    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 417.4k Views 154 Watching
    • F Offline
      fungchi
      i was depressed before i know this plugin! i already installed sectioncutfaces but there's no option for slice the model. i'm stuck and you really made my day!! Thankyou so much! ๐Ÿ‘
      • O Offline
        olivarchi0
        fabulous, thank you ๐Ÿ˜„
          katecheung
          where can i download this great program?
            Search the SketchUcation PluginStore - linked in the menu above...
            • 2 Offline
              2agostosanthi
              ya descargue el zorro, pero ahora no se como lo encuentro en google sketcUp
                It's in 'Tools'...
                Have you read the PDF manual?
                Estรก en 'Herramientas' ...
                ยฟHa leรญdo el manual en formato PDF?
                404 Not Found
                (sketchucation.com)
                  Kuchcok
                  Hi, I have downloaded and installed plugin as said at the first page. Works 100% (W7, SU2016pro). I would like to thank you for great saving of time ๐Ÿ‘
                  Also if there will be some day an update, really helpful would be if plugin can also cuts only visible groups ... now I have to copy and move away from entire model what I want to cut and put it back when done. If I just turn off the layers, for example walls, terrain, windows, etc. and I can "play" only with roof tiles with no need to copy something... itยดs just an opinion
                  It is ๐Ÿ˜Ž and very useful plugin!
                  Cheers mate
                    Zorro2 cuts objects in the model's active_entities context, it also cuts into any nested components/groups in that context is the option is chosen
                    So to cut only part of your model make a temporary group of the objects you wish to cut.
                    Edit that group and use Zorro2 within that edit's entities context.
                    Now anything outside of the group remains unchanged.
                    Explode the group when you are done - if desired...
                    In the attached image I cut a component [which is just a specialized kind of group] and deleted the bottom part - note how outside of the context nothing is affected...
                      melu
                      alguien me podria explicar como descargarlo ?
                        First page of this thread:
                        Then:
                        It's even better if you install the Sketchucation Plugin Store tool and use it to install Zorro2 and other extensions.
                        • W Offline
                          Whaat
                          That is so kind of you to say! You are most welcome. Perhaps it is time to take this Project out of beta... ๐Ÿ’š
                            DragonCF
                            wooooow! its so perfect~
                              Modixxs
                              Wish it could also slice in curves and rounded lines...
                              • ArckadiaA Offline
                                Arckadia
                                I was quietly working with my sketchup friend when the need to cut shapes became a major problem ๐Ÿ˜ฎ . But suddenly in the distance a galloping rider appears in the night and with the tip of his awesome super mega cool PLUGIN Zorro2, all my problems were gone. A thousand thanks Zorro ๐Ÿ‘ ๐Ÿ‘
                                • mkarimanM Offline
                                  mkariman
                                  Hi everybody
                                  I'm having problem with zorro2
                                  i've just installed this plugin on my su2019
                                  but it dose not show up in the toolbars or the zorro(sword) icon in the extensions menu.
                                  does it work with SU 2019 at all?
                                  SOS ๐Ÿ˜•
                                    It should work.
                                    Have you read the 'Zorro2 Tutorial' PDF - which is on the very first post in this thread...
                                    https://sketchucation.com/forums/viewtopic.php?p=124862#p124862
                                    Its menu entry is under 'Tools' NOT 'Extensions' [aka Plugins].
                                    This could be your difficulty ?
                                    There's not a toolbar.
                                    Please read up and come back if you still have issues... e.g. if you have your Extension Manager > Loading Policy set to something other than 'Unrestricted' it might not load at start up if its signature is old etc...
                                    • H Offline
                                      Himbeertoni
                                      2023 zorro2 beta.
                                      Hi to all. Today I tryed this extension. I must use with SU2016 pro.
                                      I liked to cut a model ( 12m ISO Shipping Container)
                                      The original seems made in Blender with the feature
                                      To open the doors.
                                      My target is to cut of only the doors with frame.
                                      Well that was easy, but after I figure out the whole
                                      Container is still there, just invisible.
                                      ( I reimported to SweetHome3D no changing s)
                                      So, what's the catche? How to slice the box and get rid
                                      With the unwished parts? This container is quite complex.
                                      And why, after using the sliced bitit comes back
                                      Thanks for all constructive answers.
                                        GGERMANCRUZ Newcomers @Whaat
                                        @Whaat
                                        The plugin is wonderful, a shame it hasn't been updated in so long. A possible improvement is that when cutting, it would create a face through the cutting area, and that the sectioned groups would remain solid groups. greetings.
                                          Rich O Brien Moderator @GGERMANCRUZ
                                          @GGERMANCRUZ said in [Plugin] Zorro2 (beta):
                                          @Whaat
                                          Zorro is now part of Artisan 2 tool suite
                                          • 12
                                          • 13
                                          • 14
                                          • 15
                                          • 16
                                          • 16 / 16
