    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 55.7k Views 32 Watching
    • Didier BurD
      Didier Bur
      Done.
      Was a typo, "w" instead of "d" in Plugins menu option 🎉
      (Note to french users: pas de probleme avec la version française)
      DB
      • PixeroP
        Pixero
        Thanks for this great script! 👍
        • I
          ilay7k
          Didier thanks for fix ☀
          it alive...works
          Pixero
          +7 ...sketchup...+7000
          it closes to parametric... 😲
          multiple selections of sides will be wonderful for it and connection with multiwall tool 😒 💭
          • erikBE
            erikB
            Thanks for the update. This is a very usefull tool !!!
            erikB
            • pbacotP
              It's been a while since I used this tool and it looks like interest in it has dropped off judging by the activity here. What other methods have people been using? I have been working with solid groups more and components, but sometime I just want to use something like this. There are some drawbacks to the tool at present:
              I cannot make a shortcut key command operate the tool. Nothing happens. So it is slow if you are doing a lot of doors, pulling down the menus each time. Also I have found if you preselect the embrasures, you can work them all one by one by selecting the tool over and over. I wonder if the tool could be set to work on multiple instances in one command.
              The tool would also be enhanced by having an active phase, with a toolbar. Then just clicking on an embrasure would perform the preset lintel. That would be the quickest use.
              I sometimes get an error message that the maximum door height is exceeded. It has no relationship to the drawing that I can see. Then I cannot use the tool until I reduce the door height then set it back up again where I want it. I thought I might look at adjusting the script, but it's encoded.
              Windows are set by sill and window size. It seems to me that convention would make it appropriate to set window head height and window size instead. Then adjusting for a different window would usually take only one input as window heads are usually constant in a building.
              This tool works well and cleanly. It's helpful if you have imported CAD wall lines that already have openings. Probably has other uses in joining shapes. Thanks, Peter
                SUFractal
                Just discovered this plugin this morning ... very handy when importing a plan drawing in CAD as you suggested. I agree with your comments about some minor tweaking.
                  ArCAD-UK
                  I recently discovered TIG's Hole Punching tool...
                  http://forums.sketchucation.com/viewtopic.php?t=30846
                  which could work as a more efficient alternative depending on your components and objectives.
                  • pbacotP
                    Thanks for the note. I haven't been using that method, though I have looked at the plugin a few times. I'll look into it.
                      Didier has agreed that I might update some of his Plugins in the PluginStore.
                      Please get the latest v2014/2015 compatible version from the PluginStore http://sketchucation.com/pluginstore?pln=door_lintel
                      guanjinG 1 Reply Last reply
                      • jujuJ
                        juju
                        Please get the latest version from the PluginStore
                        following the download button doesn't take me to the correct page, also, if I search the pluginstore, either by author or by plugin name it does not show this plugin
                        is it an error there or on my machine somehow?
                        • KrisidiousK
                          Krisidious
                          thanks for doing this Tig...
                          By: Kristoff Rand
                            Sorry, but although I had updated the RBZ I forgot to click 'Publish' in the PluginStore Dev-page...
                            NOW its Download link should work !
                            • KrisidiousK
                              Krisidious
                              It was gone when I went to look, but after a few seconds it was there.
                              By: Kristoff Rand
                              • P
                                pankaj_tamore
                                Dear Didier Bur,
                                This so magical very easy to use and give incredible result. because it saves lot of time which is consumed by conventional method(which is very cumbersome) of putting doors And windows. your this plug-in has put an end on that ordeal of deleting every single vertical and horizontal line on faces of walls, which very irritating thank you very much and keep it up!
                                • jujuJ
                                  juju
                                  EXCELLENT! THX
                                  • halroachH
                                    halroach
                                    This plugin is wonderful!
                                    Does it work within a component? It seems to work for me only when it's in the "open!?"
                                    FlexTools - Super Quick Windows, Doors, Slats...
                                      SyahirXIII
                                      I have been trying to use it using Profile Builder 3 , it seems to have some kind of problem detecting rectangular vertical face.
                                      Dont work here
                                      But it seems to work here
                                      • Didier BurD
                                        Didier Bur
                                        Hi syahirXIII,
                                        The message shown on your image pops up when the reveal's face loop is made of more than 4 edges.
                                        Please check if this is the case on the face that doesn't work.
                                        Regards
                                        DB
                                        • guanjinG
                                          guanjin @TIG
                                          @TIG
                                          hello
                                          This plugin doesn't seem to support sketchup2024
                                          A very suitable plugin, can you fix it working on sketchup024?
                                          thanks
                                          • guanjinG
                                            guanjin @Didier Bur
                                            @Didier-Bur
                                            hello
                                            thanks
                                            • 2 / 4
