    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.0m Views 79 Watching
    • ontaottoO Offline
      ontaotto
      @thomthom said:
      Lovely example!
      Btw, what software is that? Do you know if it uses OpenSubdiv?
      Thanks, it is Carrara the which is very compatible with SketchUp, and I don't know about Open SubD??
      Twitter: @ontaotto
      • ontaottoO Offline
        ontaotto
        @panixia said:
        not 100% sure about the exagon being the best starting shape, depending on what i have to do, in most cases, i start from 4,8,12,16 segments.. anything you can split by 4.. there are some cases in wich i use 6, that's fine, but i would not say that's always"the golden rule".. it tends to generate asymmetrical topology distribution/flow/cap, sometimes it's what i need, sometime it's not..
        looking at your grid example, in that case exagon is the best way to go, bacause you need to tile your rows "alternate" but in the case of a "stack bond style" tiling, that same base topology could be quite problematic..
        so definetly, it depends on the shape/topology you are tryng to achieve.
        Yes sure, what I am saying is to build tubes, and as you have seen in the T Pipe tubes the best sample I have done was by using octagons, the main shape recommended to subdivide is the square, mainly known as Quad, it may vary according the model of course.
        Twitter: @ontaotto
          It's the de-factor subdivision standard that's being adopted. Originally developed by pixar: http://graphics.pixar.com/opensubdiv/docs/intro.html
          Next version of SUbD will use OpenSubdiv as the subdivision engine - so it'll subdivide consistently with other applications that implement OpenSubdiv.
          • ontaottoO Offline
            ontaotto
            Well honestly I have no idea if Carrara does have that, however I have done several tests in this program and the process to subdivide is quite similar to other 3D programs such Maya, Blender and others, I am very excited about the SU plugin you have developed, I did install it a few months ago, I was trying to upload more samples but my trial has been expired, (so sad) Will post some other samples soon.
            Regards!
            Otto
            Twitter: @ontaotto
            • BoxB Offline
              A little pub doodle. If i get a chance in the next few days I'll reconstruct it fully as a gif.
              http://i.imgur.com/1303dBI.gif
                kenancakir
                Hi Box, it says image not found, from Turkiye..
                • BoxB Offline
                  That is strange, it is my normal Imgur account which you have seen on FB.
                  The gif was too big to upload directly here.
                  I'll add a screenshot for you.
                  • BoxB Offline
                    Here we go, sorry, I would normally post the non facebooked one here but I forgot to keep a clean copy.
                    http://i.imgur.com/gEkvuNf.gif
                    • bazB Offline
                      baz
                      That's amazing. You go crazy!
                      • cottyC Offline
                        cotty
                        +1
                        πŸ‘
                        my SketchUp gallery
                        • ontaottoO Offline
                          ontaotto
                          That's pretty nice!
                          Twitter: @ontaotto
                          • HornOxxH Offline
                            HornOxx
                            @box said:
                            A little pub doodle
                            πŸ‘ πŸ‘
                            this is so great again - Where do you get these crazy ideas from ??
                            BTW - thanks for your many BOX-gifs here which always are so interesting and so helpful !!!
                            never trust a skinny cook
                              Kito Raupp inspiration! πŸ˜‰
                              • dereiD Offline
                                derei
                                A friend of mine just finished a reprap 3d printer and I thought to "celebrate" his achievement, by modeling a boat for him to print...
                                • N Offline
                                  nlipovac
                                  [attachment=0:10i72gyl]<!-- ia0 -->Mowiti.jpg<!-- ia0 -->[/attachment:10i72gyl]
                                  It looks great!
                                  Hove did you do lettering?
                                  • aarondietzenA Offline
                                    aarondietzen
                                    Been a while since I posted anything here!
                                    Quick model I did earlier this week:
                                    "Imagination is more important than knowledge..."
                                    - Albert Einstein
                                    • dereiD Offline
                                      derei
                                      @nlipovac said:
                                      It looks great!
                                      I had a jpg image of my friend's logo, I imported it in Inkscape -> Trace Bitmap -> Save as DXF
                                      Imported in SketchUp + Thomthom Edge Tools -> Simplify curves (I had to weld all curves before), then
                                      Sandbox Drape + Fredo JPP
                                      *sandbox drape works only on blue axis, so I had to turn the boat on a side for that operation.
                                      ** i did the letters on the plain mesh, after using subD and converting it into plain mesh.
                                      • HornOxxH Offline
                                        HornOxx
                                        @derei said:
                                        ...I had a jpg image of my friend's logo, I imported it in Inkscape -> Trace Bitmap -> Save as DXF.
                                        Sandbox Drape + Fredo JPP.
                                        πŸ‘ Great - I love this little boat
                                        Do I get you right - the 3D text remains a geometry of itΒ΄s own?
                                        • HornOxxH Offline
                                          HornOxx
                                          @aarondietzen said:
                                          ...Quick model I did earlier this week...
                                          πŸ‘ Wonderful - what a nice SubD model idea this example is again !
                                          To reduce the geometry to what is just necessary always looks so simple but is the challenge πŸ˜‰
                                          (would you mind to share this proxy here?)
                                          • HornOxxH Offline
                                            HornOxx
                                            A Little Christmas Contribution and best Wishes
                                            Candle Proxy.skp
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 82
                                            • 83
                                            • 25 / 83
