[Plugin] Door-Lintel Update + Window-Sill
@pbacot said:
It's been a while since I used this tool and it looks like interest in it has dropped off judging by the activity here. What other methods have people been using?
I recently discovered TIG's Hole Punching tool...
http://forums.sketchucation.com/viewtopic.php?t=30846
which could work as a more efficient alternative depending on your components and objectives. -
Thanks for the note. I haven't been using that method, though I have looked at the plugin a few times. I'll look into it.
Didier has agreed that I might update some of his Plugins in the PluginStore.
Please get the latest v2014/2015 compatible version from the PluginStore http://sketchucation.com/pluginstore?pln=door_lintel -
Please get the latest version from the PluginStorefollowing the download button doesn't take me to the correct page, also, if I search the pluginstore, either by author or by plugin name it does not show this plugin
is it an error there or on my machine somehow?
thanks for doing this Tig...
Sorry, but although I had updated the RBZ I forgot to click 'Publish' in the PluginStore Dev-page...
NOW its Download link should work !
It was gone when I went to look, but after a few seconds it was there.
Dear Didier Bur,
This so magical very easy to use and give incredible result. because it saves lot of time which is consumed by conventional method(which is very cumbersome) of putting doors And windows. your this plug-in has put an end on that ordeal of deleting every single vertical and horizontal line on faces of walls, which very irritating thank you very much and keep it up!
EXCELLENT! THX
This plugin is wonderful!
Does it work within a component? It seems to work for me only when it's in the "open!?" -
I have been trying to use it using Profile Builder 3 , it seems to have some kind of problem detecting rectangular vertical face.
Hi syahirXIII,
The message shown on your image pops up when the reveal's face loop is made of more than 4 edges.
Please check if this is the case on the face that doesn't work.
Regards -
@TIG
hello
This plugin doesn't seem to support sketchup2024
A very suitable plugin, can you fix it working on sketchup024?
thanks -
@Didier-Bur
hello
thanks
