    Animator Gallery
    renderpluginsextensions
    106 Posts 30 Posters 476.6k Views 30 Watching
    • soloS Offline
      quick test using Thea, bit of a pain in the arse as thea only renders 7 frames at a time.
      • ntxdaveN Offline
        ntxdave
        Solo - another good example of using a rendering engine in combination with Animator. I have Twilight-Hobby so I am going to have to step up to another rendering engine.
        Press F1...thank me later
        • soloS Offline
          @ntxdave said:
          Now if I could just find a way to animate the texture πŸ˜„
          Hope this gives some of you some other creative ideas.
          • ntxdaveN Offline
            ntxdave
            Do you know what is clicked at the 3 second mark?
            Is this a plugin that will allow you to create animated textures?
            • soloS Offline
              Not sure if it ever was released, Tavi (TBD) was the author.
              • ntxdaveN Offline
                ntxdave
                This is a work in progress but I am attempting to show how you can use scenes and layers to show/hide object in your animation.
                Scene/Layer Demo - click to view animation
                My ultimate goal is to be able to show water and foam spraying when a car is going through a car wash. In this one, I just made a stupid looking little object to represent the water spray.
                I will have to find a cleaner way to show the shape of the spray and a better texture to use for the water and foam.
                Anyway, the object here, as I said above, was to show that you can make objects show up and hide by altering which scenes and layers are visible during any part of the animation. If you watch, you will see that I added views at different points that capture the screen with different layers activated.
                • soloS Offline
                  • ntxdaveN Offline
                    ntxdave
                    I found 2 in the Extension Warehouse that I will have to take a look at:
                    Animatex by Renderiza
                    Video Texture Plugin for SketchUp by Marc S
                    • JQLJ Offline
                      JQL
                      Tig has one too, forgot it's name.
                      www.casca.pt
                      Visit us on facebook!
                        Image tools I think?
                        I remember it need some .jar Java thing but it did run gifs in the viewport.
                        SKM tools I think?
                        I'm on phone so can't check.
                        • ntxdaveN Offline
                          ntxdave
                          Did a little bit of investigation and found out that several people posted that the animated texture in Animatex does not play in a video. Then I went and looked at the Video Texture Plugin.
                          I downloaded the trial version even though some people had said that an animated gif would not work. I tried it anyway. Here is a rather silly experiment:
                          Animated Texture inside an Animator animation. - Click to play
                          Yes, this little test looks dumb and needs some refinement (like controlling the speed of the animated gif playing inside the video, it does show that it can be done. Now one of the real tricks would be to generate a movie or animated gif of water or foam and applying it as a texture to some crazy shaped objects in the car wash.
                          Man, is this getting intriguing to me.
                          • JQLJ Offline
                            JQL
                            It would be cool if Tomasz could support these animated textures in Thea and if Fredo could keep everything in sync or even finds his way into animating textures with keyframe.
                            I'm thinking of waves, displacement textures, leafs, TV's emitting light, watches pointers turning around, flames bursting from dungeouns for game level developers... It would be a huge leap in what sketchup could traditionally do!
                            www.casca.pt
                            • ntxdaveN Offline
                              ntxdave
                              @fredo6 said:
                              I would suggest that you, dear beta testers, post finished animations under this thread (as YouTube videos).
                              I can agree with this statement. Might I suggest that the moderator for this thread to open up a new one for "Experiments / Trials / Tests" and move all of the posts from this thread that do not meet Fredo's request (and yes I am guilty too) to the new thread. At some point the Gallery thread could then become public to show the capabilities of the Animator plugin.
                              Just an opinion/suggestion. β˜€
                              • soloS Offline
                                • ntxdaveN Offline
                                  ntxdave
                                  Shows the power of a good way to display products.
                                  A little dark but I like this.
                                    Daniel S
                                    Hi All!!!!
                                    I download animator plugin today.. first test:
                                    Click to View Animation
                                    Still donΒ΄t download ffmpeg πŸ˜›
                                    Daniel S
                                      Daniel S
                                      I download ffmpeg.. the gif looks strange, the mp4 export looks good... here the gif:
                                      Daniel S
                                      • soloS Offline
                                        • ntxdaveN Offline
                                          ntxdave
                                          Drone Demo using AmbientOcclusionEx
                                          This is the same model as I posted originally but this version was rendered with the AmbientOcclusionEx plugin.
                                            @Daniel S : Cool gears! 😎
                                            • 2 / 6
