    SOLVED: Replacing image texture without upsetting mapping
    23 Posts 9 Posters 10.8k Views 9 Watching
    • T
      thomaslaidesign
      Ok will try this .... similar to the export/import method which also works.
      Now imagine a row of 10 similar objects and the hassle trying to get 1 to 10 on them. There should be a simple command/plugin to split any material and make it unlinked and unique.
      • Mistro11M
        Mistro11
        Another way is to combine both textures into one map and simply move the UV of the second cone to the desired area of the map....hope that helps.
        Structural Integrity is Not Just Physical...It's in the Design and Purpose
        • C
          caronte01
          Agreed. A make unique material option would be ideal.
          • T
            thomaslaidesign
            @Mistro11
            What we are aiming at is a scenario where:
            Instead of shifting around a relatively complex UVW mapping,
            simply flip in/out unique material texture images onto group/component copies.
            • Mistro11M
              Mistro11
              @thomaslaidesign said:
              @Mistro11
              Ok, I see....If you have Sketch UV, you can save the UV of the 1st cone, apply new texture to the second one and load the UV.....
              • T
                thomaslaidesign
                @Mistro11
                Wow! Thanks for the Plug-in info.....
                Good things come in little plug-in packages!
                SOLVED!
                • duanekempD
                  duanekemp
                  I'm so glad this question was asked. Was having the same issue and ran into some bumps. The answers here help. Had a brain fart and forgot about SketchUV's save function. Good call. Thanks.
                  Duane Kemp
                  Kemp Productions
                  Puidoux, Switzerland
                  Gallery:
                  https://duanekemp.artstation.com/
                  • fredo6F
                    There is a similar function in ThruPaint...
                    • P
                      PapcioKris
                      EZ solution here. NO PLUGINS
                      1. Map your OBJECT1 with MAP1
                      2. Open another instance of SU
                      3. Copy & paste your OBJECT1 to SU2 (It is mapped correctly)
                      4. Replace MAP1 with MAP2 (only texture) in SU1
                      5. Copy & paste your OBJECT1 From SU1 to SU2
                      6. BAM! You have OBJECT2 in SU2 with MAP2
                      You might want to rename your materials after all.
                      • N
                        nlipovac
                        I see it says it is Solved but here is my use of SketchUV Save and Load UV feature.
                        SketchUV
                        • 2 / 2
