    SOLVED: Replacing image texture without upsetting mapping
    23 Posts 9 Posters 10.8k Views 9 Watching
    • T
      thomaslaidesign
      So are you confirming that I need to manually map fresh texture if I need more than one texture in a SU file?
      That there can only exist ONE INSTANCE of a texture/mapping, unless ofcourse created from scratch.
      Bummer ...
        If Cone#1 has the same UVs as Cone#2 then simple open Cone#1.skp and replace the Cone#1 texture with Cone#2 texture and save the file as Cone#2.skp
        Now in Cone#1.skp import the Cone#2.skp and both will reside in the same file.
        Painting an already textured object with another texture doesn't inherit the UVs.
        If the use Fredo's ThruPaint you can replace the texture and keep the UVs.
        • T
          thomaslaidesign
          Nope ...
          Using the "save as" technique is resulting in
          imported file with Texture2 to be replaced by Texture1 of open file.
          Further experimentation is
          on ...
            Upload the file.
            • T
              thomaslaidesign
              Exporting to DAE and reimporting has worked!
              • T
                thomaslaidesign
                For people to try for themselves!
                MAT TEST.skp
                • N
                  numerobis
                  I'm not sure if i understand your problem, but if you just want to replace the material without messing up the UVs you can simply use the "Entity Info" window to select another material. This will not overwrite the mapping.
                  Or you can use a plugin to replace materials of a selection like this one:
                  http://sketchucation.com/pluginstore?pln=Global_Material_Change
                  (works for objects with more than one material, for multiple groups or components)
                  • T
                    thomaslaidesign
                    @numberios:
                    When I have only ONE object which has been textured and mapped, it is easy to replace the texture by renaming the file link in EDIT MATERIAL TAB
                    When I copy that object, it is not possible to have TWO different maps on each of the copy. SU populates BOTH INSTANCES with the LAST texture image applied.
                    Hence this roundabout EXPORT/IMPORT to BREAK the MATERIAL TEXTURE INSTANCING LINK.
                    Of course if there is a simpler/better way to get this done, it will be welcome!
                    So in my illustrated example, I am aiming for the rendered image of FIRST CONE having MAP 1 and SECOND CONE have MAP 2
                    STEP 1 : FIRST CONE is mapped and textured with MAP 1
                    STEP 2 : DUPLICATE FIRST CONE. So we have 2 CONES with MAP 1 only
                    STEP 3 : Select material of SECOND CONE. Replace with MAP 2
                    RESULT : BOTH FIRST AND SECOND CONE now are textured with MAP 2
                    DESIRED RESULT : FIRST CONE has MAP 1 and SECOND CONE has MAP 2
                    • T
                      thomaslaidesign
                      here are the maps
                      • C
                        caronte01
                        Try this:
                        -Copy your base component
                        -Make the copy unique and save it to disk
                        -Open the copy and make a small adjustment to the material (colorize it). and save it.
                        -In the original file, reload the modified component. There should be 2 different materials in the editor, one for each component.
                        -Go to the new component, and edit the texture in an external editor, and paste the new texture over the old one. Make sure the textures line up. Flatten the image and save it.
                        When loading from disk, sketchup tries to maintain visual fidelity of components and materials, so when it finds a similarly named comp or material with different definition, it creates a new material or component definition.
                        • T
                          thomaslaidesign
                          Ok will try this .... similar to the export/import method which also works.
                          Now imagine a row of 10 similar objects and the hassle trying to get 1 to 10 on them. There should be a simple command/plugin to split any material and make it unlinked and unique.
                          • Mistro11M
                            Mistro11
                            Another way is to combine both textures into one map and simply move the UV of the second cone to the desired area of the map....hope that helps.
                            Structural Integrity is Not Just Physical...It's in the Design and Purpose
                            • C
                              caronte01
                              Agreed. A make unique material option would be ideal.
                              • T
                                thomaslaidesign
                                @Mistro11
                                What we are aiming at is a scenario where:
                                Instead of shifting around a relatively complex UVW mapping,
                                simply flip in/out unique material texture images onto group/component copies.
                                • Mistro11M
                                  Mistro11
                                  @thomaslaidesign said:
                                  @Mistro11
                                  Ok, I see....If you have Sketch UV, you can save the UV of the 1st cone, apply new texture to the second one and load the UV.....
                                  • T
                                    thomaslaidesign
                                    @Mistro11
                                    Wow! Thanks for the Plug-in info.....
                                    Good things come in little plug-in packages!
                                    SOLVED!
                                    • duanekempD
                                      duanekemp
                                      I'm so glad this question was asked. Was having the same issue and ran into some bumps. The answers here help. Had a brain fart and forgot about SketchUV's save function. Good call. Thanks.
                                      Duane Kemp
                                      Kemp Productions
                                      Puidoux, Switzerland
                                      Gallery:
                                      https://duanekemp.artstation.com/
                                      • fredo6F
                                        There is a similar function in ThruPaint...
                                        • P
                                          PapcioKris
                                          EZ solution here. NO PLUGINS
                                          1. Map your OBJECT1 with MAP1
                                          2. Open another instance of SU
                                          3. Copy & paste your OBJECT1 to SU2 (It is mapped correctly)
                                          4. Replace MAP1 with MAP2 (only texture) in SU1
                                          5. Copy & paste your OBJECT1 From SU1 to SU2
                                          6. BAM! You have OBJECT2 in SU2 with MAP2
                                          You might want to rename your materials after all.
                                          • N
                                            nlipovac
                                            I see it says it is Solved but here is my use of SketchUV Save and Load UV feature.
                                            SketchUV
