    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      Anton_S
      Hi, Robin,
      I'm glad I could help.
      Best regards,
      Anton
        Sjamon
        Dear Anton,
        I just downloaded the plugin to make a simple cinematic / collision check on a folding workbench model, that is basically a deformable parallelogram.
        Although I got the basic principle and manage to make singles hinges move as expected, any component is stuck as soon as it's linked to two hinges.
        There's also a message reading "Requires MSPhysics 0.9.8+" in a corner of the screen, should I understand that it won't work unless I install something else ?
        Armand
          Anton_S
          Hi, Armand,
          A hinge with no parent groups will act stationary. In order for the hinge to move, it must have a parent group. What I think is going on in your model is that the hinges are top level groups. If you want a hinge to link two groups together, and still move, simply create a hinge joint within one of the groups andd then, using the joint connection tool, connect it to the other group. That way the hinge joint will have a parent body, which will allow it to move.
          Check out this mini clip:
          Movable Joints Example
          The message is there so that people using your model would know that they need MSPhysics in order to run it.
          Regards,
          Anton
          • gillesG
            gilles
            I think I have some issue with hinge when I link it to a parent:
            Mac OSX 10.8.5, SU2015.
              Anton_S
              Hi, gilles,
              To fix that, you have to select the joint, open MSPhysics UI, and check the "connected collide" option.
              Regards,
              Anton
              • robintR
                robint
                @anton_s said:
                Hi, Robin,
                Best regards,
                Anton
                I made a simple mass/spring damper system as per model, but I get some odd results not like the damped sinusoid
                Am I on the right track or have I made some basic errors
                Also the block doesn't sit still on the plane but wanders off
                I am also having difficulty tying in the UI with real values of spring rate N/m and damping c*velocity Ns/m
                Any advice, most appreciated
                Cheers
                Robin
                BTW I looked at the Ruby docs but couldnt tie up real units to the constants
                classic spring damper
                As one door closes another one slams in your face
                • gillesG
                  gilles
                  @anton_s said:
                  Hi, gilles,
                  Regards,
                  Anton
                  Works fine ๐Ÿ‘
                  A lot to dig in, I go back to the mine.
                    Anton_S
                    Hi, Robin,
                    The block doesn't sit still probably because you disabled the friction. Enabling the friction checkbox option for the block and for the floor contacting the block will fix the wandering off behavior.
                    I will add an option to control accel and damp with the SI units in the upcoming release. At the moment, I figured that spring constant is roughly equals to (accel * 7 - damp), when spring joint stiffness is set to 1.0.
                    Edit: Ensure that both anuglar and linear damping for all bodies are set to zero. This improves the closeness.
                    Anton
                    • robintR
                      robint
                      Hi Anton
                      I'm sure I tried every way with the friction coeffs, and it didnt seem to help much, unless Im doing something wrong. If you could get real SI units into the spring damper model this would be fantastic. Classic maths leaves everything in normalised units which is really hard for students to translate into the real world - thats what MS physics is about. I try to encourage my student to abandon th suck-it-and-see approach in favour of understanding what is really happening and calculating the effect. I know that math is a real turn off for most users, but I try
                      cheers Robin
                      • robintR
                        robint
                        @anton_s said:
                        Hi, Robin,
                        Anton
                        Yes indeed, improved action, I missed the friction box
                        Herewith a revised model changing block mass from 0 - 0.5 kg gives a displacement of 0 - 1.0 so the spring rate is 2
                        spring stiff 1 (what does this do?)
                        Accel 1, damp 1.5 (gives critical damping approx)
                        changing sample rate from 1/60 to 1/240 changes the whole model performance
                        iterations 16 - improves stability
                        the plane has a mass of 0.01kg, lowest i could get without instability
                        So Ive actually got a spring damper that sort of behaves but it seems like the spring has inertial mass - an ideal spring should be zero mass and friction
                        What do you think? Anything I can do to help (ruby dummy just now)
                        Cheers
                        Robin) ๐Ÿ˜›
                        V 2
                          Anton_S
                          Hi, Robin,
                          I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
                          Regards,
                          Anton
                          • robintR
                            robint
                            @anton_s said:
                            Hi, Robin,
                            Regards,
                            Anton
                            Hi Anton
                            It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
                            BTW just seen some example in Sketchucation, blown away with the talent out there
                            Hope my little exercises aren' t too dull
                            Cheers
                            Robin
                            • gillesG
                              gilles
                              What am I doing wrong?
                              THEO-JANSEN2.skp
                                Anton_S
                                Hi, gilles,
                                You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
                                Anton
                                • gillesG
                                  gilles
                                  Thanks Anton,
                                  Very nice tool you made there.
                                  THEO.skp
                                    Anton_S
                                    Very clever, gilles!
                                    I'm sure there is a way to improve performance and stiffness of that thing.
                                    Anton
                                    • gillesG
                                      gilles
                                      Thรฉo Jansen.
                                      http://www.strandbeest.com/index.php ๐Ÿ‘
                                        The peaceful robots! ๐Ÿ˜Ž
                                        • gillesG
                                          gilles
                                          I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
                                          Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
                                          Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
                                          Just for anybody else having the same troubles.
                                            Anton_S
                                            Yeah, I'm working on that. Thanks for the report, gilles!
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 46
                                            • 47
                                            • 26 / 47
