                  Robin
                                    Anton_S
                                    Announcing 0.9.9!
                                    This version comes with mainly an improved dialog and joints.
                                    View changelog for details: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                                    Anton
                                      SketchyPhysicsNutt
                                      Thanks Anton for fixing the full-screen issue my animations are back to normal ๐Ÿ˜„
                                      MSPhysics 0.9.9
                                      tested on win 8.1 and sketchup 2015/2016 working fine.
                                      the new plane joint works great on single or two different planes ๐Ÿ‘
                                      thx again and merry xmas
                                      Tez
                                        Anton_S
                                        Hello, Tez,
                                        Good to hear that it's working now. And merry Christmas to you too!
                                        Best regards,
                                        Anton
                                          SketchyPhysicsNutt
                                          Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
                                          in Sketchyphysics i just tick the OnTouch panel and use
                                          playSound('Sound1')
                                          what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error?
                                          its no bug ..just me don't understand MS scripts yet.
                                          Tez
                                          • robintR
                                            robint
                                            Hi Anton, installed 0.9.9 and restarted SU
                                            but its screwed up my model?
                                            It falls downwards and I cant get the static floor to work as before, also the script stopped working
                                            Did I do a corrupt installation?
                                            Should I have deleted 0.9.8 first - you didnt say?
                                            I assumed it would overwrite and update itself
                                            Where to go? delete and start fresh installation or go back to 0.9.8?
                                            What to do? ๐Ÿ˜ณ
                                            Robin
                                            falling block7.skp
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 46
                                            • 47
                                            • 26 / 47
