    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 883.2k Views 172 Watching
    • robintR Offline
      robint
      Hi Anton
      I'm sure I tried every way with the friction coeffs, and it didnt seem to help much, unless Im doing something wrong. If you could get real SI units into the spring damper model this would be fantastic. Classic maths leaves everything in normalised units which is really hard for students to translate into the real world - thats what MS physics is about. I try to encourage my student to abandon th suck-it-and-see approach in favour of understanding what is really happening and calculating the effect. I know that math is a real turn off for most users, but I try
      cheers Robin
      As one door closes another one slams in your face
      • robintR Offline
        robint
        @anton_s said:
        Hi, Robin,
        The block doesn't sit still probably because you disabled the friction. Enabling the friction checkbox option for the block and for the floor contacting the block will fix the wandering off behavior.
        I will add an option to control accel and damp with the SI units in the upcoming release. At the moment, I figured that spring constant is roughly equals to (accel * 7 - damp), when spring joint stiffness is set to 1.0.
        Edit: Ensure that both anuglar and linear damping for all bodies are set to zero. This improves the closeness.
        Anton
        Yes indeed, improved action, I missed the friction box
        Herewith a revised model changing block mass from 0 - 0.5 kg gives a displacement of 0 - 1.0 so the spring rate is 2
        spring stiff 1 (what does this do?)
        Accel 1, damp 1.5 (gives critical damping approx)
        changing sample rate from 1/60 to 1/240 changes the whole model performance
        iterations 16 - improves stability
        the plane has a mass of 0.01kg, lowest i could get without instability
        So Ive actually got a spring damper that sort of behaves but it seems like the spring has inertial mass - an ideal spring should be zero mass and friction
        What do you think? Anything I can do to help (ruby dummy just now)
        Cheers
        Robin) 😛
        V 2
          Anton_S
          Hi, Robin,
          I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
          Regards,
          Anton
          • robintR Offline
            robint
            @anton_s said:
            Hi, Robin,
            Regards,
            Anton
            Hi Anton
            It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
            BTW just seen some example in Sketchucation, blown away with the talent out there
            Hope my little exercises aren' t too dull
            Cheers
            Robin
            • gillesG Offline
              gilles
              What am I doing wrong?
              THEO-JANSEN2.skp
                Anton_S
                Hi, gilles,
                You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
                Anton
                • gillesG Offline
                  gilles
                  Thanks Anton,
                  Very nice tool you made there.
                  THEO.skp
                    Anton_S
                    Very clever, gilles!
                    I'm sure there is a way to improve performance and stiffness of that thing.
                    Anton
                    • gillesG Offline
                      gilles
                      Théo Jansen.
                      http://www.strandbeest.com/index.php 👍
                        The peaceful robots! 😎
                        • gillesG Offline
                          gilles
                          I had issues with MS UI: modifying values, sometimes works sometimes not. 😡
                          Then I notice this: typing a value +enter or tab does not work. 😮
                          Typing a value + click outside the input box works… 😮
                          Just for anybody else having the same troubles.
                          Mac OSX 10.8.5, SU2015.
                            Anton_S
                            Yeah, I'm working on that. Thanks for the report, gilles!
                            • robintR Offline
                              robint
                              [attachment=0:3sqfwcxi]<!-- ia0 -->MS-UI.gif<!-- ia0 -->[/attachment:3sqfwcxi]
                              Hi gilles
                              I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry
                              kinda convoluted
                              Robin
                                Anton_S
                                Announcing 0.9.9!
                                This version comes with mainly an improved dialog and joints.
                                View changelog for details: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                                Anton
                                  SketchyPhysicsNutt
                                  Thanks Anton for fixing the full-screen issue my animations are back to normal 😄
                                  MSPhysics 0.9.9
                                  tested on win 8.1 and sketchup 2015/2016 working fine.
                                  the new plane joint works great on single or two different planes 👍
                                  thx again and merry xmas
                                  Tez
                                    Anton_S
                                    Hello, Tez,
                                    Good to hear that it's working now. And merry Christmas to you too!
                                    Best regards,
                                    Anton
                                      SketchyPhysicsNutt
                                      Sorry Anton forgot to ask u in my last post about simple OnTouch sound scripts
                                      in Sketchyphysics i just tick the OnTouch panel and use
                                      playSound('Sound1')
                                      what's the MSphysics equivalent script for Ontouch sound .....i keep getting an error?
                                      its no bug ..just me don't understand MS scripts yet.
                                      Tez
                                      • robintR Offline
                                        robint
                                        Hi Anton, installed 0.9.9 and restarted SU
                                        but its screwed up my model?
                                        It falls downwards and I cant get the static floor to work as before, also the script stopped working
                                        Did I do a corrupt installation?
                                        Should I have deleted 0.9.8 first - you didnt say?
                                        I assumed it would overwrite and update itself
                                        Where to go? delete and start fresh installation or go back to 0.9.8?
                                        What to do? 😳
                                        Robin
                                        falling block7.skp
                                          Anton_S
                                          Tez,
                                          In the Sound tab of the MSPhysics UI, whenever a sound is added, a piece of code for playing the sounds is displayed below. For your case, after you add the sound to the MSPhysics UI, the code for playing it would be:
                                          onTouch { |toucher, position, normal, force, speed|
                                            simulation.play_sound("Sound1")
                                          You can also refer to this scripting documentation link for playing 3D sounds: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/master/file/Overview.md#Music___Sound
                                          Anton
                                            Anton_S
                                            Robin,
                                            I assume the script you talk about is the controllable sphere thingy. There has been some scripting changes and the documentation for the controllable sphere is updated. For your case, you will have to replace the add_force2 function with the add_force function.
                                            Now, I don't know how the static floor behaved previously. Basing on the model you posted, everything is working fine. I don't see any issues.
                                            If you want to revert to on original version, you may always refer to the instructions on the homepage.
                                            Anton
                                            • 46
                                            • 47
                                            • 3 / 47
