    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 430.7k Views 154 Watching
      @snoodles1990 said:
      I have tried to download this plugin (inserted the Zorro2.rb into my system files: Program Files (x86)_Google_Google SketchUp 8_Plugins) without any luck. After I have uploaded it into my program files I should expect to see "Zorro" show up in my Sketchup "Tools," however, it does not show up? Any suggestions?
      I have tried to reboot sketchup and my computer. I don't know what else I can do.Thanks for any and all help.
      Where did you get the file you downloaded? The one that is available here on SCF comes as an rbz file, not rb. Do not put rbz files into the Plugins folder. After downloading the rbz file, open SketchUp and go to Window>Preferences>Extensions. Click on Install Extensions... Navigate to the location where you saved the file, select it and click on the affirmative answers.
      Better, install the Sketchucation Plugin Store plugin that way and use it to automatically install the plugin.
        snoodles1990
        Thanks this did it. This is the first .rbz I have downloaded to date. Thanks for your help.
        • H
          Heda27869415
          Hi Whaat i seem to be having a bugsplat problem with my zorro2 plugin, i also really need to use it asap, please can you help me. oh and thank you for such an amazing tool.
          • W
            Whaat
            What version of SketchUp are you using?
            • F
              fungchi
              i was depressed before i know this plugin! i already installed sectioncutfaces but there's no option for slice the model. i'm stuck and you really made my day!! Thankyou so much! 👍
              • O
                olivarchi0
                fabulous, thank you 😄
                • K
                  katecheung
                  where can i download this great program?
                    Search the SketchUcation PluginStore - linked in the menu above...
                      2agostosanthi
                      ya descargue el zorro, pero ahora no se como lo encuentro en google sketcUp
                        It's in 'Tools'...
                        Have you read the PDF manual?
                        Está en 'Herramientas' ...
                        ¿Ha leído el manual en formato PDF?
                        404 Not Found
                        (sketchucation.com)
                        • K
                          Kuchcok
                          Hi, I have downloaded and installed plugin as said at the first page. Works 100% (W7, SU2016pro). I would like to thank you for great saving of time 👍
                          Also if there will be some day an update, really helpful would be if plugin can also cuts only visible groups ... now I have to copy and move away from entire model what I want to cut and put it back when done. If I just turn off the layers, for example walls, terrain, windows, etc. and I can "play" only with roof tiles with no need to copy something... it´s just an opinion
                          It is 😎 and very useful plugin!
                          Cheers mate
                            Zorro2 cuts objects in the model's active_entities context, it also cuts into any nested components/groups in that context is the option is chosen
                            So to cut only part of your model make a temporary group of the objects you wish to cut.
                            Edit that group and use Zorro2 within that edit's entities context.
                            Now anything outside of the group remains unchanged.
                            Explode the group when you are done - if desired...
                            In the attached image I cut a component [which is just a specialized kind of group] and deleted the bottom part - note how outside of the context nothing is affected...
                              melu
                              alguien me podria explicar como descargarlo ?
                                First page of this thread:
                                Then:
                                It's even better if you install the Sketchucation Plugin Store tool and use it to install Zorro2 and other extensions.
                                • W
                                  Whaat
                                  That is so kind of you to say! You are most welcome. Perhaps it is time to take this Project out of beta... 💚
                                    DragonCF
                                    wooooow! its so perfect~
                                      Modixxs
                                      Wish it could also slice in curves and rounded lines...
                                      • ArckadiaA
                                        Arckadia
                                        I was quietly working with my sketchup friend when the need to cut shapes became a major problem 😮 . But suddenly in the distance a galloping rider appears in the night and with the tip of his awesome super mega cool PLUGIN Zorro2, all my problems were gone. A thousand thanks Zorro 👍 👍
                                        • mkarimanM
                                          mkariman
                                          Hi everybody
                                          I'm having problem with zorro2
                                          i've just installed this plugin on my su2019
                                          but it dose not show up in the toolbars or the zorro(sword) icon in the extensions menu.
                                          does it work with SU 2019 at all?
                                          SOS 😕
                                            It should work.
                                            Have you read the 'Zorro2 Tutorial' PDF - which is on the very first post in this thread...
                                            https://sketchucation.com/forums/viewtopic.php?p=124862#p124862
                                            Its menu entry is under 'Tools' NOT 'Extensions' [aka Plugins].
                                            This could be your difficulty ?
                                            There's not a toolbar.
                                            Please read up and come back if you still have issues... e.g. if you have your Extension Manager > Loading Policy set to something other than 'Unrestricted' it might not load at start up if its signature is old etc...
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 16 / 16
